    Correct workflow to register new geometry as quads
    Scheduled Pinned Locked Moved SUbD
    renderpluginsextensions
    9 Posts 4 Posters 9.8k Views 4 Watching
    • N Offline
      numerobis
      I would like to know how to register normal geometry as quads, when i add new geometry to an existing object. When i select only the new lines or faces it always produces a completely new object, messing up my topology.
      I think i'm missing something... πŸ˜•
        Can you post an example model - along with a screenshot?
        • N Offline
          numerobis
          http://abload.de/img/quads01qbaad.jpg
          http://abload.de/img/quads027fa1m.jpg
          http://abload.de/img/quads03g4b8s.jpg
          πŸ˜„
          The correct geometry has been converted from a wireframe using the "Convert wireframe to quads"-tool and the messed up parts (subdivided tris) with the smoothed edges visible in the selection have been added or edited later.
          (file format skp2015)
          quads_2015.skp
            If you have a mesh with quads similar to Sandbox Tools: two triangles with soft+smooth then use the Sandbox Tools Quads to QFT Quads functions.
            QFT quads are similar to Sandbox Tools quads, but it also have Cast Shadow turned off.
            • N Offline
              numerobis
              Thanks! It's working now. I thought i had tried this before... i don't know. Now everything is ok. Thanks again for the quick response! πŸ˜„
              http://abload.de/img/quads04lssx6.jpg
                Nice result! And a great use of SUbD.
                • pbacotP Offline
                  That's some fancy terrain there!
                  • N Offline
                    numerobis
                    Thanks Rich. The early stages of a new project. Still a long way to go. But it's a totally new experience to do the subd work in SU. Until now i have done these things in max. I really hope that SU can be improved regarding polycount and geometry processing - this could be really ground breaking in combination with subd and an improved poly modeling workflow! (and maybe other non-destructive modeling tools, parametric modeling, etc. ...just dreaming πŸ˜‰ )
                    The next application site for SUbD will be the displacement geometry of the wall and some metal sheets on the roof πŸ˜‰
                    @pbacot yes, much space to fill with vegetation. 😲 . πŸ’š
                      I hope you post images of your progress. Very nice to see how people use the tool.
