    Foundation Plugin
    451 Posts 15 Posters 580.3k Views 15 Watching
    • medeekM Offline
      medeek
      Version 1.6.7 - 03.07.2021
      • Fixed a bug with brick ledges (and drain pipe) for slab-on-grade foundations.
      Nathaniel P. Wilkerson PE
      Medeek Engineering Inc
      design.medeek.com
      • medeekM Offline
        medeek
        Version 1.6.8 - 03.14.2021
        • Standardized the naming convention of the plugin toolbars.
        design.medeek.com
        • medeekM Offline
          medeek
          Version 1.6.9 - 03.25.2021
          • Fixed a bug with footing offsets when a (polyline) stemwall terminates non-orthogonally.
          http://design.medeek.com/resources/foundationplugin/images/foundation_su76_800.jpg
          design.medeek.com
          • medeekM Offline
            medeek
            Version 1.6.9b - 03.26.2021
            • Fixed a bug with footing extensions (polyline stemwalls) for SketchUp Pro 2021.
            • Enabled hidden edges for polyline stemwalls that terminate non-orthogonally.
            http://design.medeek.com/resources/foundationplugin/images/foundation_su77_800.jpg
            design.medeek.com
            • medeekM Offline
              medeek
              First look at a hole cut using the new SUBTRACT keyword system:
              https://aws1.discourse-cdn.com/sketchup/original/3X/f/c/fcfa3a82d747e94b0e665eed71592e96d3eaa409.jpeg
              Now I just need to set this up for the other various foundation types (ie. stemwall, stemwall steps, strip footings etc...)
              design.medeek.com
              • medeekM Offline
                medeek
                Version 1.7.0 - 05.09.2021
                • Added an option for subtractive geometry into the General tab of the Global Settings.
                • Sub-groups within foundations and footings can be made persistent and "subtractive" by naming these groups to (subtract1, subtract2, subtract3, etc...)
                http://design.medeek.com/resources/foundationplugin/images/foundation_su78_800.jpg
                http://design.medeek.com/resources/foundationplugin/images/foundation_su80_800.jpg
                Interestingly the code to make this happen was staring me in the face for months. I essentially took the "roof connections" complex roof module, changed up the logic slightly, simplified it, and arrived at this new feature/ability.
                Notice that the subtractive groups cut through the rebar as well as the concrete. Certain other elements such as anchor bolts (groups within groups) are not removed. I may need to give this some additional consideration.
                I guess we need to make this new feature available with the Truss plugin as well now.
                design.medeek.com
                • medeekM Offline
                  medeek
                  Version 1.7.0b - 05.09.2021
                  • Components within foundations can also be made persistent and "subtractive" by naming the component instance to (subtract1, subtract2, subtract3, etc...)
                  design.medeek.com
                  • medeekM Offline
                    medeek
                    Version 1.7.1 - 05.20.2021
                    • Fixed a bug with subbase and slab insulation options for slab-on-grade foundations.
                    design.medeek.com
                    • medeekM Offline
                      medeek
                      Version 1.7.2 - 06.03.2021
                      • Added four additional parameters to the "User Interface" section of the General tab of the global settings. This allows the customization (colors) of the HTML menus and buttons.
                      design.medeek.com
                      • medeekM Offline
                        medeek
                        Version 1.7.3 - 06.12.2021
                        • Added a "Regen" context menu item for the following foundation assemblies: Polyline Stemwall, Strip Footing, Interior Bearing.
                        design.medeek.com
                        • medeekM Offline
                          medeek
                          Version 1.7.4 - 07.10.2021
                          • Enabled subscription and permanent licensing.
                          • The License tab of the Global Settings now displays the license type.
                          design.medeek.com
                          • medeekM Offline
                            medeek
                            Version 1.7.5 - 08.04.2021
                            • Fixed a bug with the stemwall blockout tool.
                            design.medeek.com
                            • medeekM Offline
                              medeek
                              Tutorial 10 - Subtractive Geometry (15:45 min.)
                              design.medeek.com
                              • medeekM Offline
                                medeek
                                Version 1.7.6 - 09.14.2021
                                • Added an ICF option for polyline stemwalls.
                                • Added an ICF layer in the Global Settings under the "Layers" tab.
                                • Fixed a critical bug with custom materials that was caused by the change in the location of the plugin's data sub-folder.
                                http://design.medeek.com/resources/foundationplugin/images/foundation_su81_800.jpg
                                http://design.medeek.com/resources/foundationplugin/images/foundation_su82_800.jpg
                                View model here:
                                3D Warehouse
                                (3dwarehouse.sketchup.com)
                                design.medeek.com
                                • medeekM Offline
                                  medeek
                                  Version 1.7.7 - 09.18.2021
                                  • Added an ICF option for stemwall steps.
                                  http://design.medeek.com/resources/foundationplugin/images/foundation_su83_800.jpg
                                  design.medeek.com
                                  • medeekM Offline
                                    medeek
                                    I've been thinking about adding in a Door and Window module to the polyline stemwalls. However, I'm not very familiar with what is common practice as far window and door bucks go.
                                    Any feedback or drawings/details would be greatly appreciated.
                                    https://aws1.discourse-cdn.com/sketchup/original/3X/8/2/82afc53ef76fe018cc253fb8cafc73ff8c416840.jpeg
                                    https://aws1.discourse-cdn.com/sketchup/original/3X/c/f/cf90dbc35179b4ada9a963a6ebb272291eb02cd6.jpeg
                                    https://aws1.discourse-cdn.com/sketchup/original/3X/4/6/46198b175e576ce79f073062822deef0c6d0a10c.jpeg
                                    design.medeek.com
                                    • medeekM Offline
                                      medeek
                                      Now that I'm on the subject of windows it may also be useful to add in some sort of window well feature:
                                      https://aws1.discourse-cdn.com/sketchup/original/3X/4/c/4cbe68e6bb45e0e417077a8ad1184d254d8b5836.jpeg
                                      Window Well Options:
                                      Type: Steel
                                      Shape: Rectangle, Arc, Trapezoid
                                      Width:
                                      Projection:
                                      Depth:
                                      Radius:
                                      Vertical Offset:
                                      design.medeek.com
                                      • medeekM Offline
                                        medeek
                                        Version 1.7.8 - 11.11.2021
                                        • Added interior footings for rectangular and polygon slabs.
                                        • Enabled editing, moving and deleting of interior footings for all slab foundations.
                                        http://design.medeek.com/resources/foundationplugin/images/foundation_su88_800.jpg
                                        Regular slabs now have the same functionality with interior footings as the slab-on-grade foundations.
                                        design.medeek.com
                                        • medeekM Offline
                                          medeek
                                          Version 1.7.9 - 12.24.2021
                                          • Fixed a bug in the slab tool when layers/tags is disabled in the global settings.
                                          I apologize that I did not notice this bug when I added interior footings to the slab module. Typically I enable layers/tags so it managed to sneak past me.
                                          design.medeek.com
                                          • medeekM Offline
                                            medeek
                                            Version 1.8.0 - 02.13.2022
                                            • Fixed a bug with the slab insulation thickness for the SOG draw tool (metric).
                                            • Fixed a bug with the slab and SOG edit menus for slab reinforcement (metric).
                                            http://design.medeek.com/resources/foundationplugin/images2/foundation_su89_800.jpg
                                            design.medeek.com
                                            • 18
                                            • 19
                                            • 20
                                            • 21
                                            • 22
                                            • 23
                                            • 20 / 23
