    [Plugin] Animator - v4.6a - 18 Dec 25
    Scheduled Pinned Locked Moved Animator Beta
    renderpluginsextensions
    602 Posts 120 Posters 2.3m Views 120 Watching
    • R
      rong1937
      Hope to support Enscape render
      • C
        chals375
        Hello.
        First of all, I hope you understand the awkwardness of English.
        Writing on the translator.
        I used the animator 2.1a version and thea render v2.
        I was using it well, but after updating the animator to 2.3c, I can't turn it on.
        When I press the render button, the word "no clip defined in model" appears.
        So do files with dozens of clips.
        Everything went dead.
        I want to use version 2.1a again, but it is not possible because the period of use has expired.
        If I set my computer time to the past, I can use it, but because thea render license is not available, rendering is not possible.
        How shall I do it?
        Please help me.T.T
        • fredo6F
          fredo6
          @chals375
          1. First of all, can you play the animation interactively within Animator
          2. Can you generate the video in natural mode (No rendering by Thea)?
          3. Can you open the Ruby console while you are in Animator, to see i there are errors showing.
          Finally, the best would be that you post or PM me your model so that I can have a closer look.
          Fredo
          PS: do not play with the clock of your PC, as you can have many other bad side effects on other applications.
          • T
            Tranthanhvu
            Can you help me.
            https://youtu.be/eLUiA4i01Yo
            • fredo6F
              fredo6
              @tranthanhvu said:
              Can you help me.
              For the rotation, you need to select the two arms objects, instead of the components which includes both arms.
              • C
                Comial
                @fredo6 said:
                @chals375
                I'm having the same issue since upgrading to v2.3. In response to your questions to @chals375
                1. Yes, I can play the animation without any problems in Animator
                2. Yes, I can generate the video in natural mode. Also, Thea render's animation tab can render Sketchup default animations but does not open a dialog when selecting Animator as the plugin.
                3. Ruby console does not display any errors when trying to render from Thea Render
                Rendering with Thea works just fine if I initiate it from Animator, but the only reason I want to render from Thea is so that I have control over what format the exported image sequence is in. If there is a way to do that from Animator then that would also solve my problem.
                PS. I love all your plugins. Thank you for all your contributions to the Sketchup community!!
                • fredo6F
                  fredo6
                  I fixed the issue with the generation from Thea render in Animator 2.4a.
                  Please advise if this is ok for your now.
                  • fredo6F
                    fredo6
                    New Release: Animator - v2.4a - 10 Jan 19
                    Requirement: LibFredo6 v8.7e
                    Minor release
                    • Extension of validity
                    • Fix a problem preventing to generate the video from Thea render
                    See plugin home page of Animator for Download of RBZ from the PluginStore.
                    See Main Post of the Animator thread for more information.
                    • C
                      Comial
                      It does! Thank you, this is really great. I appreciate you providing such great support for your plugins.
                      • OxerO
                        Oxer
                        It works fine on Mac too. 👍
                        http://www.oxervision.blogspot.com/
                        • fredo6F
                          fredo6
                          New Release: Animator - v2.4b - 12 Mar 19
                          Minor release
                          • Some bug fixes
                          • A
                            Aaronyee
                            Minor release
                            • Some bug fixes
                            Hi, fredo. I want to realize how version of thea render can support v2.4b animator. Is the thea render v2.0 ok? Thank you for help me.
                            • fredo6F
                              fredo6
                              I did not test with this version of Thea 2.0. I only have v1.5 on my laptop.
                              So if you have it already, please make a test on a simple animation, opening the Ruby Console to check if there are error messages (normally you should only see traces of the execution).
                              For Thea, make sure you use a Presto method, not interactive, with a reasonable sample/px, typically 10 to 20. This keeps the rendering under a reasonable amount of time.
                              • fredo6F
                                fredo6
                                New Release: Animator - v2.4c - 14 May 19
                                Requirement: LibFredo6 v8.7f
                                Minor release
                                • M
                                  meapiper
                                  Can I use this extension with Maxwell Render to create a rendered video? I believe I need to creates multiple scenes to bring into Maxwell.
                                  • fredo6F
                                    fredo6
                                    I have no API to Maxwell, so it is not supported in Direct mode by Animator.
                                    And I doubt that Maxwell support the reverse mode (as Thea does), because they would have contacted me.
                                    So short answer is NO.
                                    Fredo
                                    • fredo6F
                                      fredo6
                                      New Release: Animator - v2.4d - 14 Jun 19
                                      Minor release
                                      • Added a permanent FFMeg button to be able to change the location of the FFmpeg executable
                                      • fredo6F
                                        fredo6
                                        New Release: Animator - v2.5a - 11 Sep 19
                                        Requirement: LibFredo6 v9.1b
                                        Minor release
                                        • fixed some bug around video generation
                                        • Y
                                          yonofun
                                          Any advice concerning ffmpeg video download. I followed the link and the FFmpeg.org pdf directions but didn't find the exact steps available and got into a baited ads trap and downloaded similarly labeled ffmpeg files that were unrelated. I successfully created an edit in animator and would love to get it to mp4.
                                          • fredo6F
                                            fredo6
                                            For Mac, here is the download page.
                                            Then I suggest you pick the latest build of FFmpeg for Mac (dated 3 Jan 2020).
                                            https://ffmpeg.zeranoe.com/builds/macos64/static/ffmpeg-20200102-81172b5-macos64-static.zip
                                            Just extract the ffmpegexecutable in the ** bin**subfolder and put it in a known place where you will point to from Animator.
