    2017 is here
    82 Posts 31 Posters 9.6k Views 31 Watching
      @pilou said:
      No problem of overwriting previous versions ?
      No. As with every single release of SketchUp ever, the new version installs entirely separately from older versions. You can even keep using your old SketchUp 2 if you want. πŸ˜‰
      • ntxdaveN Offline
        ntxdave
        Just tried to update to the new version and it said that my license # was not correct. Since I have a maintenance agreement, I assume they will send me the updated license # very soon.
        Press F1...thank me later
          The license key and serial number for an older version never works on the newer version of SketchUp. Did you run through the License Wizard? It ought to give you the new license info.
          http://www.sketchup.com/license/renew
          • N Offline
            numerobis
            Oh, please, not again... 😲
            So a finally working offset tool, two new inference options and faster transparency are the top new features of 2017?!? How about the performance with 30 million non transparent faces? Or importing 3 million faces? Or executing ruby scripts?!?
            I hope they saved the best new features for a second video...
            But yeah, i always wished i could change the axis colors! Must have been really hard to implement! WOW! One color for every direction and i can adjust them separately! Well done. πŸ’š
            Looks like another wasted year... unbelievable. 😐
              Have you try to Install Joint PushPull by Fredo 6 ?
              Edit : resolved β˜€ You must have the ultimate last version!!! (JPP +Lib Fredo)
                Pilou, you should always install the latest version of all extensions when you get a new version of SketchUp.
                  Glenn at home
                  Still no Layer lock option 😞
                    Last Twilight Render 2.62 works fine! β˜€
                    But curiously Visualizer not! 😲
                      driven
                      @pilou said:
                      But curiously Visualizer not! :shock:
                      no mystery there, Visualizer would need to be updated to Ruby 2.2 and development was frozen so it won't be...
                      it is probably a very easy fix if you can talk them into it...
                        No matter what or how many changes, there will always be the whiners.
                        • ashscottA Offline
                          ashscott
                          Does anyone have any good examples of extensions for the Layout API?
                          https://blog.sketchup.com/developer/abcs-layouts-c-api
                          Just some stuff I do with Sketchup.
                          • jujuJ Offline
                            juju
                            @kaas said:
                            For people who have/make custom ruby plugins: the way you install / enable extensions has been slightly changed.
                            Just in case:
                            1. zip your loader.rb (+ folder)
                            2. rename the zip to rbz
                            3. install by using the extension manager.
                            4. In the extension manager - choose the settings (top right) and choose 'unrestricted'
                            wasn't this the case with SU2016 already?
                              kaas
                              @juju - In 2016 You can just drop stuff into the plugin folder and it is loaded at the next start
                              • PixeroP Offline
                                Pixero
                                Does this mean that all rb must be rewritten to a rbz with a loader to function in 2017?
                                  Jim
                                  You can still drop .rb files into the Plugins folder, but you must have the Extension Loading Policy set to "Unrestricted" or "Approve" which has computer security ramifications.
                                  Info on Extensions Loading Policy
                                    bsfranza
                                    wow - impressive release - things go in the right direction i guess πŸ˜„ im so excited to see what su will go in the next releases!
                                    • V Offline
                                      vico44
                                      The old way still work for me (drop stuff in plugin folder)
                                      Visualizer not working for me too 😞
                                      The extension manager is really better...
                                        kaas
                                        Just in case:
                                        Edit: seems like dropping rb's still works. It failed at first for me but it must have been another issue.
                                        • jujuJ Offline
                                          juju
                                          minor annoyance I have is that IE11 (I use Chrome for browsing but keep IE installed as SketchUp uses it) keeps on popping up now that I didn't have with the previous version, anybody else experiencing this?
                                          • jujuJ Offline
                                            juju
                                            aaarrgh!
                                            starting to load extensions (starting on EW) and already have 3 that you can only install from EW directly that have licence issues... seriously??!!!
                                            the new version isn't starting off so well...
                                            I am impressed with the LO updates though, I hope the actual lives up to webpage I read on it.
                                            SU2017 is 64-bit only, I can see some whining there but not from me though, I never needed the 32-bit version in SU2016...
                                            • 1 / 5
