    SketchUcation Tools in 2017
    113 Posts 17 Posters 20.5k Views 17 Watching
    • FrederikF
      Frederik
      @tig said:
      This weird, it works OK for many of us...
      Please copy+paste+enter these in the Ruby Console.
      SCF_Dialog::MINWIDTH
      350 ???
      SCF_Dialog::MAXWIDTH
      900 ???
      What do you get ?
      Please see attached screen grab...
      Cheers
      Kim Frederik
      • JQLJ
        JQL
        @tig said:
        Can someone with this problem please try a slightly different approach...
        Close SketchUp 2017.
        Use Regedit again to reset the dialog's height to a reasonable number [say 500] in the Registry and then close.
        Now select the SketchUp 2017 exe icon [or the equivalent desktop-shortcut] and...
        right-click > context-menu > Run as administrator
        this will launch SketchUp slightly differently with some subtle side-effects like diabling image drag-n-drop !
        Any improvement on the SCF dialog front ?
        No difference. It still only displays the dialog's bar, and reverts the registry to a value of 25(hex) and 37(decimal)
        www.casca.pt
        Visit us on facebook!
        • JQLJ
          JQL
          I just tested it again and changed ALL reg values to 512.
          This made SCF change the width of the bar and still don't display anything else.
          Then I closed Sketchup and got back at the registry editor. Here's what I got:
          www.casca.pt
          • TIGT
            Another possibility...
            Somehow the dialog's min height is getting messed with in the v2017 API [but only for some !], so I have made a test RBS that restricts the min height of that dialog to 100 - which should then be enough to give some borders and let you grab an edge and resize, and perhaps then have it remembered for next time ?
            Please follow these steps...
            Download the attached ZIP file: SCF_Dialog.rbs.zip
            Extract the RBS file that's in it - to somewhere like your Desktop.
            Open C:\Users\YourUserName\AppData\Roaming\SketchUp\SketchUp 2017\SketchUp\Plugins\SketchUcation
            Find the file named SCF_Dialog.rbs
            Select it and rename it SCF_Dialog.rbsxxx so it doesn't load.
            Move the new file SCF_Dialog.rbs into that subfolder.
            Restart SketchUp 2017, test the SCF dialog and report what happens...
            NOTE:
            Because changing that RBS file then breaks the 'signing' hash you must use the Unrestricted Loading Policy.
            If it's unsuccessful...
            Reset things - delete the SCF_Dialog.rbs file and rename the SCF_Dialog.rbsxxx original as SCF_Dialog.rbs.
            When you restart SketchUp 2017 things will be as they were.
            If it's successful...
            I'll prepare a new v3.0.3 to include this 'hack'...
            Let us know...
            SCF_Dialog.rbs.zip
            • N
              NickW
              Hi TIG,
              The MINWIDTH and MAXWIDTH do came back as 350 and 900.
              The Regedit followed by Run As Administrator makes no change.
              • TIGT
                Can't you grab the bottom edge and make it higher ?
                • N
                  NickW
                  OK, so the dialog is now taller, but I cannot change the height. I do get the double headed arrow at the dialog's bottom edge, but cannot drag it either up or down. And the scrollbar on the RHS of the dialog has no effect FWIW.
                  • N
                    NickW
                    Sorry, we had crossing posts. No, I cannot drag it in either direction.
                    • JQLJ
                      JQL
                      Cool hack:
                      I feel we're getting there... can't we have a minimum value bigger than 100
                      www.casca.pt
                      • TIGT
                        The RBS in the attached ZIP has a larger min height [500] so it might at least be usable, at least until I get to the bottom of this weirdness...
                        Please follow the earlier instructions and retest.
                        I can't see how the window is not resize-able for you !
                        It is for me and the code specifically makes it so...
                        Anyway, thanks for the testing...
                        Please report back...
                        SCF_Dialog.rbs.zip
                        • JQLJ
                          JQL
                          Nice this one is useable:
                          Nicelly done, Thanks!
                          www.casca.pt
                          • N
                            NickW
                            I now have a scrollable area, and the scrollbar works. Still cannot resize vertically, but at least it's usable in this form.
                            Thanks, and good luck with finding the root cause. Post again if I can help further.
                            • N
                              NickW
                              JQL
                              Your last three images are blank apart from a caption in the middle.
                              EDIT: ...four...
                              • JQLJ
                                JQL
                                They are not images, they are gifs, Click on them. Sorry for that I usually say you have to click on them but I believe Tig has seen those before, so I assume he knows he has to click them already. My mistake...
                                www.casca.pt
                                • JQLJ
                                  JQL
                                  Here's how they are done with Licecap:
                                  www.casca.pt
                                  • N
                                    NickW
                                    If I click on them I just get a popup window with the same, mostly black, image.
                                    EDIT: AH, no, it just takes a little time to load. Sorry. 😳
                                    • JQLJ
                                      JQL
                                      Damn... I'm not telling everything again. Click on them and wait 3 secs...
                                      www.casca.pt
                                      • N
                                        NickW
                                        😳 Sorry JQL.
                                        Good app that though, thanks for pointing it out.
                                        • TIGT
                                          Can you please try this alternative RBS in the attached ZIP.
                                          As well as setting a min height [500] it also sets a max height [900] - which I hope might make the dialog see sense for those of you with the issue - it already works for me with no tweaks...
                                          Please report back asap...
                                          I need to get this fixed...
                                          SCF_Dialog.rbs.zip
                                          • B
                                            blue442
                                            This worked flawlessly for me.
                                            I had the weird box problem before.
                                            -- it also remembers the size and location.
                                            • 6
                                            • 4 / 6
