    Msphysics load errors
    5 Posts 5 Posters 2.2k Views 5 Watching
    • R
      Randall North
      I have tried to run msphysics on sketchup 2015 make, 2016 pro trail and 2017 make. Same problem with all three. I have checked. The files are there. Please help.
      Error Loading File C:/Users/admin/AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins/MSPhysics/main.rb
      Error: #<Exception: An exception occurred while loading MSPhysics library. The exception occurred due to one or more of the following reasons:
      • LoadError: 126: The specified module could not be found. - C:/Users/admin/AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins/MSPhysics/win64/2.0/msp_lib.so
      • LoadError: 126: The specified module could not be found. - C:/Users/admin/AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins/MSPhysics/win64/2.0/msp_lib_no_sdl.so
      C:/Program Files/SketchUp/SketchUp 2016/Tools/extensions.rb:197:in require' C:/Program Files/SketchUp/SketchUp 2016/Tools/extensions.rb:197:in load'
      C:/Users/admin/AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins/MSPhysics.rb:90:in register_extension' C:/Users/admin/AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins/MSPhysics.rb:90:in module:MSPhysics'
      C:/Users/admin/AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins/MSPhysics.rb:72:in `<top (required)>'
      • A
        Anton_S
        Hi, Randall,
        I think the errors are fixed now. Upgrade to 0.9.7.
        Anton
        • Bryan KB
          Anton, I have separate topic with another problem. Could you take a look at it when you have time?
          Thanks. β˜€
          Here is the link:
          http://sketchucation.com/forums/viewtopic.php?f=15%26amp;t=66097
          • O
            oliviertien
            Not sure if I'm late to the party, but I get the same loading errors in Sketchup 2020 (pro). I'll put the error codes here down below, maybe someone knows what's up:
            Error Loading File C:/Users/ThisPC/AppData/Roaming/SketchUp/SketchUp 2020/SketchUp/Plugins/MSPhysics/main_entry.rb
            Error: #<IOError: The required, staged c extension file, "C:/Users/ThisPC/AppData/Roaming/SketchUp/SketchUp 2020/SketchUp/Plugins/MSPhysics/libraries/stage/win64/2.5/msp_lib.so", is missing!>
            C:/Users/ThisPC/AppData/Roaming/SketchUp/SketchUp 2020/SketchUp/Plugins/ams_Lib/extension_manager.rb:204:in block in require_all' C:/Users/ThisPC/AppData/Roaming/SketchUp/SketchUp 2020/SketchUp/Plugins/ams_Lib/extension_manager.rb:201:in each'
            C:/Users/ThisPC/AppData/Roaming/SketchUp/SketchUp 2020/SketchUp/Plugins/ams_Lib/extension_manager.rb:201:in require_all' C:/Users/ThisPC/AppData/Roaming/SketchUp/SketchUp 2020/SketchUp/Plugins/MSPhysics/main.rb:70:in <top (required)>'
            C:/Program Files/SketchUp/SketchUp 2020/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb:59:in require' C:/Program Files/SketchUp/SketchUp 2020/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb:59:in require'
            C:/Users/ThisPC/AppData/Roaming/SketchUp/SketchUp 2020/SketchUp/Plugins/MSPhysics/main_entry.rb:15:in <top (required)>' C:/Program Files/SketchUp/SketchUp 2020/Tools/extensions.rb:197:in require'
            C:/Program Files/SketchUp/SketchUp 2020/Tools/extensions.rb:197:in load' C:/Users/ThisPC/AppData/Roaming/SketchUp/SketchUp 2020/SketchUp/Plugins/MSPhysics.rb:21:in register_extension'
            C:/Users/ThisPC/AppData/Roaming/SketchUp/SketchUp 2020/SketchUp/Plugins/MSPhysics.rb:21:in <module:MSPhysics>' C:/Users/ThisPC/AppData/Roaming/SketchUp/SketchUp 2020/SketchUp/Plugins/MSPhysics.rb:5:in <top (required)>'
            Error Loading File s4u_scaletool/s4u_scaletool_menu.rb
            Could not find included file 's4u_scaletool/s4u_scaletool_menu.rb'
            • TIGT
              I believe that currently it's incompatible with v2020 - see other posts about this...
