    Foundation Plugin
    451 Posts 15 Posters 614.5k Views 15 Watching
    • medeekM
      medeek
      Version 1.6.8 - 03.14.2021
      • Standardized the naming convention of the plugin toolbars.
      Nathaniel P. Wilkerson PE
      Medeek Engineering Inc
      design.medeek.com
      • medeekM
        medeek
        Version 1.6.9 - 03.25.2021
        • Fixed a bug with footing offsets when a (polyline) stemwall terminates non-orthogonally.
        http://design.medeek.com/resources/foundationplugin/images/foundation_su76_800.jpg
        design.medeek.com
        • medeekM
          medeek
          Version 1.6.9b - 03.26.2021
          • Fixed a bug with footing extensions (polyline stemwalls) for SketchUp Pro 2021.
          • Enabled hidden edges for polyline stemwalls that terminate non-orthogonally.
          http://design.medeek.com/resources/foundationplugin/images/foundation_su77_800.jpg
          design.medeek.com
          • medeekM
            medeek
            First look at a hole cut using the new SUBTRACT keyword system:
            https://aws1.discourse-cdn.com/sketchup/original/3X/f/c/fcfa3a82d747e94b0e665eed71592e96d3eaa409.jpeg
            Now I just need to set this up for the other various foundation types (ie. stemwall, stemwall steps, strip footings etc...)
            design.medeek.com
            • medeekM
              medeek
              Version 1.7.0 - 05.09.2021
              • Added an option for subtractive geometry into the General tab of the Global Settings.
              • Sub-groups within foundations and footings can be made persistent and "subtractive" by naming these groups to (subtract1, subtract2, subtract3, etc...)
              http://design.medeek.com/resources/foundationplugin/images/foundation_su78_800.jpg
              http://design.medeek.com/resources/foundationplugin/images/foundation_su80_800.jpg
              Interestingly the code to make this happen was staring me in the face for months. I essentially took the "roof connections" complex roof module, changed up the logic slightly, simplified it, and arrived at this new feature/ability.
              Notice that the subtractive groups cut through the rebar as well as the concrete. Certain other elements such as anchor bolts (groups within groups) are not removed. I may need to give this some additional consideration.
              I guess we need to make this new feature available with the Truss plugin as well now.
              design.medeek.com
              • medeekM
                medeek
                Version 1.7.0b - 05.09.2021
                • Components within foundations can also be made persistent and "subtractive" by naming the component instance to (subtract1, subtract2, subtract3, etc...)
                design.medeek.com
                • medeekM
                  medeek
                  Version 1.7.1 - 05.20.2021
                  • Fixed a bug with subbase and slab insulation options for slab-on-grade foundations.
                  design.medeek.com
                  • medeekM
                    medeek
                    Version 1.7.2 - 06.03.2021
                    • Added four additional parameters to the "User Interface" section of the General tab of the global settings. This allows the customization (colors) of the HTML menus and buttons.
                    design.medeek.com
                    • medeekM
                      medeek
                      Version 1.7.3 - 06.12.2021
                      • Added a "Regen" context menu item for the following foundation assemblies: Polyline Stemwall, Strip Footing, Interior Bearing.
                      design.medeek.com
                      • medeekM
                        medeek
                        Version 1.7.4 - 07.10.2021
                        • Enabled subscription and permanent licensing.
                        • The License tab of the Global Settings now displays the license type.
                        design.medeek.com
                        • medeekM
                          medeek
                          Version 1.7.5 - 08.04.2021
                          • Fixed a bug with the stemwall blockout tool.
                          design.medeek.com
                          • medeekM
                            medeek
                            Tutorial 10 - Subtractive Geometry (15:45 min.)
                            design.medeek.com
                            • medeekM
                              medeek
                              Version 1.7.6 - 09.14.2021
                              • Added an ICF option for polyline stemwalls.
                              • Added an ICF layer in the Global Settings under the "Layers" tab.
