    MSPhysics tests and questions
    104 Posts 21 Posters 52.7k Views 21 Watching
      aldoz8
      Hi, I hope I am in the right place to put my question..
      I am developing a quadruped robot:
      https://www.youtube.com/watch?v=bt_8X4lYDGY
      So I am using SketchUP make 2017 + MSPhysics to test different settings of my robot and different scenarios :
      https://www.youtube.com/watch?v=fBTxNx2UAT8
      Just cool! but I have a little problem:
      In Sketchup I am using 8 servos, 2 for each legs and I get (as you can see in the second video) 8 MSPhysics sliders to move my 8 servos.
      Ok, but I would to have another slider that let me to move, for example, servos 3,4 and 5.
      So I would to obtain my actual 8 sliders + 1 new sliders that move servos 3,4 and 5.
      Obviously I will be able to move servo 3,4 and 5 using both the old 3,4&5 sliders and the new one slider too!
      So I will obtain :
      SLIDER 1 = servo 1
      SLIDER 2 = servo 2
      SLIDER 3 = servo 3
      SLIDER 4 = servo 4
      SLIDER 5 = servo 5
      SLIDER 6 = servo 6
      SLIDER 7 = servo 7
      SLIDER 8 = servo 8
      SLIDER 9 = servo 3, 4, 5
      How to do that?
      Thank you all in advance!
      • ecatiE Offline
        ecati
        aldoz8
        If you can not find a solution, do you share the skp file?
          Jens3D
          I downloaded MS Physics plugin after seeing a demo from Justin's SketchUpEssentials. Looks really cool, but is it really compatible with Mac? It says it is, but following the tutorials on Youtube, all the setup modes seem to function, but when it comes to implementation, the model disappears, and a counter on the bottom left hand of the screen counts ‘Frame’, Time and FPS. Goes on forever! Is this normal?
          Box, on the SketchUp Forum looked at the model for me on a PC, and then had similar issues, so suggested that this is not necessarily a Mac issue.
          I am setting up a mobile (to hang above a baby's cot) with rotating discs balanced on a simple rod. Each disc then has to be able to swivel on its vertical axis, each group would then too, and then including the main arm holding all the groups has to be able to swivel on its axis.
          Can Anybody offer some advice.
          Jens
          • F Offline
            faust07
            Judging from the description, objects outside the window seem to fall into the bottomless state and cause the SketchUp clipping problem. All groups or components that should not be simulated should be set to "Ignore" or "Static". This can be done in the MSP user interface or in the MSP context menu. A sample SUp model is always very helpful for more precise assessments.
            • F Offline
              faust07
              @ aldoz8:
              There is no easy solution for this after my first tests. Each slider can directly control only one joint (and several identical copies of the joint) at a time. It is possible to use scripts to query the input values from a slider and pass them on to the required other joints. Unfortunately, I don't have time for an example. Sorry!
              • ecatiE Offline
                ecati
                This is a message sent by mistake. It needs to be deleted. I did not delete it. Sorry.
                  tecnozati
                  Hello everyone, to see if a charitable soul can help me out.
                  Using MSPhysics script I want to get:
                  1 know the position of a servo join
                  2 move the servo without using “get_var ()” as controller
                  I wish to animate a mechanism with scripting, I would greatly appreciate code examples (I find it almost impossible to find them)
                  Greetings and many thanks
                  • F Offline
                    faust07
                    There is a link to the Scripting Documentation in the first post of Anton_S regarding his MSPhysics plugin: https://sketchucation.com/forums/viewtopic.php?f=323&t=56852
                      Anton_S
                      tecnozati,
                      Yeah, the docs do not have enough coding examples. But I intended to fix that someday.
                      To get the position of a servo joint from a script field, you will first need to know the name/id of the joint, which is displayed in UI when you select the joint. Then you can write the following code:
                      onStart {
                        @j = simulation.find_joint_by_name("569422")
                      onTick {
                        # Set desired angle
                        if (key(' ') == 1)
                          @j.controller = 100.degrees
                        else
                          @j.controller = 0
                        # Get current angle
                        simulation.log_line @j.cur_angle.radians
                      You can refer to servo docs for more functionality: https://www.rubydoc.info/github/AntonSynytsia/MSPhysics/MSPhysics/Servo
                      Anton
                        tecnozati
                        😮 😮 Thank you, thank you, thank you! The head was going to burn me!
                        And above all, thanks for Msphysics! 👍
                          tecnozati
                          Again, thanks Anton, I have managed to give life to my creature 😉
                            Anton_S
                            Dude great job!!!
                            • P Offline
                              pppppppppppppppppppppppppppppluginuser
                              I have made a simple car and set a controller for the servos and motors but they don't respond. Any clue on how to fix? (controls are the arrow keys)
                              Motor ui
                              Servo ui
                              Simple car
                              Car Simulation.skp
                              • ecatiE Offline
                                ecati
                                If you upload the skp file, we can have a look.
                                • ecatiE Offline
                                  ecati
                                  It works perfectly. I didn't see any problem.
                                  Click on the picture for animation.
                                  • P Offline
                                    It might be something with my wrong with either my computer, msphysics, or sketchup because I start the simulation and the car starts driving by itself and doesn't respond to the the arrow keys.
                                    Also is there a plugin that downloads the simulation recording?
                                    • P Offline
                                      Never mind I just needed to uninstall MS physics and AMS library and get the extensions from the SketchUp extension warehouse. Just a final question, what plugin downloads the simulation recording?
                                      • BoxB Offline
                                        A small hint, I suspect nobody has bothered to reply or read your posts due to your spam style user name. I only came here by accident.
                                        Like most things in life there is 'Unique' and there is 'wtf'. try being unique.
                                          I fixed it to be less obnoxious.
                                            DanyLecocq
                                            Bonjour, je n'ai également pas la possibilité de commander les animations (Thruster, Emetter, etc..) avec le clavier de mon portable, je ne suis pas le premier à relever ce problème apparemment et je ne trouve pas la solution. Avez-vous une idée svp ?
                                            • 6
                                            • 5 / 6
