    V2017 corrupting Dynamic Components
    7 Posts 4 Posters 602 Views 4 Watching
      tgm
      Loaded the 2017 update this week and now ALL Dynamic Components will not work in either my originally installed 2016 or 2017.
      Installing 2017 somehow corrupted something along the way. I did have this same condition verified by another user so it's not my system that's whacko!
      Does anyone ever check this out prior to releasing??
      Very frustrating as now I have a useless v2016!!
      Tom in GA
      • Rich O BrienR Online
        Did you update the DC extension?
          V2017 does not corrupt Dynamic Components. There was a change to the way the UI for them is handled. As Rich implied, you'll need to update the DC extension in SU2016 since you've installed SU2017.
            tgm
            What does the change in UI on v2017 have to do with the dynamic components on v2016?
            I should be able to run each program independently of each other, correct?
              They changed the way the web dialogs work. they now use the embedded Chromium. This impacts the web dialogs for SU2016, too. They changed this partly because too many users failed to keep IE up to date and the web dialogs wouldn't work.
              Mostly but not entirely. Just update SU Dynamic Component and it'll be OK.
                You can find here!
                It must install from each old version of SU!
                https://extensions.sketchup.com/en/content/dynamic-components
                  Mostly but not entirely. Just update SU Dynamic Component through the Extension Warehouse and it'll be OK.
