    Import model axis wrong
    14 Posts 4 Posters 1.8k Views 4 Watching
    • syburnS Offline
      syburn
      I cant understand why when i import a 3ds file it does not follow the sketchup axis. Z axis in 3d max should correspond to Blue in Sketchup. Also some chairs I have imported seem impossible to rotate from Z axis so that they are flat on the plane Red Green plane. Is there a why to get round this issue easily - im spending ages changing axis and getting very confused.
        Maybe you could share one of the 3ds files so we can take a look?
        How were the 3ds files made? How were they exported? Do you know that they were created in the correct orientation?
        Please complete your profile with the SketchUp version and operating system you are using. That sort of information can be useful in helping you out.
          There are two 3d CAD axes-conventions.
          SketchUp uses the newer one:
          X=screen right
          Y=into screen
          Z=up screen
          Older apps often use
          X=screen right
          Y=up screen
          Z=out of screen
          You usually get the chance to flip YZ axes when exporting/importing file-formats...
          If you don't do that, then it will arrive with the wrong axes, and you then need to rotate the geometry/reset the axes of the component etc...
          • syburnS Offline
            syburn
            Here is the file! Not altered at all. They did not let me alter the axis or anything when it imported.
            3ds file was 1.7mb but when add to sketchup then became 12mb - thats worrying!
            Cheers!
            furniture file
            • cottyC Offline
              cotty
              You should upload the 3ds file instead so that we can try the import too.
              my SketchUp gallery
              • syburnS Offline
                syburn
                They said 3ds file is not allowed?
                  How about putting it into a ZIP file?
                  • syburnS Offline
                    syburn
                    It is a zip file, isn't it?
                      You attached a RAR file which contained the SKP.
                      A RAR is like a ZIP but not the same.
                      Cotty/Dave asked you to attached the 3DS file - not the SKP, the 3DS file-type is not allowed as an attachment, so ZIP the file [or RAR it] and see if it's then small enough to attach...
                      • syburnS Offline
                        syburn
                        Ok here it is. I thought RAR and Winzip are one and the same.
                        Connected to this issue, I am having mega difficulty selecting furniture edges that are nice and straight when the furniture is curved or angled. Selecting the bounding box would be perfect but seems not possible.
                        ASTON_ARMCHAIR_74X84X75.3ds.zip
                          Where did you get the 3ds model?
                          It is clear that it was made so its axes don't agree with SketchUp's axes. It looks like you need to go back to the author and find out what they are doing. It would also be interesting to find out why the backrest is created with the faces inside out. Notice they appear as green--my back face color--in the attached. Also, why does it come in located so far from the origin?
                          As for correcting the orientation, is there anything wrong with using the Move tool?
                          click to animate.
                          • syburnS Offline
                            syburn
                            Its from Minotti - they also have the file in Obj format what ever that is?. I see you draw a construction line on the bounding box to allow easy rotating.
                            Cheers!
                            • cottyC Offline
                              cotty
                              Cheers!
                              No, he doesn't, it's the helping line (0° reference) from the rotation tool.
                              my SketchUp gallery
                                OBJ is another 3d data file.
                                In Pro you can export in that format.
                                There's an OBJ importer available...
                                http://sketchucation.com/pluginstore?pln=obj_importer
                                It has the option to flip the YZ axes as well as choosing units etc...
                                It's slow, but free.
                                There's also a paid importer by Fluid, that is faster.
                                http://www.fluidinteractive.com/products/sketchup-extensions/fluidimporter/
