Msphysics load errors
I have tried to run msphysics on sketchup 2015 make, 2016 pro trail and 2017 make. Same problem with all three. I have checked. The files are there. Please help.
Error Loading File C:/Users/admin/AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins/MSPhysics/main.rb
Error: #<Exception: An exception occurred while loading MSPhysics library. The exception occurred due to one or more of the following reasons:- LoadError: 126: The specified module could not be found. - C:/Users/admin/AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins/MSPhysics/win64/2.0/msp_lib.so
- LoadError: 126: The specified module could not be found. - C:/Users/admin/AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins/MSPhysics/win64/2.0/msp_lib_no_sdl.so
C:/Program Files/SketchUp/SketchUp 2016/Tools/extensions.rb:197:in
require' C:/Program Files/SketchUp/SketchUp 2016/Tools/extensions.rb:197:inload'
C:/Users/admin/AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins/MSPhysics.rb:90:inregister_extension' C:/Users/admin/AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins/MSPhysics.rb:90:inmodule:MSPhysics'
C:/Users/admin/AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins/MSPhysics.rb:72:in `<top (required)>' -
Hi, Randall,
I think the errors are fixed now. Upgrade to 0.9.7.
Anton
Anton, I have separate topic with another problem. Could you take a look at it when you have time?
Thanks.
Here is the link:
Not sure if I'm late to the party, but I get the same loading errors in Sketchup 2020 (pro). I'll put the error codes here down below, maybe someone knows what's up:
Error Loading File C:/Users/ThisPC/AppData/Roaming/SketchUp/SketchUp 2020/SketchUp/Plugins/MSPhysics/main_entry.rb
Error: #<IOError: The required, staged c extension file, "C:/Users/ThisPC/AppData/Roaming/SketchUp/SketchUp 2020/SketchUp/Plugins/MSPhysics/libraries/stage/win64/2.5/msp_lib.so", is missing!>
C:/Users/ThisPC/AppData/Roaming/SketchUp/SketchUp 2020/SketchUp/Plugins/ams_Lib/extension_manager.rb:204:inblock in require_all' C:/Users/ThisPC/AppData/Roaming/SketchUp/SketchUp 2020/SketchUp/Plugins/ams_Lib/extension_manager.rb:201:ineach'
C:/Users/ThisPC/AppData/Roaming/SketchUp/SketchUp 2020/SketchUp/Plugins/ams_Lib/extension_manager.rb:201:inrequire_all' C:/Users/ThisPC/AppData/Roaming/SketchUp/SketchUp 2020/SketchUp/Plugins/MSPhysics/main.rb:70:in<top (required)>'
C:/Program Files/SketchUp/SketchUp 2020/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb:59:inrequire' C:/Program Files/SketchUp/SketchUp 2020/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb:59:inrequire'
C:/Users/ThisPC/AppData/Roaming/SketchUp/SketchUp 2020/SketchUp/Plugins/MSPhysics/main_entry.rb:15:in<top (required)>' C:/Program Files/SketchUp/SketchUp 2020/Tools/extensions.rb:197:inrequire'
C:/Program Files/SketchUp/SketchUp 2020/Tools/extensions.rb:197:inload' C:/Users/ThisPC/AppData/Roaming/SketchUp/SketchUp 2020/SketchUp/Plugins/MSPhysics.rb:21:inregister_extension'
C:/Users/ThisPC/AppData/Roaming/SketchUp/SketchUp 2020/SketchUp/Plugins/MSPhysics.rb:21:in<module:MSPhysics>' C:/Users/ThisPC/AppData/Roaming/SketchUp/SketchUp 2020/SketchUp/Plugins/MSPhysics.rb:5:in<top (required)>'
Error Loading File s4u_scaletool/s4u_scaletool_menu.rb
Could not find included file 's4u_scaletool/s4u_scaletool_menu.rb' -
I believe that currently it's incompatible with v2020 - see other posts about this...
