    Foundation Plugin
    450 Posts 15 Posters 497.5k Views 15 Watching
    • medeekM Offline
      medeek
      Version 1.7.3 - 06.12.2021
      • Added a "Regen" context menu item for the following foundation assemblies: Polyline Stemwall, Strip Footing, Interior Bearing.
      Nathaniel P. Wilkerson PE
      Medeek Engineering Inc
      design.medeek.com
      • medeekM Offline
        medeek
        Version 1.7.4 - 07.10.2021
        • Enabled subscription and permanent licensing.
        • The License tab of the Global Settings now displays the license type.
        design.medeek.com
        • medeekM Offline
          medeek
          Version 1.7.5 - 08.04.2021
          • Fixed a bug with the stemwall blockout tool.
          design.medeek.com
          • medeekM Offline
            medeek
            Tutorial 10 - Subtractive Geometry (15:45 min.)
            design.medeek.com
            • medeekM Offline
              medeek
              Version 1.7.6 - 09.14.2021
              • Added an ICF option for polyline stemwalls.
              • Added an ICF layer in the Global Settings under the "Layers" tab.
              • Fixed a critical bug with custom materials that was caused by the change in the location of the plugin's data sub-folder.
              http://design.medeek.com/resources/foundationplugin/images/foundation_su81_800.jpg
              http://design.medeek.com/resources/foundationplugin/images/foundation_su82_800.jpg
              View model here:
              3D Warehouse
              (3dwarehouse.sketchup.com)
              design.medeek.com
              • medeekM Offline
                medeek
                Version 1.7.7 - 09.18.2021
                • Added an ICF option for stemwall steps.
                http://design.medeek.com/resources/foundationplugin/images/foundation_su83_800.jpg
                design.medeek.com
                • medeekM Offline
                  medeek
                  I've been thinking about adding in a Door and Window module to the polyline stemwalls. However, I'm not very familiar with what is common practice as far window and door bucks go.
                  Any feedback or drawings/details would be greatly appreciated.
                  https://aws1.discourse-cdn.com/sketchup/original/3X/8/2/82afc53ef76fe018cc253fb8cafc73ff8c416840.jpeg
                  https://aws1.discourse-cdn.com/sketchup/original/3X/c/f/cf90dbc35179b4ada9a963a6ebb272291eb02cd6.jpeg
                  https://aws1.discourse-cdn.com/sketchup/original/3X/4/6/46198b175e576ce79f073062822deef0c6d0a10c.jpeg
                  design.medeek.com
                  • medeekM Offline
                    medeek
                    Now that I'm on the subject of windows it may also be useful to add in some sort of window well feature:
                    https://aws1.discourse-cdn.com/sketchup/original/3X/4/c/4cbe68e6bb45e0e417077a8ad1184d254d8b5836.jpeg
                    Window Well Options:
                    Type: Steel
                    Shape: Rectangle, Arc, Trapezoid
                    Width:
                    Projection:
                    Depth:
                    Radius:
                    Vertical Offset:
                    design.medeek.com
                    • medeekM Offline
                      medeek
                      Version 1.7.8 - 11.11.2021
                      • Added interior footings for rectangular and polygon slabs.
                      • Enabled editing, moving and deleting of interior footings for all slab foundations.
                      http://design.medeek.com/resources/foundationplugin/images/foundation_su88_800.jpg
                      Regular slabs now have the same functionality with interior footings as the slab-on-grade foundations.
                      design.medeek.com
                      • medeekM Offline
                        medeek
                        Version 1.7.9 - 12.24.2021
                        • Fixed a bug in the slab tool when layers/tags is disabled in the global settings.
                        I apologize that I did not notice this bug when I added interior footings to the slab module. Typically I enable layers/tags so it managed to sneak past me.
                        design.medeek.com
                        • medeekM Offline
                          medeek
                          Version 1.8.0 - 02.13.2022
                          • Fixed a bug with the slab insulation thickness for the SOG draw tool (metric).
                          • Fixed a bug with the slab and SOG edit menus for slab reinforcement (metric).
                          http://design.medeek.com/resources/foundationplugin/images2/foundation_su89_800.jpg
                          design.medeek.com
                          • medeekM Offline
                            medeek
                            Version 1.8.1 - 03.02.2022
                            • Enabled window wells for polyline stemwall openings: Rectangle, Arc and Trapezoid.
                            http://design.medeek.com/resources/foundationplugin/images2/foundation_su90_800.jpg
                            http://design.medeek.com/resources/foundationplugin/images2/foundation_su91_800.jpg
                            http://design.medeek.com/resources/foundationplugin/images2/foundation_su92_800.jpg
                            The new updated menu for stemwall openings also shows two other advanced options however I have not yet activated those features yet.
