Import model axis wrong
14 Posts 4 Posters 1.1k Views 4 Watching
    syburn
    I cant understand why when i import a 3ds file it does not follow the sketchup axis. Z axis in 3d max should correspond to Blue in Sketchup. Also some chairs I have imported seem impossible to rotate from Z axis so that they are flat on the plane Red Green plane. Is there a why to get round this issue easily - im spending ages changing axis and getting very confused.
      Maybe you could share one of the 3ds files so we can take a look?
      How were the 3ds files made? How were they exported? Do you know that they were created in the correct orientation?
      Please complete your profile with the SketchUp version and operating system you are using. That sort of information can be useful in helping you out.
        There are two 3d CAD axes-conventions.
        SketchUp uses the newer one:
        X=screen right
        Y=into screen
        Z=up screen
        Older apps often use
        X=screen right
        Y=up screen
        Z=out of screen
        You usually get the chance to flip YZ axes when exporting/importing file-formats...
        If you don't do that, then it will arrive with the wrong axes, and you then need to rotate the geometry/reset the axes of the component etc...
          syburn
          Here is the file! Not altered at all. They did not let me alter the axis or anything when it imported.
          3ds file was 1.7mb but when add to sketchup then became 12mb - thats worrying!
          Cheers!
          furniture file
            cotty
            You should upload the 3ds file instead so that we can try the import too.
            my SketchUp gallery
              syburn
              They said 3ds file is not allowed?
                How about putting it into a ZIP file?
                  syburn
                  It is a zip file, isn't it?
                    You attached a RAR file which contained the SKP.
                    A RAR is like a ZIP but not the same.
                    Cotty/Dave asked you to attached the 3DS file - not the SKP, the 3DS file-type is not allowed as an attachment, so ZIP the file [or RAR it] and see if it's then small enough to attach...
                      syburn
                      Ok here it is. I thought RAR and Winzip are one and the same.
                      Connected to this issue, I am having mega difficulty selecting furniture edges that are nice and straight when the furniture is curved or angled. Selecting the bounding box would be perfect but seems not possible.
                      ASTON_ARMCHAIR_74X84X75.3ds.zip
                        Where did you get the 3ds model?
                        It is clear that it was made so its axes don't agree with SketchUp's axes. It looks like you need to go back to the author and find out what they are doing. It would also be interesting to find out why the backrest is created with the faces inside out. Notice they appear as green--my back face color--in the attached. Also, why does it come in located so far from the origin?
                        As for correcting the orientation, is there anything wrong with using the Move tool?
                        click to animate.
                          syburn
                          Its from Minotti - they also have the file in Obj format what ever that is?. I see you draw a construction line on the bounding box to allow easy rotating.
                          Cheers!
                            cotty
                            Cheers!
                            No, he doesn't, it's the helping line (0° reference) from the rotation tool.
                            my SketchUp gallery
                              OBJ is another 3d data file.
                              In Pro you can export in that format.
                              There's an OBJ importer available...
                              http://sketchucation.com/pluginstore?pln=obj_importer
                              It has the option to flip the YZ axes as well as choosing units etc...
                              It's slow, but free.
                              There's also a paid importer by Fluid, that is faster.
                              http://www.fluidinteractive.com/products/sketchup-extensions/fluidimporter/
