    Need help constructing a sofa with subd
    26 Posts 7 Posters 3.6k Views 7 Watching
    • jo-keJ Offline
      jo-ke
      I still have problems constructing good quality proxies.
      I have to construct this sofa but I am struggling with the right shape of the proxy.
      can anybody help me to find the right shape?
      giorgetti-drive.skp
      http://www.zz7.de
      • ginchiusG Offline
        ginchius
        something like that
        You can find my models at http://sketchucation.com/shop/models
        • jo-keJ Offline
          jo-ke
          Wow. This one looks perfect. You are a real master. How did you do that?
          http://www.zz7.de
          • ginchiusG Offline
            ginchius
            I forget to save modeling process step by step. Started modeling from the sides. Used two plugins: Vertex tools and Extrude edges by rails
            • jo-keJ Offline
              jo-ke
              OK, I understand the first pic.
              but how to get to the thrid dimension?
              http://www.zz7.de
              • jo-keJ Offline
                jo-ke
                OK, so far, so nice. But now is my problem... how to go on?
                http://www.zz7.de
                  Stick to very primitive forms then refine...
                  keep refining as you go...
                  i would have shared the file but i got this from SU...
                  • jo-keJ Offline
                    jo-ke
                    looks effektive and simple.
                    I am going to try it again....
                    not too bad I hope
                    http://www.zz7.de
                      Excellent!
                        Easiest thing to learn is proxy modelling. You're a natural at it too.
                        • jo-keJ Offline
                          jo-ke
                          Thank you for your help. I am really not into proxymodelling... but result is quite well.
                          http://www.zz7.de
                            I think that looks like a fine result, I have problems with proxies too so appreciate how difficult it can be to get your mind around the method.
                              What is the difference between a Proxy and a simple 3D object?
                              State before subdivision ?
                              • ginchiusG Offline
                                ginchius
                                Made short but not full sofa modeling process, here you can download pdf tut
                                https://www.dropbox.com/s/5qgopf6p030oe4t/Sofa%20tut.pdf?dl=0
                                • jo-keJ Offline
                                  jo-ke
                                  Wow! Extra Wow! This is really useful.
                                  I will try to reconstruct it and post my results....
                                  http://www.zz7.de
                                  • HornOxxH Offline
                                    HornOxx
                                    πŸ‘ ... this is an excelent tutorial example here - thanks to all!
                                    never trust a skinny cook
                                      Thanks for the tut.
                                      • jo-keJ Offline
                                        jo-ke
                                        Here's my new attempt
                                        http://www.zz7.de
                                        • HornOxxH Offline
                                          HornOxx
                                          πŸ‘ πŸ˜„ ...as expected with you - a great result
                                          Even the seams you've done - are these simple follow-me shapes?
                                          • ginchiusG Offline
                                            ginchius
                                            I'm glad you like my tutorial
                                            Very good result indeed
                                            @hornoxx said:
                                            ...are these simple follow-me shapes?
                                            For seams I'm usig the "Pipe along path" plugin
                                            • 1 / 2
