    [Tips] Animator Tips and Tricks
    Scheduled Pinned Locked Moved Animator Beta
    renderpluginsextensions
    74 Posts 18 Posters 256.9k Views 18 Watching
    • fredo6F Offline
      fredo6
      @manabouttools said:
      Any keyboard shortcuts to zoom the timeline? Or any settings to key in a zoom value to get around this?
      Kent
      Let's take things in order
      1. without any modifier, putting the mouse cursor over the time, can you scroll the timeline?
      2. with Option key pressed, and assuming you have enough tracks, can you scroll the tracks?
      3. with Command key pressed, putting the mouse cursor over the time, what do you get?
      • MANaboutTOOLSM Offline
        MANaboutTOOLS
        I can click-drag with the left button to scroll the time. I added enough tracks to test this.
        1. No. Hovering the curser over the bar and gesturing with the magic mouse (scroll-wheel) zooms the model.
        2. No. Zooms the model
        3. With the mouse hovering over the scroll bar the time reads (for example) 25.5 s. If I press the command key the time then reads 25.50 s. And as above, mouse wheel gesture zooms model.
        I hope this helps. Do you want a screen record?
        Kent
          MANaboutTOOLS
          Here's a screenflow capture...
          • fredo6F Offline
            fredo6
            Do you have a special mouse ?
              MANaboutTOOLS
              No, mouse came with the mac.
              • fredo6F Offline
                fredo6
                Could you open the Ruby Console when you run Animator and scroll with the mousewheel.
                Fredo
                  MANaboutTOOLS
                  Yes,
                  I have Ruby open. No difference.
                  Kent
                  • jujuJ Offline
                    juju
                    Yes,
                    Kent
                    any messages in the ruby console when scrolling?
                      MANaboutTOOLS
                      No. Nothing
                      • fredo6F Offline
                        fredo6
                        @carloshmejia said:
                        First of all thank you for your amazing plugins.
                        I am learning to use Animator. For some reason my original position changed and now it not correspond to my model. Are there a way to reset or change the original position of my clip?
                        Probably not...
                        There is a Positioner facility in Animator (4th icon), allowing you save and restore the position of objects. It is a good idea to save the position of objects before you start building animations.
                        Fredo
                          carloshmejia
                          Fredo, first of all thank you for your amazing plugins.
                          Frequently the objects that I am animating lose its connection with the movements assign to them. Timeline seems OK, when you run the sequence it shows running except the objects don't move. What am I doing wrong?
                          • I Offline
                            itaipeter
                            @fredo6 said:
                            The picto is explicit
                            Hello Fredo, thanks for the extension it's amazing and simple to use.
                            I'm having difficulty using the appearance function. for some reason, it doesn't work as it should.
                            I've messed with it in this project and suddenly as working the function refused to work with disappearing components.i've made a short video to explain.
                            thanks
                            • fredo6F Offline
                              fredo6
                              Your video cannot be accessed. Maybe it is private.
                              • I Offline
                                itaipeter
                                it should work now. thank you
                                • fredo6F Offline
                                  fredo6
                                  I am not sure I understand the problems from the video.
                                  Maybe posting the model would help so that I can have a look.
                                  Fredo
                                  • I Offline
                                    itaipeter
                                    update:
                                    I've created a new file for trying the disappear apparition option and it worked perfectly.
                                    somehow it's my file that is not corresponding with the plugin. I tried to delete all layers and purge the file but it didn't help.
                                    here is another video to show that. (in this one the animator doesn't even react)
                                    thanks,
                                    itay
                                      dennis1313
                                      Can I create a custom easing curve? Dennis
                                        dennis1313
                                        Let's start with this - Your Animator product is awesome.....
                                        I do have a question - can the user create their own custome "easing" timeline? I have a need for a custom timeline for a project i am working on. Have you thought about an "easing" timeline that doesn't go from 0-to-1 but from 0 to some other value. I am thinking of something like a two cycle sinewave or a path that starts at zero and damps out at the end to .5 Think of the things you could move around with that - the possibilities are almost endless. You can do almost anything with the tools you have provided but a custom easing would allow MANY things to be done in one step that now take many steps.
                                        dennis1313
                                        • fredo6F Offline
                                          fredo6
                                          Thanks for the positive appreciation.
                                          @dennis1313 said:
                                          I do have a question - can the user create their own custom "easing" timeline?
                                          This is in my plan, and more generally, to provide a framework to vary all variables through time. I mainly need to build a GUI for that.
                                          Are you interested in custom easing for movement or for cameras?
                                            jani151
                                            @fredo6 said:
                                            @wanniya said:
                                            Is there any way to work with section plane animation?
                                            This is coming in a new release tomorrow.
                                            Fredo
                                            [attachment=1:3ljdz6fn]<!-- ia1 -->Animator - Apparition.gif<!-- ia1 -->[/attachment:3ljdz6fn]
                                            [attachment=0:3ljdz6fn]<!-- ia0 -->Animator - Apparition 2.gif<!-- ia0 -->[/attachment:3ljdz6fn]
                                            Hi Guys, Can you guide me to create the animation using section plane along with the path in different SketchUp styles [i.e x-ray, hidden line, wireframe, etc]. Actually, I want to create an animation of water flow through the pipe in sketchup[similar to blender].
                                            Jani
                                            • 2 / 4
