    2017 is here
    82 Posts 31 Posters 11.2k Views 31 Watching
    • 3dita3 Offline
      3dita
      Noticed something new on Trimble's home page?
      Seems Sketchup 2017 is here.
      Not much noise around it though, wonder why..
      Have a go: http://www.sketchup.com/download/all
      3dita - Digital Visual Motion
        The release only happened within the last hour or so.
        • 3dita3 Offline
          3dita
          So I can say "First" for once?? πŸ˜„
            Only the Make for the moment! πŸ˜‰
              You can get SU2017 Pro if you go through the main page and download it.
                  No problem of overwriting previous versions ?
                    No. As with every single release of SketchUp ever, the new version installs entirely separately from older versions. You can even keep using your old SketchUp 2 if you want. πŸ˜‰
                    • ntxdaveN Offline
                      ntxdave
                      Just tried to update to the new version and it said that my license # was not correct. Since I have a maintenance agreement, I assume they will send me the updated license # very soon.
                      Press F1...thank me later
                        The license key and serial number for an older version never works on the newer version of SketchUp. Did you run through the License Wizard? It ought to give you the new license info.
                        http://www.sketchup.com/license/renew
                        • N Offline
                          numerobis
                          Oh, please, not again... 😲
                          So a finally working offset tool, two new inference options and faster transparency are the top new features of 2017?!? How about the performance with 30 million non transparent faces? Or importing 3 million faces? Or executing ruby scripts?!?
                          I hope they saved the best new features for a second video...
                          But yeah, i always wished i could change the axis colors! Must have been really hard to implement! WOW! One color for every direction and i can adjust them separately! Well done. πŸ’š
                          Looks like another wasted year... unbelievable. 😐
                            Have you try to Install Joint PushPull by Fredo 6 ?
                            Edit : resolved β˜€ You must have the ultimate last version!!! (JPP +Lib Fredo)
                              Pilou, you should always install the latest version of all extensions when you get a new version of SketchUp.
                              • G Offline
                                Glenn at home
                                Still no Layer lock option 😞
                                  Last Twilight Render 2.62 works fine! β˜€
                                  But curiously Visualizer not! 😲
                                    driven
                                    @pilou said:
                                    But curiously Visualizer not! :shock:
                                    no mystery there, Visualizer would need to be updated to Ruby 2.2 and development was frozen so it won't be...
                                    it is probably a very easy fix if you can talk them into it...
                                    john
                                      No matter what or how many changes, there will always be the whiners.
                                      • ashscottA Offline
                                        ashscott
                                        Does anyone have any good examples of extensions for the Layout API?
                                        https://blog.sketchup.com/developer/abcs-layouts-c-api
                                        Just some stuff I do with Sketchup.
                                        • jujuJ Offline
                                          juju
                                          @kaas said:
                                          For people who have/make custom ruby plugins: the way you install / enable extensions has been slightly changed.
                                          Just in case:
                                          1. zip your loader.rb (+ folder)
                                          2. rename the zip to rbz
                                          3. install by using the extension manager.
                                          4. In the extension manager - choose the settings (top right) and choose 'unrestricted'
                                          wasn't this the case with SU2016 already?
                                          • K Offline
                                            kaas
                                            @juju - In 2016 You can just drop stuff into the plugin folder and it is loaded at the next start
                                            • 1 / 5
