    Difficult to close a true planar polgon
    11 Posts 3 Posters 827 Views 3 Watching
      Swany
      Hi all, I often do very large landscapes. I find that I am forever stitching paths etc. It defies logic to me as I cannot close some/most planes without a lot of stitching. Even this process deifies logic as usually chase the closed polygone to a point of the polygone will not close.........it is a point! What further troubles me is when I finish after sometimes hours of work it becomes the plane I wanted proving it always was a planar polygon. Can anyone enlighten me. 😠
      Have attached an image about what I mean
      OK I wont attach an image as this site is not allowing that ATM
      Cheers
      AutoSave_N1233_City park.skp
        How about attaching a sample SKP file?
          Swany
          Hi Dave I have attached the file to the thread Starter.
            Hmmmm.... Usually when faces need to be triangulated it's because the points are slightly off in the Z direction. That doesn't appear to be the case with your model. How did you go about drawing the curves for the paths? It was simple enough to clean up, though.
              Swany
              Hi Dave when it came back to me it was not "cleaned up" weird huh? What else is wierd is I can add a model but not an image ATM (very small file). So have returned your file to you to have a look at. mmmmm.skp
              Cheers and thanks foe the assistance.
                Swany
                Oh, I created it with curves on an image. The image is hidden.
                  Weird. This is what I see. All those triangles are gone.
                  I wonder why you can't upload images. What file extension are you trying to upload?
                    Swany
                    Dave I just got rid of all the faces in the model and it was a simple matter of drawing a few lines to remake the poly planar's.........quite easy...but still don't really understand ❓ Maybe I dont need to know.
                    Where you able to select the pathways only when you fixed it?
                      Swany
                      😳 Oh, Png, file extension that mus:fro:t be it 😳
                        To be honest, I didn't try. I was rushing to get ready for work. I'd have to look at it again when I get home.
                        It doesn't have to be a PNG. That's what I always use. You should also be able to upload .jpg and .bmp if it's not too large.
                          Put your image in other place then link it! πŸ˜‰
                          https://postimg.org
                          https://s6.postimg.cc/lg1z7yzdd/Sans_titre_17.jpg
                          with the balise of the forum
                          http://sketchucation.com/forums/styles/abbcode/images/img.gif
                          that's giving that! πŸ˜„
                          (with the ultra fun Deck Builder by Sdmitch)