                              • Fixed a critical bug with custom materials that was caused by the change in the location of the plugin's data sub-folder.
                              http://design.medeek.com/resources/foundationplugin/images/foundation_su81_800.jpg
                              http://design.medeek.com/resources/foundationplugin/images/foundation_su82_800.jpg
                              View model here:
                              3D Warehouse
                              3D Warehouse is a website of searchable, pre-made 3D models that works seamlessly with SketchUp.
                              (3dwarehouse.sketchup.com)
                              design.medeek.com
                              • medeekM
                                medeek
                                Version 1.7.7 - 09.18.2021
                                • Added an ICF option for stemwall steps.
                                http://design.medeek.com/resources/foundationplugin/images/foundation_su83_800.jpg
                                design.medeek.com
                                • medeekM
                                  medeek
                                  I've been thinking about adding in a Door and Window module to the polyline stemwalls. However, I'm not very familiar with what is common practice as far window and door bucks go.
                                  Any feedback or drawings/details would be greatly appreciated.
                                  https://aws1.discourse-cdn.com/sketchup/original/3X/8/2/82afc53ef76fe018cc253fb8cafc73ff8c416840.jpeg
                                  https://aws1.discourse-cdn.com/sketchup/original/3X/c/f/cf90dbc35179b4ada9a963a6ebb272291eb02cd6.jpeg
                                  https://aws1.discourse-cdn.com/sketchup/original/3X/4/6/46198b175e576ce79f073062822deef0c6d0a10c.jpeg
                                  design.medeek.com
                                  • medeekM
                                    medeek
                                    Now that I'm on the subject of windows it may also be useful to add in some sort of window well feature:
                                    https://aws1.discourse-cdn.com/sketchup/original/3X/4/c/4cbe68e6bb45e0e417077a8ad1184d254d8b5836.jpeg
                                    Window Well Options:
                                    Type: Steel
                                    Shape: Rectangle, Arc, Trapezoid
                                    Width:
                                    Projection:
                                    Depth:
                                    Radius:
                                    Vertical Offset:
                                    design.medeek.com
                                    • medeekM
                                      medeek
                                      Version 1.7.8 - 11.11.2021
                                      • Added interior footings for rectangular and polygon slabs.
                                      • Enabled editing, moving and deleting of interior footings for all slab foundations.
                                      http://design.medeek.com/resources/foundationplugin/images/foundation_su88_800.jpg
                                      Regular slabs now have the same functionality with interior footings as the slab-on-grade foundations.
                                      design.medeek.com
                                      • medeekM
                                        medeek
                                        Version 1.7.9 - 12.24.2021
                                        • Fixed a bug in the slab tool when layers/tags is disabled in the global settings.
                                        I apologize that I did not notice this bug when I added interior footings to the slab module. Typically I enable layers/tags so it managed to sneak past me.
                                        design.medeek.com
                                        • medeekM
                                          medeek
                                          Version 1.8.0 - 02.13.2022
                                          • Fixed a bug with the slab insulation thickness for the SOG draw tool (metric).
                                          • Fixed a bug with the slab and SOG edit menus for slab reinforcement (metric).
                                          http://design.medeek.com/resources/foundationplugin/images2/foundation_su89_800.jpg
                                          design.medeek.com
                                          • medeekM
                                            medeek
                                            Version 1.8.1 - 03.02.2022
                                            • Enabled window wells for polyline stemwall openings: Rectangle, Arc and Trapezoid.
                                            http://design.medeek.com/resources/foundationplugin/images2/foundation_su90_800.jpg
                                            http://design.medeek.com/resources/foundationplugin/images2/foundation_su91_800.jpg
                                            http://design.medeek.com/resources/foundationplugin/images2/foundation_su92_800.jpg
                                            The new updated menu for stemwall openings also shows two other advanced options however I have not yet activated those features yet.
                                            design.medeek.com
                                            • 18
                                            • 19
                                            • 20
                                            • 21
                                            • 22
                                            • 23
                                            • 20 / 23
