    Difficult to close a true planar polgon
    11 Posts 3 Posters 935 Views 3 Watching
    • S
      Swany
      Hi all, I often do very large landscapes. I find that I am forever stitching paths etc. It defies logic to me as I cannot close some/most planes without a lot of stitching. Even this process deifies logic as usually chase the closed polygone to a point of the polygone will not close.........it is a point! What further troubles me is when I finish after sometimes hours of work it becomes the plane I wanted proving it always was a planar polygon. Can anyone enlighten me. 😠
      Have attached an image about what I mean
      OK I wont attach an image as this site is not allowing that ATM
      Cheers
      AutoSave_N1233_City park.skp
        How about attaching a sample SKP file?
        • S
          Swany
          Hi Dave I have attached the file to the thread Starter.
            Hmmmm.... Usually when faces need to be triangulated it's because the points are slightly off in the Z direction. That doesn't appear to be the case with your model. How did you go about drawing the curves for the paths? It was simple enough to clean up, though.
            • S
              Swany
              Hi Dave when it came back to me it was not "cleaned up" weird huh? What else is wierd is I can add a model but not an image ATM (very small file). So have returned your file to you to have a look at. mmmmm.skp
              Cheers and thanks foe the assistance.
              • S
                Swany
                Oh, I created it with curves on an image. The image is hidden.
                  Weird. This is what I see. All those triangles are gone.
                  I wonder why you can't upload images. What file extension are you trying to upload?
                  • S
                    Swany
                    Dave I just got rid of all the faces in the model and it was a simple matter of drawing a few lines to remake the poly planar's.........quite easy...but still don't really understand ❓ Maybe I dont need to know.
                    Where you able to select the pathways only when you fixed it?
                    • S
                      Swany
                      😳 Oh, Png, file extension that mus:fro:t be it 😳
                        To be honest, I didn't try. I was rushing to get ready for work. I'd have to look at it again when I get home.
                        It doesn't have to be a PNG. That's what I always use. You should also be able to upload .jpg and .bmp if it's not too large.
                          Put your image in other place then link it! πŸ˜‰
                          https://postimg.org
                          https://s6.postimg.cc/lg1z7yzdd/Sans_titre_17.jpg
                          with the balise of the forum
                          http://sketchucation.com/forums/styles/abbcode/images/img.gif
                          that's giving that! πŸ˜„
                          (with the ultra fun Deck Builder by Sdmitch)
