    ๐Ÿ”Œ Smart Spline | Fluid way to handle splines for furniture design and complex structures. Download
    Real world Wip. Glass sculptures.
    120 Posts 21 Posters 63.2k Views 21 Watching
      I'd like that. Don't think my boss would let me get away from work, though.
      • BoxB Offline
        It'll be after November,so everyone who can, will be throwing on their life vests, jumping in the sea and paddling like Cubans but in the other direction.
          True. Maybe I'll be moving in with you.
          • Rich O BrienR Online
            If your willing to fly me and the kids out I'll be there...
            ...with a hammer...smashy time
            • BoxB Offline
              Sure Rich, no problem, you go and wait by the letterbox, I'm sure the tickets will arrive any second now.
              • BoxB Offline
                Not a great photo but it gives you some idea of the scale of this work.
                • bazB Offline
                  baz
                  Fuck me dead and bury me pregnant!
                  • Bryan KB Offline
                    Stunning work! Please show us more progress pictures if you can!
                    • cottyC Offline
                      cotty
                      Have I said WOW already? I'm a big fan of this topic already...
                      my SketchUp gallery
                      • BoxB Offline
                        Ok, here's a couple more.
                        This is still a test sample, we are making this to work through the issues involved in the laminating process. Issues like, how the hell do you glue things this big together without getting air bubbles and crap between the layers.
                        This is 10 sheets of glass with the contour lines compressed to form the image. So it has some depth but nowhere near the final piece which will be 10 times thicker.
                        Something most people don't realise is that glass isn't very easy to see through when you stack it all together, you get multiple reflections and clouding and the more layers the denser it becomes. You eventually can't see through it at all.
                        However, when properly 'glued' together the block of 100 sheets will become pretty much optically clear. You will be able to read a newspaper through it.
                        Here you see the wave shape forming at the top, and that's the monster laser in the background.
                        A better angle to see the figure.
                          d12dozr
                          Fantastic project. Very interested to see the process and results!
                          http://goo.gl/f7ooYh
                          • BoxB Offline
                            This was a test to confirm the amount of detail we wanted to put into it, we needed to do a large enough section so that we could see if the back and front faces worked together. It would be no good if the hair on the back of his head overpowered the detail of his face. I think we have got the balance right.
                            As I mentioned earlier, sheets of glass stacked together become too dense to see through, but once laminated it becomes optically clear.
                            You can see that here, the first image is just dry sheets of glass with all the detail but not glued.
                            The second is the same sheets glued together.
                            The third is with light from underneath.
                            No glue
                            Glued
                            Underlite
                            • cottyC Offline
                              cotty
                              Some would call it an "exceptional art object", others call it "just a test"... ๐Ÿ‘
                              my SketchUp gallery
                              • BoxB Offline
                                Thanks Cotty, I know what you mean.
                                But now that it has answered the questions it's just a 90 kilo lump we have to put somewhere out of the way.
                                  Seems a little morbid! ๐Ÿ˜‰
                                  • andybotA Offline
                                    andybot
                                    yikes, so how much will the full project weigh?!
                                    • BoxB Offline
                                      I think I mentioned that in my original post. ~3000kg each. We are adjusting the calculations all the time as we refine things. The special air bed transporter is limited to 7 metric tons. So we need the two blocks and their support structures to come in at less than that. It's going to be close.
                                      • tuna1957T Offline
                                        tuna1957
                                        insane just freaking insane ! ๐Ÿ˜ฎ ๐Ÿ‘ ๐Ÿ‘ ๐Ÿ‘
                                        • brooklynia373B Offline
                                          brooklynia373
                                          BRAVO!
                                          • BoxB Offline
                                            The job has been tied up in rather uninteresting testing and jig construction lately so no interesting photo ops. But I figured this little vid might be of interest and give a bit of an idea of how dynamic the sculptures will be.
                                            • 6
                                            • 2 / 6
