    Welcome to Animator Beta Testers
    Scheduled Pinned Locked Moved Animator Beta
    renderpluginsextensions
    50 Posts 20 Posters 178.2k Views 20 Watching
    • B
      barakuda
      One more problem. When I save my animation and exit Clip Editor, the Clip player and Editor cannot be opened again when I click on the icons. I need to restart SU8 to open Editor or Player. I use SU8 because I am still running on Windows XP and I do not plan to buy new system for years yet.
      • T
        Treadshot A1
        @barakuda
        As a fellow user of SU8 (albeit on Win8 and Win10), the Animator plugin Clip Editor sometimes not opening does happen. I forget exactly where in Fredo's (rather excellent) documentation it says this, but if clicking the Clip Editor icon results in a system sound effect, you can double click the icon to open Animator (instead of closing and reopening Sketchup). Dont remember why, but double clicking works for me.
        • ShantaS
          Shanta
          I've just started using Animator, so I apologize if this is a total noob mistake. The whole rolling cart in the animation is one group, with the rolling base (that the chair is on) and the doors are sub-groups. The final moves in the video are to move the whole group up the ramp, and then a second pivot to lower the uphill part of the cart so that it approximates following the curve of the ramp. When the model rotates, however, you'll notice that the rolling base moves independently and becomes misaligned. I'm not sure what I might have done wrong. Im running Make 17.2.2554 and Animator was updated 7/9/2017. I am on a Mac.
            @shanta said:
            ...you'll notice that the rolling base moves independently and becomes misaligned. I'm not sure what I might have done wrong...
            Hard to decipher without the file to look at.
            • ShantaS
              Shanta
              Hope this works:
              https://www.dropbox.com/s/s63r69mm2gh0k3g/20170719%20Ginormous%20Santa%20Chair%20Crate%20Ani%202.skp
              Dropbox has changed so much, I'm not 100% sure how to use it anymore.
                You need to share both the .skp and .animator file.
                Animator writes all animation data to the .animator file.
                • ShantaS
                  Shanta
                  Oops! I did mention I was new to this, right πŸ˜‰
                  Dropbox - Error - Simplify your life
                  (www.dropbox.com)
                  • fredo6F
                    fredo6
                    Actually, Animator writes the information within the model. The .animator file is a backup, just in case (if ever you undo, since the attributes writing is an undoable operation).
                    Fredo
                      Sorry. My fault.
                      I spend some time looking at those .animator file to see if we can implement them into animated browser embeds.
                      Also I was hoping those files could some be imported into larger scenes to animation to objects.
                      • fredo6F
                        fredo6
                        The .animator file is purely technical, in case something happen to the model.
                        I was thinking also to have an animation specification file, that would be easier to build and in clear language to specify an animation by the sequences and time line (like "Object1 3.0 4.2 Rotate 90 (1, 0, 0)" for a rotation of 90 degrees around the X axi, starting at 3s and for a duration of 4.2s, applied to Object1.
                        Not sure however if this would be useful and what we could do with it. Somehow, there is a concept of parametric composed animation, which could probably be make more generic with this approach.
                        Fredo
                        • 3 / 3
