    Foundation Plugin
    451 Posts 15 Posters 580.3k Views 15 Watching
    • medeekM Offline
      medeek
      Version 1.6.3 - 10.22.2020
      • Fixed a bug in the strip footing "Outline" edit menu.
      Nathaniel P. Wilkerson PE
      Medeek Engineering Inc
      design.medeek.com
      • medeekM Offline
        medeek
        Version 1.6.4 - 01.11.2021
        • Added the option for post bases for the (Post & Beam) Interior Bearing tool: BC40, BC60.
        http://design.medeek.com/resources/foundationplugin/images/foundation_su69_800.jpg
        Post base hardware added per customer request.
        design.medeek.com
        • medeekM Offline
          medeek
          Version 1.6.4b - 01.14.2021
          • Added the following additional post bases to the Interior Bearing tool: ABU44, ABU66.
          http://design.medeek.com/resources/foundationplugin/images/foundation_su70_800.jpg
          Two additional post bases added per customer request.
          design.medeek.com
          • medeekM Offline
            medeek
            When the foundation segment lengths in a polyline stemwall foundation are too short this is what you get (notice the anchor bolt placement):
            https://aws1.discourse-cdn.com/sketchup/original/3X/b/a/ba1443b0e345add3c636dbc40bc9ded984787e76.jpeg
            I'm working up some additional logic to properly deal with anchor bolt placement with short segment lengths.
            design.medeek.com
            • medeekM Offline
              medeek
              Version 1.6.5 - 02.09.2021
              • Fixed a bug with anchor bolt placement for polyline stemwalls.
              • Added an option for a zero depth footing for polyline stemwalls, which eliminates the footing for this foundation type.
              http://design.medeek.com/resources/foundationplugin/images/foundation_su72_800.jpg
              By setting the depth of the footing to zero you can eliminate the footing from a polyline stemwall, so only the stemwall portion of the foundation is drawn. This is per customer request.
              Also the algorithm for anchor bolt placement for polyline stemwalls is greatly improved, however there can always be further improvements, any feedback is always appreciated.
              design.medeek.com
              • medeekM Offline
                medeek
                Version 1.6.6 - 02.12.2021
                • Added logic to the final assembly routine to allow for electrical components (Medeek Electrical) to be retained within all foundation assemblies.
                http://design.medeek.com/resources/foundationplugin/images/foundation_su73_800.jpg
                design.medeek.com
                • medeekM Offline
                  medeek
                  Version 1.6.7 - 03.07.2021
                  • Fixed a bug with brick ledges (and drain pipe) for slab-on-grade foundations.
                  design.medeek.com
                  • medeekM Offline
                    medeek
                    Version 1.6.8 - 03.14.2021
                    • Standardized the naming convention of the plugin toolbars.
                    design.medeek.com
                    • medeekM Offline
                      medeek
                      Version 1.6.9 - 03.25.2021
                      • Fixed a bug with footing offsets when a (polyline) stemwall terminates non-orthogonally.
                      http://design.medeek.com/resources/foundationplugin/images/foundation_su76_800.jpg
                      design.medeek.com
                      • medeekM Offline
                        medeek
                        Version 1.6.9b - 03.26.2021
                        • Fixed a bug with footing extensions (polyline stemwalls) for SketchUp Pro 2021.
                        • Enabled hidden edges for polyline stemwalls that terminate non-orthogonally.
                        http://design.medeek.com/resources/foundationplugin/images/foundation_su77_800.jpg
                        design.medeek.com
                        • medeekM Offline
                          medeek
                          First look at a hole cut using the new SUBTRACT keyword system:
                          https://aws1.discourse-cdn.com/sketchup/original/3X/f/c/fcfa3a82d747e94b0e665eed71592e96d3eaa409.jpeg
                          Now I just need to set this up for the other various foundation types (ie. stemwall, stemwall steps, strip footings etc...)
                          design.medeek.com
                          • medeekM Offline
                            medeek
                            Version 1.7.0 - 05.09.2021
                            • Added an option for subtractive geometry into the General tab of the Global Settings.
                            • Sub-groups within foundations and footings can be made persistent and "subtractive" by naming these groups to (subtract1, subtract2, subtract3, etc...)
                            http://design.medeek.com/resources/foundationplugin/images/foundation_su78_800.jpg
                            http://design.medeek.com/resources/foundationplugin/images/foundation_su80_800.jpg
                            Interestingly the code to make this happen was staring me in the face for months. I essentially took the "roof connections" complex roof module, changed up the logic slightly, simplified it, and arrived at this new feature/ability.
                            Notice that the subtractive groups cut through the rebar as well as the concrete. Certain other elements such as anchor bolts (groups within groups) are not removed. I may need to give this some additional consideration.
                            I guess we need to make this new feature available with the Truss plugin as well now.
                            design.medeek.com
                            • medeekM Offline
                              medeek
                              Version 1.7.0b - 05.09.2021
                              • Components within foundations can also be made persistent and "subtractive" by naming the component instance to (subtract1, subtract2, subtract3, etc...)
                              design.medeek.com
                              • medeekM Offline
                                medeek
                                Version 1.7.1 - 05.20.2021
                                • Fixed a bug with subbase and slab insulation options for slab-on-grade foundations.
                                design.medeek.com
                                • medeekM Offline
                                  medeek
                                  Version 1.7.2 - 06.03.2021
                                  • Added four additional parameters to the "User Interface" section of the General tab of the global settings. This allows the customization (colors) of the HTML menus and buttons.
                                  design.medeek.com
                                  • medeekM Offline
                                    medeek
                                    Version 1.7.3 - 06.12.2021
                                    • Added a "Regen" context menu item for the following foundation assemblies: Polyline Stemwall, Strip Footing, Interior Bearing.
                                    design.medeek.com
                                    • medeekM Offline
                                      medeek
                                      Version 1.7.4 - 07.10.2021
                                      • Enabled subscription and permanent licensing.
                                      • The License tab of the Global Settings now displays the license type.
                                      design.medeek.com
                                      • medeekM Offline
                                        medeek
                                        Version 1.7.5 - 08.04.2021
                                        • Fixed a bug with the stemwall blockout tool.
                                        design.medeek.com
                                        • medeekM Offline
                                          medeek
                                          Tutorial 10 - Subtractive Geometry (15:45 min.)
                                          design.medeek.com
                                          • medeekM Offline
                                            medeek
                                            Version 1.7.6 - 09.14.2021
                                            • Added an ICF option for polyline stemwalls.
                                            • Added an ICF layer in the Global Settings under the "Layers" tab.
                                            • Fixed a critical bug with custom materials that was caused by the change in the location of the plugin's data sub-folder.
                                            http://design.medeek.com/resources/foundationplugin/images/foundation_su81_800.jpg
                                            http://design.medeek.com/resources/foundationplugin/images/foundation_su82_800.jpg
                                            View model here:
                                            3D Warehouse
                                            (3dwarehouse.sketchup.com)
                                            design.medeek.com
                                            • 18
                                            • 19
                                            • 20
                                            • 21
                                            • 22
                                            • 23
                                            • 20 / 23
