    Workspace - office deployment
    5 Posts 4 Posters 668 Views 4 Watching
    • S
      Sl-m
      Hi There,
      We do have 6 X Sketchup licences in the office and every time a new skp version is installed I do have to implement every computer with the same workspace which is a very annoying and time consuming task.
      As I'm the one who masters SKP the best I tend to implement the same workspace on every computer so I can teach my employees how to use the various tools and extension I tried first on my own before deploying them.
      Deployment is a critical issue in an office and I'm struggling to find out where this information is stored so I can easily replicate it.
      Help appreciated.
      Thank you.
      Slim
        I tend to implement the same workspace on every computer...I'm struggling to find out where this information is stored so I can easily replicate it
        Which info are you referring to?
        • B
          Bruce Watt
          I think Slim refers to the placement and location of icons, toolbars and trays within the user interface, but I may be wrong.
          SKUP PRO 2021 latest version / update
          Windows 10 Pro
          Dell Alienware Aurora R10 AMD
          AMD Ryzen™ 9 3900X
          NVIDIA® GeForce RTX™ 2080 Ti 11GB GDDR6
            If it's toolbar locations you're stuck with positioning on each device.
            If you use our ExtensionStore you could use the bundle feature to bulk install a set of plugins per machine.
              Having been through the process of setting up SketchUp on multiple computers, I have a process the seems to streamline it.
              The first things I do are open SU in the previous version and save the blank template file into a directory I can easily find. Then I make a screenshot of the entire SketchUp screen and save that image in the same directory. Since I use both Mac and Windows, I have a screen shot for each.
              Next, I install the SCF Extension Store so I can install the bundle from SCF. I also install my extensions from the EW.
              I've already got my custom styles, materials and local component collections in a directory called SketchUp Assets. I don't put them in the User/AppData or Use/Library/Application Support directories.
              I open the saved template file in the new version of SketchUp and immediately use File>Save as template...
              Next, I import as an image the screenshot I made of the old version to use as a guide for placing toolbars and creating the custom toolbars on the PC side. Then I make the toolbars and place the ones I want displayed.
              Finally, in Preferences, I point SketchUp to the appropriate folders in the SketchUp Assets directory. That Assets directory, the screenshot and the template file can all be copied to a memory stick or to a network drive.
