    Reduce model complexity
    5 Posts 5 Posters 1.4k Views 5 Watching
      Deanby7
      I have a sofa model that has been created in Fusion (converted to .skp) it contains millions of triangle faces to describe the curvy cushion shapes. Is there a way in Sketchup (or a free plugin) that will reduce the face count whilst retaining most of the shape?
        Import it into Blender
        Add a decimator modifier and set the Collapse ratio to 0.1and check the Symmetry box.
        Apply the modifier and repeat until you get it to where you want it.
        • Alan FraserA Offline
          Alan Fraser
          Learning to use Mesh Wrapper efficiently will pay dividends if you deal with much hi-poly content. It will make for a much neater and more editable model than a savage poly-reduction.
          https://extensions.sketchup.com/en/content/meshwrapper-tool
          3D Figures
            MeshLab is your friend! πŸ˜„ (free)
            (if you have again your original model in some compatible format!)
            import:PLY, STL, OFF, OBJ, 3DS, COLLADA, PTX, V3D, PTS, APTS, XYZ, GTS, TRI, ASC, X3D, X3DV, VRML, ALN
            export:PLY, STL, OFF, OBJ, 3DS, COLLADA, VRML, DXF, GTS, U3D, IDTF, X3D
            • bazB Offline
              baz
              post deleted by me
