    Foundation Plugin
    451 Posts 15 Posters 614.6k Views 15 Watching
    • medeekM
      medeek
      Version 1.6.4 - 01.11.2021
      • Added the option for post bases for the (Post & Beam) Interior Bearing tool: BC40, BC60.
      http://design.medeek.com/resources/foundationplugin/images/foundation_su69_800.jpg
      Post base hardware added per customer request.
      Nathaniel P. Wilkerson PE
      Medeek Engineering Inc
      design.medeek.com
      • medeekM
        medeek
        Version 1.6.4b - 01.14.2021
        • Added the following additional post bases to the Interior Bearing tool: ABU44, ABU66.
        http://design.medeek.com/resources/foundationplugin/images/foundation_su70_800.jpg
        Two additional post bases added per customer request.
        design.medeek.com
        • medeekM
          medeek
          When the foundation segment lengths in a polyline stemwall foundation are too short this is what you get (notice the anchor bolt placement):
          https://aws1.discourse-cdn.com/sketchup/original/3X/b/a/ba1443b0e345add3c636dbc40bc9ded984787e76.jpeg
          I'm working up some additional logic to properly deal with anchor bolt placement with short segment lengths.
          design.medeek.com
          • medeekM
            medeek
            Version 1.6.5 - 02.09.2021
            • Fixed a bug with anchor bolt placement for polyline stemwalls.
            • Added an option for a zero depth footing for polyline stemwalls, which eliminates the footing for this foundation type.
            http://design.medeek.com/resources/foundationplugin/images/foundation_su72_800.jpg
            By setting the depth of the footing to zero you can eliminate the footing from a polyline stemwall, so only the stemwall portion of the foundation is drawn. This is per customer request.
            Also the algorithm for anchor bolt placement for polyline stemwalls is greatly improved, however there can always be further improvements, any feedback is always appreciated.
            design.medeek.com
            • medeekM
              medeek
              Version 1.6.6 - 02.12.2021
              • Added logic to the final assembly routine to allow for electrical components (Medeek Electrical) to be retained within all foundation assemblies.
              http://design.medeek.com/resources/foundationplugin/images/foundation_su73_800.jpg
              design.medeek.com
              • medeekM
                medeek
                Version 1.6.7 - 03.07.2021
                • Fixed a bug with brick ledges (and drain pipe) for slab-on-grade foundations.
                design.medeek.com
                • medeekM
                  medeek
                  Version 1.6.8 - 03.14.2021
                  • Standardized the naming convention of the plugin toolbars.
                  design.medeek.com
                  • medeekM
                    medeek
                    Version 1.6.9 - 03.25.2021
                    • Fixed a bug with footing offsets when a (polyline) stemwall terminates non-orthogonally.
                    http://design.medeek.com/resources/foundationplugin/images/foundation_su76_800.jpg
                    design.medeek.com
                    • medeekM
                      medeek
                      Version 1.6.9b - 03.26.2021
                      • Fixed a bug with footing extensions (polyline stemwalls) for SketchUp Pro 2021.
                      • Enabled hidden edges for polyline stemwalls that terminate non-orthogonally.
                      http://design.medeek.com/resources/foundationplugin/images/foundation_su77_800.jpg
                      design.medeek.com
                      • medeekM
                        medeek
                        First look at a hole cut using the new SUBTRACT keyword system:
                        https://aws1.discourse-cdn.com/sketchup/original/3X/f/c/fcfa3a82d747e94b0e665eed71592e96d3eaa409.jpeg
                        Now I just need to set this up for the other various foundation types (ie. stemwall, stemwall steps, strip footings etc...)
                        design.medeek.com
                        • medeekM
                          medeek
                          Version 1.7.0 - 05.09.2021
                          • Added an option for subtractive geometry into the General tab of the Global Settings.
                          • Sub-groups within foundations and footings can be made persistent and "subtractive" by naming these groups to (subtract1, subtract2, subtract3, etc...)
                          http://design.medeek.com/resources/foundationplugin/images/foundation_su78_800.jpg
                          http://design.medeek.com/resources/foundationplugin/images/foundation_su80_800.jpg
                          Interestingly the code to make this happen was staring me in the face for months. I essentially took the "roof connections" complex roof module, changed up the logic slightly, simplified it, and arrived at this new feature/ability.
                          Notice that the subtractive groups cut through the rebar as well as the concrete. Certain other elements such as anchor bolts (groups within groups) are not removed. I may need to give this some additional consideration.
                          I guess we need to make this new feature available with the Truss plugin as well now.
                          design.medeek.com
                          • medeekM
                            medeek
                            Version 1.7.0b - 05.09.2021
                            • Components within foundations can also be made persistent and "subtractive" by naming the component instance to (subtract1, subtract2, subtract3, etc...)
                            design.medeek.com
                            • medeekM
                              medeek
                              Version 1.7.1 - 05.20.2021
                              • Fixed a bug with subbase and slab insulation options for slab-on-grade foundations.
                              design.medeek.com
                              • medeekM
                                medeek
                                Version 1.7.2 - 06.03.2021
                                • Added four additional parameters to the "User Interface" section of the General tab of the global settings. This allows the customization (colors) of the HTML menus and buttons.
                                design.medeek.com
                                • medeekM
                                  medeek
                                  Version 1.7.3 - 06.12.2021
                                  • Added a "Regen" context menu item for the following foundation assemblies: Polyline Stemwall, Strip Footing, Interior Bearing.
                                  design.medeek.com
                                  • medeekM
                                    medeek
                                    Version 1.7.4 - 07.10.2021
                                    • Enabled subscription and permanent licensing.
                                    • The License tab of the Global Settings now displays the license type.
                                    design.medeek.com
                                    • medeekM
                                      medeek
                                      Version 1.7.5 - 08.04.2021
                                      • Fixed a bug with the stemwall blockout tool.
                                      design.medeek.com
                                      • medeekM
                                        medeek
                                        Tutorial 10 - Subtractive Geometry (15:45 min.)
                                        design.medeek.com
                                        • medeekM
                                          medeek
                                          Version 1.7.6 - 09.14.2021
                                          • Added an ICF option for polyline stemwalls.
                                          • Added an ICF layer in the Global Settings under the "Layers" tab.
                                          • Fixed a critical bug with custom materials that was caused by the change in the location of the plugin's data sub-folder.
                                          http://design.medeek.com/resources/foundationplugin/images/foundation_su81_800.jpg
                                          http://design.medeek.com/resources/foundationplugin/images/foundation_su82_800.jpg
                                          View model here:
                                          3D Warehouse
                                          (3dwarehouse.sketchup.com)
                                          design.medeek.com
                                          • medeekM
                                            medeek
                                            Version 1.7.7 - 09.18.2021
                                            • Added an ICF option for stemwall steps.
                                            http://design.medeek.com/resources/foundationplugin/images/foundation_su83_800.jpg
                                            design.medeek.com
                                            • 18
                                            • 19
                                            • 20
                                            • 21
                                            • 22
                                            • 23
                                            • 20 / 23
