    Toposhaper Crashing
    23 Posts 11 Posters 6.6k Views 11 Watching
    • ball4872B
      ball4872
      Is there a maximum size that toposhaper will complete? I am trying to create a mesh for my current project and it keeps giving me the pink ruby error window. Just wondering if there is something that I can change to allow it to work successfully. I simplified my contours all the way up to 10 feet and it still crashes. I have a hard due date coming up and in a bit of a time crunch. Anyone else ran into this problem and have found a solution please help.
      The error says it was aborted because of zero length vector.
      • fredo6F
        fredo6
        This would help if you can post the full error (just select the text in the dialog box).
        Also, posting the model would help, in case this is related to the model.
        Fredo
        • ball4872B
          ball4872
          Date: 08-Sep-16 15:41:06
          An error occurred in CALCULATING TERRAINS
          The operation is fully aborted
          Zero length vector)
          TopoShaperAAMixin.rb: 283 -- offset
          TopoShaperAAMixin.rb: 283 -- bb_2_points
          TopoShaperAAMixin.rb: 290 -- contour_cut_segment?
          TopoShaperAlgo.rb: 1895 -- block in hull_proximity_direct_pass
          TopoShaperAlgo.rb: 1895 -- each
          TopoShaperAlgo.rb: 1895 -- find
          TopoShaperAlgo.rb: 1895 -- hull_proximity_direct_pass
          TopoShaperAlgo.rb: 1855 -- hull_proximity_pass
          TopoShaperAlgo.rb: 1744 -- hull_concave_pass
          TopoShaperAlgo.rb: 1676 -- block in hull_concave
          TopoShaperAlgo.rb: 1674 -- each
          TopoShaperAlgo.rb: 1674 -- hull_concave
          TopoShaperAlgo.rb: 1565 -- hull_calculate
          TopoShaperAlgo.rb: 525 -- top_analysis_contour
          TopoShaperAlgo.rb: 418 -- top_processing
          TopoShaperTool.rb: 575 -- algo_processing
          TopoShaperTool.rb: 667 -- execute_validate
          TopoShaperPalette.rb: 130 -- execute_from_palette
          TopoShaperPalette.rb: 76 -- notify_from_palette
          TopoShaperPalette.rb: 518 -- call
          TopoShaperPalette.rb: 518 -- block (2 levels) in palette_validate
          body_Lib6Palette.rb: 3058 -- call
          body_Lib6Palette.rb: 3058 -- execute_button
          body_Lib6Palette.rb: 2865 -- onLButtonUp
          Lib6Palette.rb: 93 -- onLButtonUp
          TopoShaperTool.rb: 985 -- onLButtonUp
          Imported Topography Needs Toposhaper
          • fredo6F
            fredo6
            The model is quite complex and would normally require a lot of clean up
            • contours do not need to be that close in altitude (since it is the quad mesh resolution that detremines the precision)
            • there are a number of ill contours, that cross others. This also should be fixed.
            In general, do not expect to run TopoShaper right away on a model 'out of the box' without looking at the contours and fixing the most obvious visual issues
            I had to make a few changes in TopoShaper and in your model in order to be able to generate the terrain.
            As the file is still big (5 Mb, I cannot post it here). So, please PM me an email address and I'll do it.
            In parallel, I will republish TopoShaper.
            But again, please cleanup your contours beforehand. If you do so, it may even run with the current version of TopoShaper.
            • Remove the crossing contours (there are a few)
            • once you can generate the preview, look at the Red junctions and refuse those which are abnormal
            • you can also exclude weird contours if you wish
            • Use the 'Save and Reload Contours' to update your model, so that you've done the changes once and the correct enveloppe is recalculated.
            Fredo
            • ball4872B
              ball4872
              Thank you so much Fredo. I will definitely from now on clean up all of my contours before running it. It was a hurry project so I didnt spend enough time on the grading. I was only given a few hours to grade out the entire site. I am not able to send messages yet on here so I will give you my email now and delete it once I receive your message. trevor @ stackrockgroup . com
              Thank you so much for the response. I sure love how active and responsive the forums are with sketchup. It has to be the best out there.
              • cottyC
                cotty
                Fredo don't ask for it, but you can always donate via Paypal, you will find a link in the plugin menu structure...
                my SketchUp gallery
                • A
                  aguadodaniel
                  Hello, I am trying to create a mesh for my current project and it keeps giving me the pink ruby error window. Just wondering if there is something that I can change to allow it to work successfully.
