    Skin for terrain
    5 Posts 3 Posters 916 Views 3 Watching
      miikka1978
      I have terrain modeled for golf hole and I would need to take this model into game engine. I would need to select the outer edges of the current terrain model and drop/project these lines to 500mx500m terrain plane, a kind creating a skin between terrain model and terrain plane to create a square terrain model.
      Do you have any suggestion for tools/plugins that I could use to make it quick to do? I have to do it 18 times.
      I was planning to do it by selecting outer edges of the terrain and using Drape tool but this requires flat geometry to be projected. I also tested Curviloft plugin but I didn't get it working. Do you know any other plugins or technique to create this kind of skin?
      http://i.imgur.com/xfU6V2v.png
        Use Vertex Tools on the selected boundary and extrude it on Z.
        Or SDMitch Terrain Skirt tool.
          miikka1978
          Thanks! I have so far tested Skirt tool and that works well in my case at least.
            I had a similar project a year or 2 ago. That time I was dealing with LIDAR scans and 40k images.
            Needed to downsample the mesh and images to get it to open in SU.
              Maybe ?