                            design.medeek.com
                            • medeekM Offline
                              medeek
                              Version 1.8.2 - 03.03.2022
                              • Enabled window and door bucks for polyline stemwall openings.
                              http://design.medeek.com/resources/foundationplugin/images2/foundation_su94_800.jpg
                              http://design.medeek.com/resources/foundationplugin/images2/foundation_su95_800.jpg
                              design.medeek.com
                              • medeekM Offline
                                medeek
                                To be honest I've never actually had to deal with a basement door opening in any of my various projects (design or structural) so now I have a bunch of questions.
                                Notice that typical prehung door frame is not deep enough to span two 2x4's and a 1/2" air gap:
                                https://aws1.discourse-cdn.com/sketchup/original/3X/e/6/e6b32e6674f250ad04f27f9c9bd32e7b696119bc.jpeg
                                So how is this typically framed out and trimmed? Are there special order door frames that are deeper that can better accommodate this situation?
                                *Note: I have not shown the brickmould that would trim out the exterior of the door and cover the door buck.
                                design.medeek.com
                                • medeekM Offline
                                  medeek
                                  https://aws1.discourse-cdn.com/sketchup/original/3X/b/3/b3dbd0dd7caffaf1043fb5ee727ad6c972b4eead.jpeg
                                  Something along these lines for an inswinging door (however I have shown the door frame and jamb extension as a single solid for simplicity).
                                  Also note that I have shown the brickmould as 2.25" however 2" is a more common width so there would probably be a 1/4" gap between the brickmould and concrete (caulking).
                                  https://azekexteriors.com/images/products/moulding/moulding-options/AZM-180_Brick_Mould.png
                                  design.medeek.com
                                  • medeekM Offline
                                    medeek
                                    First look at doors installed within the foundation plugin:
                                    https://aws1.discourse-cdn.com/sketchup/original/3X/3/d/3d75eb3c87a3f514328507e63248c000921360de.jpeg
                                    design.medeek.com
                                    • medeekM Offline
                                      medeek
                                      Still a few details to work out with the door and window opening module.
                                      https://aws1.discourse-cdn.com/sketchup/original/3X/4/4/44c3487b8d6aaa6400e27eab04efe1673a76e3ce.gif
                                      design.medeek.com
                                      • gullfoG Offline
                                        gullfo
                                        one thought - maybe create a windows and doors module and only add the bucks for the doors and windows in the foundation. then the windows and doors modules become reusable across your other products. also maybe the option to apply commercial product names / models, etc, even if minimal drawing detail, so the reporting shows up as a commercial product (e.g Pella)
                                        Glenn
                                        http://www.runnel.com
                                        • medeekM Offline
                                          medeek
                                          As I am wrapping up the details on the new window and door module of the foundation plugin it occurred to me that it might also be useful to have a basement entrance option:
                                          https://aws1.discourse-cdn.com/sketchup/optimized/3X/8/f/8f01b795bb20cfce47ee5ca9336b24b77171eb61_2_622x500.jpeg
                                          https://aws1.discourse-cdn.com/sketchup/optimized/3X/1/7/17eaa98114ff3ea5d309006bfb68523e4c06dcbc_2_358x500.jpeg
                                          A whole bunch more parameters with this option (ie. number of steps, landing width and length etc...) but it would actually be quite easy to code.
                                          I would probably have three directional options (Left, Right and Center).
                                          The problem with this option would be much the same as every other option, I need to make it as flexible as possible for it to be useful but not overly complex (too many parameters).
                                          I'm also looking for some plans for this type of entrance to better educate me on what is common practice.
                                          Any thoughts in this regard?
                                          design.medeek.com
                                          • medeekM Offline
                                            medeek
                                            Version 1.8.3 - 03.10.2022
                                            • Enabled the installation of windows and doors for polyline stemwall openings.
                                            • Enabled lumber and pressure treated lumber textures in the Materials tab of the Global Settings.
                                            • Added a door and window opening tool to the Stemwall Opening Toolbar.
                                            • Animation option added to the General tab of the Global Settings.
                                            http://design.medeek.com/resources/foundationplugin/images2/foundation_su102_800.jpg
                                            http://design.medeek.com/resources/foundationplugin/images2/foundation_su101_800.jpg
                                            http://design.medeek.com/resources/foundationplugin/images2/foundation_su97_800.jpg
                                            http://design.medeek.com/resources/images/foundation_opening_su_menu_active.jpg
                                            http://design.medeek.com/resources/foundationplugin/images2/foundation_su105_800.jpg
                                            This is a fairly substantial upgrade to the foundation plugin. Note that windows and doors can only be installed into "polyline" stemwalls, this new feature does not work with the legacy stemwall tool.
                                            design.medeek.com
                                            • 18
                                            • 19
                                            • 20
                                            • 21
                                            • 22
                                            • 23
                                            • 20 / 23
