🔌 Quick Selection | Try Didier Bur's reworked classic extension that supercharges selections in SketchUp Download
Toposhaper Crashing
23 Posts 11 Posters 4.5k Views 11 Watching
    ball4872
    Is there a maximum size that toposhaper will complete? I am trying to create a mesh for my current project and it keeps giving me the pink ruby error window. Just wondering if there is something that I can change to allow it to work successfully. I simplified my contours all the way up to 10 feet and it still crashes. I have a hard due date coming up and in a bit of a time crunch. Anyone else ran into this problem and have found a solution please help.
    The error says it was aborted because of zero length vector.
    • F Offline
      This would help if you can post the full error (just select the text in the dialog box).
      Also, posting the model would help, in case this is related to the model.
        ball4872
        Date: 08-Sep-16 15:41:06
        An error occurred in CALCULATING TERRAINS
        The operation is fully aborted
        Zero length vector)
        TopoShaperAAMixin.rb: 283 -- offset
        TopoShaperAAMixin.rb: 283 -- bb_2_points
        TopoShaperAAMixin.rb: 290 -- contour_cut_segment?
        TopoShaperAlgo.rb: 1895 -- block in hull_proximity_direct_pass
        TopoShaperAlgo.rb: 1895 -- each
        TopoShaperAlgo.rb: 1895 -- find
        TopoShaperAlgo.rb: 1895 -- hull_proximity_direct_pass
        TopoShaperAlgo.rb: 1855 -- hull_proximity_pass
        TopoShaperAlgo.rb: 1744 -- hull_concave_pass
        TopoShaperAlgo.rb: 1676 -- block in hull_concave
        TopoShaperAlgo.rb: 1674 -- each
        TopoShaperAlgo.rb: 1674 -- hull_concave
        TopoShaperAlgo.rb: 1565 -- hull_calculate
        TopoShaperAlgo.rb: 525 -- top_analysis_contour
        TopoShaperAlgo.rb: 418 -- top_processing
        TopoShaperTool.rb: 575 -- algo_processing
        TopoShaperTool.rb: 667 -- execute_validate
        TopoShaperPalette.rb: 130 -- execute_from_palette
        TopoShaperPalette.rb: 76 -- notify_from_palette
        TopoShaperPalette.rb: 518 -- call
        TopoShaperPalette.rb: 518 -- block (2 levels) in palette_validate
        body_Lib6Palette.rb: 3058 -- call
        body_Lib6Palette.rb: 3058 -- execute_button
        body_Lib6Palette.rb: 2865 -- onLButtonUp
        Lib6Palette.rb: 93 -- onLButtonUp
        TopoShaperTool.rb: 985 -- onLButtonUp
        Imported Topography Needs Toposhaper
        • F Offline
          The model is quite complex and would normally require a lot of clean up
          • contours do not need to be that close in altitude (since it is the quad mesh resolution that detremines the precision)
          • there are a number of ill contours, that cross others. This also should be fixed.
          In general, do not expect to run TopoShaper right away on a model 'out of the box' without looking at the contours and fixing the most obvious visual issues
          I had to make a few changes in TopoShaper and in your model in order to be able to generate the terrain.
          As the file is still big (5 Mb, I cannot post it here). So, please PM me an email address and I'll do it.
          In parallel, I will republish TopoShaper.
          But again, please cleanup your contours beforehand. If you do so, it may even run with the current version of TopoShaper.
          • Remove the crossing contours (there are a few)
          • once you can generate the preview, look at the Red junctions and refuse those which are abnormal
          • you can also exclude weird contours if you wish
          • Use the 'Save and Reload Contours' to update your model, so that you've done the changes once and the correct enveloppe is recalculated.
            ball4872
            Thank you so much Fredo. I will definitely from now on clean up all of my contours before running it. It was a hurry project so I didnt spend enough time on the grading. I was only given a few hours to grade out the entire site. I am not able to send messages yet on here so I will give you my email now and delete it once I receive your message. trevor @ stackrockgroup . com
            Thank you so much for the response. I sure love how active and responsive the forums are with sketchup. It has to be the best out there.
              cotty
              Fredo don't ask for it, but you can always donate via Paypal, you will find a link in the plugin menu structure...
              my SketchUp gallery
                aguadodaniel
                Hello, I am trying to create a mesh for my current project and it keeps giving me the pink ruby error window. Just wondering if there is something that I can change to allow it to work successfully.