                  The error says
                  Date: 28-Jun-20 23:07:03
                  An error occurred in CLEANSING
                  undefined local variable or method `colors_init' for #<F6_TopoShaper::TopoShaperCleanser:0x0000023f501784a0>
                  toposhapercleanser.rbe: 84 -- initialize
                  toposhapertool.rbe: 541 -- new
                  toposhapertool.rbe: 541 -- cleansing_processing
                  toposhapertool.rbe: 523 -- after_selection
                  toposhapertool.rbe: 493 -- notify_edge_picked
                  body_lib6edgepicker.rbe: 539 -- call
                  body_lib6edgepicker.rbe: 539 -- notify_action
                  body_lib6edgepicker.rbe: 595 -- terminate_current_selection
                  toposhapertool.rbe: 658 -- execute_validate
                  toposhapertool.rbe: 387 -- handle_initial_selection
                  toposhapertool.rbe: 319 -- activate
                  toposhapertool.rbe: 133 -- select_tool
                  toposhapertool.rbe: 133 -- action__mapping
                  lib6plugin.rbe: 126 -- call
                  lib6plugin.rbe: 126 -- launch_action
                  lib6plugin.rbe: 224 -- launch_action
                  bootstrap_toposhaper.rbe: 82 -- launch_action
                  bootstrap_toposhaper.rbe: 135 -- block in startup
                  lib6plugin.rbe: 1324 -- command_invoke
                  lib6plugin.rbe: 1306 -- block (2 levels) in build_config_commands
                  lib6traductor.rbe: 1372 -- block in add_command
                  • fredo6F
                    fredo6
                    It may help to post or send me the corresponding model so that I can relate the errors to the geometry.
                    Many thanks
                    Fredo
                    • A
                      aguadodaniel
                      That'll be great, what's your email?
                      • S
                        student moshe
                        Hello friends
                        I had a problem using toposhaper
                        And I was wondering if anyone could help me figure out what the problem was,
                        There is a report text document from toposhaper attached for explanation
                        Ruby Error - CLEANSING - 24-Oct-21 11_10_51.txt
                        • fredo6F
                          fredo6
                          @student moshe said:
                          Hello friends
                          There is a problem in relation with layers in your model. If you could attach the skp file, it would help.
                          • S
                            suprabari Newcomers
                            Hello friends
                            There is a report text document from toposhaper attached for explanation and 1 attached file dwg
                            Ruby Error - CALCULATING TERRAINS - 19-Dec-22 14_55_41.txt
                            area_mess_detail.dwg
                            • S
                              suprabari Newcomers
                              Hello friends
                              There is a report text document from toposhaper attached for explanation and i attached file dwg
                              • S
                                suprabari Newcomers
                                Hello friends
                                  @suprabari said:
                                  I had a problem using toposhaper...
                                  What version of SketchUp are you using? There is no 2021 Free/Make version as you indicate in your profile.
                                  Can you share the .skp file so we can see how you have the model set up?
                                  • S
                                    suprabari Newcomers
                                    My version of Sketchup is 2021, i use .dwg file. Here is my file.
                                    I have another .dwg file and it is running normal, but this .dwg cant
                                      I get the following when I try to run Toposhaper with your file. It may be that Fredo6 will have an idea of what might be changed to get it to work.
                                      In the meantime, The From Contours option with the Sandbox tools seems todo a reasonable job.
                                      • U
                                        upscalevalley Newcomers
                                        TopoShaper is a software tool that is used to create three-dimensional models of terrain from digital elevation data. It is designed to work with large datasets and can handle terrain models with millions of points. However, the maximum size of a model that TopoShaper can complete depends on several factors, including the amount of available memory on the computer being used to run the software and the complexity of the terrain being modeled. In general, the larger the dataset, the more memory and processing power will be required to complete the model. If the computer being used does not have enough resources to handle the size of the dataset, the model may not be able to be completed. It is always a good idea to make sure that the computer being used has sufficient resources to handle the size of the dataset being processed. Additionally, the complexity of the terrain being modeled can also affect the maximum size of a model that TopoShaper can complete. If the terrain is very complex with a large number of features, it may require more resources to generate an accurate model. In such cases, it may be necessary to use a more powerful computer or to break the dataset into smaller pieces and process them separately in order to complete the model.
                                        • T
                                          thiagotomazoli
                                          Estou com o seguinte erro
                                          Date: 17-Oct-23 14:21:14
                                          cannot hide layer that is a part of the active path
                                          body_lib6tool.rbe: 2538 -- visible=
                                          body_lib6tool.rbe: 2538 -- block in switch_to_temp_layer
                                          body_lib6tool.rbe: 2537 -- each
                                          body_lib6tool.rbe: 2537 -- switch_to_temp_layer
                                          toposhapertool.rbe: 1391 -- change_view
                                          toposhapertool.rbe: 1358 -- set_preview_working
                                          toposhapertool.rbe: 544 -- cleansing_processing
                                          body_lib6edgepicker.rbe: 582 -- terminate_current_selection
                                          data6.rb: 65 -- call
                                          data6.rb: 65 -- launch_action
                                          lib6plugin.rbe: 240 -- launch_action
                                          bootstrap_toposhaper.rbe: 83 -- launch_action
                                          bootstrap_toposhaper.rbe: 149 -- block in startup
                                          lib6plugin.rbe: 1469 -- command_invoke
                                          lib6plugin.rbe: 1449 -- block (2 levels) in build_config_commands
                                          lib6traductor.rbe: 1387 -- block in add_command
                                          • T
                                            thiagotomazoli
                                            01.pngOlá, estou com o seguinte erro.
                                            Deu certo uma vez, apareceu a malha e tudo, más não gerou o terreno.
                                            Mapeamento feito por drone, e feito limpeza manual aqui no sketchup.
                                            Más não consigo, sempre aparece o erro
                                            R04- Topografia Inicial.skp
                                            • 1 / 2
