    SketchUcation Tools in 2017
    113 Posts 17 Posters 20.0k Views 17 Watching
    • JQLJ
      JQL
      You might have nailed it Tig...
      Taking a look at the registry I get this:
      I'll try changing the height and report back
      www.casca.pt
      Visit us on facebook!
      • JQLJ
        JQL
        Damn,
        I quit sketchup, change the registry value Height for a decimal value of 512, then open sketchup 2017, open Sketchucation Extension Store and only see a bar as usual.
        I close sketchup again, an go to the registry and I see that the decimal value is back at 37...
        This is very strange as it seems eithe Sketchup or Sketchucation Extension Store is forcing that value.
        www.casca.pt
        • N
          NickW
          As JQL indicates you can reset the values for the dialog in the registry but this has no effect on the height of the dialog in SU. If you quit SU without attempting to resize the dialog the registry values remain unaltered. Changing the size of the dialog in SU resets the height value in the registry to Decimal 37. It looks like the width value is responding correctly to resizes.
          Clearing the IE cache has no effect.
            This weird, it works OK for many of us...
            Please copy+paste+enter these in the Ruby Console.
            SCF_Dialog::MINWIDTH
            350 ???
            SCF_Dialog::MAXWIDTH
            900 ???
            What do you get ?
            These are used to set the default sizes, BUT any customized H/W are then remembered in the Registry as SketchUp closes.
            Note that the MAXWIDTH is actually re-used for the initial default dialog height, thereafter it should be remembered as what was set by the user.
            Something is resetting that dialog's height for some of you...
              Can someone with this problem please try a slightly different approach...
              Close SketchUp 2017.
              Use Regedit again to reset the dialog's height to a reasonable number [say 500] in the Registry and then close.
              Now select the SketchUp 2017 exe icon [or the equivalent desktop-shortcut] and...
              right-click > context-menu > Run as administrator
              this will launch SketchUp slightly differently with some subtle side-effects like diabling image drag-n-drop !
              Any improvement on the SCF dialog front ?
              • FrederikF
                Frederik
                350 ???
                900 ???
                What do you get ?
                Please see attached screen grab...
                Cheers
                Kim Frederik
                • JQLJ
                  JQL
                  No difference. It still only displays the dialog's bar, and reverts the registry to a value of 25(hex) and 37(decimal)
                  www.casca.pt
                  • JQLJ
                    JQL
                    I just tested it again and changed ALL reg values to 512.
                    This made SCF change the width of the bar and still don't display anything else.
                    Then I closed Sketchup and got back at the registry editor. Here's what I got:
                    www.casca.pt
                      Another possibility...
                      Somehow the dialog's min height is getting messed with in the v2017 API [but only for some !], so I have made a test RBS that restricts the min height of that dialog to 100 - which should then be enough to give some borders and let you grab an edge and resize, and perhaps then have it remembered for next time ?
                      Please follow these steps...
                      Download the attached ZIP file: SCF_Dialog.rbs.zip
                      Extract the RBS file that's in it - to somewhere like your Desktop.
                      Open C:\Users\YourUserName\AppData\Roaming\SketchUp\SketchUp 2017\SketchUp\Plugins\SketchUcation
                      Find the file named SCF_Dialog.rbs
                      Select it and rename it SCF_Dialog.rbsxxx so it doesn't load.
                      Move the new file SCF_Dialog.rbs into that subfolder.
                      Restart SketchUp 2017, test the SCF dialog and report what happens...
                      NOTE:
                      Because changing that RBS file then breaks the 'signing' hash you must use the Unrestricted Loading Policy.
                      If it's unsuccessful...
                      Reset things - delete the SCF_Dialog.rbs file and rename the SCF_Dialog.rbsxxx original as SCF_Dialog.rbs.
                      When you restart SketchUp 2017 things will be as they were.
                      If it's successful...
                      I'll prepare a new v3.0.3 to include this 'hack'...
                      Let us know...
                      SCF_Dialog.rbs.zip
                      • N
                        NickW
                        Hi TIG,
                        The MINWIDTH and MAXWIDTH do came back as 350 and 900.
                        The Regedit followed by Run As Administrator makes no change.
                          Can't you grab the bottom edge and make it higher ?
                          • N
                            NickW
                            OK, so the dialog is now taller, but I cannot change the height. I do get the double headed arrow at the dialog's bottom edge, but cannot drag it either up or down. And the scrollbar on the RHS of the dialog has no effect FWIW.
                            • N
                              NickW
                              Sorry, we had crossing posts. No, I cannot drag it in either direction.
                              • JQLJ
                                JQL
                                Cool hack:
                                I feel we're getting there... can't we have a minimum value bigger than 100
                                www.casca.pt
                                  The RBS in the attached ZIP has a larger min height [500] so it might at least be usable, at least until I get to the bottom of this weirdness...
                                  Please follow the earlier instructions and retest.
                                  I can't see how the window is not resize-able for you !
                                  It is for me and the code specifically makes it so...
                                  Anyway, thanks for the testing...
                                  Please report back...
                                  SCF_Dialog.rbs.zip
                                  • JQLJ
                                    JQL
                                    Nice this one is useable:
                                    Nicelly done, Thanks!
                                    www.casca.pt
                                    • N
                                      NickW
                                      I now have a scrollable area, and the scrollbar works. Still cannot resize vertically, but at least it's usable in this form.
                                      Thanks, and good luck with finding the root cause. Post again if I can help further.
                                      • N
                                        NickW
                                        JQL
                                        Your last three images are blank apart from a caption in the middle.
                                        EDIT: ...four...
                                        • JQLJ
                                          JQL
                                          They are not images, they are gifs, Click on them. Sorry for that I usually say you have to click on them but I believe Tig has seen those before, so I assume he knows he has to click them already. My mistake...
                                          www.casca.pt
                                          • JQLJ
                                            JQL
                                            Here's how they are done with Licecap:
                                            www.casca.pt
                                            • 4 / 6