                The error says
                Date: 28-Jun-20 23:07:03
                An error occurred in CLEANSING
                undefined local variable or method `colors_init' for #<F6_TopoShaper::TopoShaperCleanser:0x0000023f501784a0>
                toposhapercleanser.rbe: 84 -- initialize
                toposhapertool.rbe: 541 -- new
                toposhapertool.rbe: 541 -- cleansing_processing
                toposhapertool.rbe: 523 -- after_selection
                toposhapertool.rbe: 493 -- notify_edge_picked
                body_lib6edgepicker.rbe: 539 -- call
                body_lib6edgepicker.rbe: 539 -- notify_action
                body_lib6edgepicker.rbe: 595 -- terminate_current_selection
                toposhapertool.rbe: 658 -- execute_validate
                toposhapertool.rbe: 387 -- handle_initial_selection
                toposhapertool.rbe: 319 -- activate
                toposhapertool.rbe: 133 -- select_tool
                toposhapertool.rbe: 133 -- action__mapping
                lib6plugin.rbe: 126 -- call
                lib6plugin.rbe: 126 -- launch_action
                lib6plugin.rbe: 224 -- launch_action
                bootstrap_toposhaper.rbe: 82 -- launch_action
                bootstrap_toposhaper.rbe: 135 -- block in startup
                lib6plugin.rbe: 1324 -- command_invoke
                lib6plugin.rbe: 1306 -- block (2 levels) in build_config_commands
                lib6traductor.rbe: 1372 -- block in add_command
                • F Offline
                  It may help to post or send me the corresponding model so that I can relate the errors to the geometry.
                  Many thanks
                    aguadodaniel
                    That'll be great, what's your email?
                      student moshe
                      Hello friends
                      I had a problem using toposhaper
                      And I was wondering if anyone could help me figure out what the problem was,
                      There is a report text document from toposhaper attached for explanation
                      Ruby Error - CLEANSING - 24-Oct-21 11_10_51.txt
                      • F Offline
                        @student moshe said:
                        Hello friends
                        There is a problem in relation with layers in your model. If you could attach the skp file, it would help.
                          suprabari Newcomers
                          Hello friends
                          There is a report text document from toposhaper attached for explanation and 1 attached file dwg
                          Ruby Error - CALCULATING TERRAINS - 19-Dec-22 14_55_41.txt
                          area_mess_detail.dwg
                            suprabari Newcomers
                            Hello friends
                            There is a report text document from toposhaper attached for explanation and i attached file dwg
                              suprabari Newcomers
                              Hello friends
                                @suprabari said:
                                I had a problem using toposhaper...
                                What version of SketchUp are you using? There is no 2021 Free/Make version as you indicate in your profile.
                                Can you share the .skp file so we can see how you have the model set up?
                                  suprabari Newcomers
                                  My version of Sketchup is 2021, i use .dwg file. Here is my file.
                                  I have another .dwg file and it is running normal, but this .dwg cant
                                    I get the following when I try to run Toposhaper with your file. It may be that Fredo6 will have an idea of what might be changed to get it to work.
                                    In the meantime, The From Contours option with the Sandbox tools seems todo a reasonable job.
                                    • U Offline
                                      upscalevalley Newcomers
                                      TopoShaper is a software tool that is used to create three-dimensional models of terrain from digital elevation data. It is designed to work with large datasets and can handle terrain models with millions of points. However, the maximum size of a model that TopoShaper can complete depends on several factors, including the amount of available memory on the computer being used to run the software and the complexity of the terrain being modeled. In general, the larger the dataset, the more memory and processing power will be required to complete the model. If the computer being used does not have enough resources to handle the size of the dataset, the model may not be able to be completed. It is always a good idea to make sure that the computer being used has sufficient resources to handle the size of the dataset being processed. Additionally, the complexity of the terrain being modeled can also affect the maximum size of a model that TopoShaper can complete. If the terrain is very complex with a large number of features, it may require more resources to generate an accurate model. In such cases, it may be necessary to use a more powerful computer or to break the dataset into smaller pieces and process them separately in order to complete the model.
                                        thiagotomazoli
                                        Estou com o seguinte erro
                                        Date: 17-Oct-23 14:21:14
                                        cannot hide layer that is a part of the active path
                                        body_lib6tool.rbe: 2538 -- visible=
                                        body_lib6tool.rbe: 2538 -- block in switch_to_temp_layer
                                        body_lib6tool.rbe: 2537 -- each
                                        body_lib6tool.rbe: 2537 -- switch_to_temp_layer
                                        toposhapertool.rbe: 1391 -- change_view
                                        toposhapertool.rbe: 1358 -- set_preview_working
                                        toposhapertool.rbe: 544 -- cleansing_processing
                                        body_lib6edgepicker.rbe: 582 -- terminate_current_selection
                                        data6.rb: 65 -- call
                                        data6.rb: 65 -- launch_action
                                        lib6plugin.rbe: 240 -- launch_action
                                        bootstrap_toposhaper.rbe: 83 -- launch_action
                                        bootstrap_toposhaper.rbe: 149 -- block in startup
                                        lib6plugin.rbe: 1469 -- command_invoke
                                        lib6plugin.rbe: 1449 -- block (2 levels) in build_config_commands
                                        lib6traductor.rbe: 1387 -- block in add_command
                                          thiagotomazoli
                                          01.pngOlá, estou com o seguinte erro.
                                          Deu certo uma vez, apareceu a malha e tudo, más não gerou o terreno.
                                          Mapeamento feito por drone, e feito limpeza manual aqui no sketchup.
                                          Más não consigo, sempre aparece o erro
                                          R04- Topografia Inicial.skp
