    MSPhysics tests and questions
    104 Posts 21 Posters 53.4k Views 21 Watching
    • F Offline
      faust07
      The script works in this form good for a few objects. The falling pieces of an iceberg touch each other and produce emitting objects everywhere in the air in mass. SketchUp crashes then ... It would be good if I could use instead of .each a certain surface for the contact. Another problem is that all splashes are created simultaneously. Therefore a script for a random time point of emitting would be very helpful. I'll try this...
      • F Offline
        faust07
        After I have tried several things and have not come to any satisfactory result, I have a suggestion:
        It would be great to have a kind of "Penetration Joint" or function (onPenetration):
        to connect it to one or more noncollidable objects (or faces).
        The properties of objects that penetrate this noncollidable object are to be evaluated continuously:
        name, mass, velocity, position of the touch/penetration, direction of movement, etc..
        In other words, please bring back the old onTouch bug as an independent function!
        • F Offline
          faust07
          I finally found a satisfactory solution for my imitated water fun in MSPhysics v1.0.2:
          A combination of a surface with onTouch function (water surface) and an evaluation of velocity.lenght (onTouching event) and contact.points of in the area of this surface moving objects.
          Anton, thank you for the examples, hints and help!
          • F Offline
            faust07
            Hi Anton,
            I want to bring more variation into the particles of the orca's breathing air. My intended scaling function does not show any reaction. What can be the cause? Can't scripted emitted objects not be scaled during simulation?
            for i in 1..20 do
              tra = this.group.transformation
              dir_zsf = tra.zaxis
              dir_zsf.length = 290 + rand(100)
              fount_p = Geom;;Point3d.new(0.0 + rand(-5..5), 2.9.m + rand(20), 0.5.m + rand(15)) # y-pos of fountain
              point = fount_p.transform(tra)
              transl = Geom;;Transformation.new(point)
              scalin = Geom;;Transformation.scaling point, rand(1..5)
              transf = scalin * transl
              if point.z > 0.1.m
                body = simulation.emit_body(@@splashF, transf, dir_zsf, 0.2)
                body.collidable = false
            • F Offline
              faust07
              The next step is to find a solution to bridge the gaps that arise between the moving parts of the objects at the pivot points.
              I think of flexible triangular or square surfaces, which I can clamp between the boundary lines of the moving parts. For this I have to immerse deeper into the Ruby programming of SketchUp geometry ...
              If someone from the experts has ideas, I would be very happy.
              and how it looks like rendered with indigo RT
              • F Offline
                faust07
                Hello Anton, here an other little question:
                When I let run "Replay" with active hidden geometry all emitted objects remain in there last position still after there lifetime. Is this normal? Could that explain why Twilight takes longer and longer to render the images during the simulation?
                  aldoz8
                  Hi, I hope I am in the right place to put my question..
                  I am developing a quadruped robot:
                  https://www.youtube.com/watch?v=bt_8X4lYDGY
                  So I am using SketchUP make 2017 + MSPhysics to test different settings of my robot and different scenarios :
                  https://www.youtube.com/watch?v=fBTxNx2UAT8
                  Just cool! but I have a little problem:
                  In Sketchup I am using 8 servos, 2 for each legs and I get (as you can see in the second video) 8 MSPhysics sliders to move my 8 servos.
                  Ok, but I would to have another slider that let me to move, for example, servos 3,4 and 5.
                  So I would to obtain my actual 8 sliders + 1 new sliders that move servos 3,4 and 5.
                  Obviously I will be able to move servo 3,4 and 5 using both the old 3,4&5 sliders and the new one slider too!
                  So I will obtain :
                  SLIDER 1 = servo 1
                  SLIDER 2 = servo 2
                  SLIDER 3 = servo 3
                  SLIDER 4 = servo 4
                  SLIDER 5 = servo 5
                  SLIDER 6 = servo 6
                  SLIDER 7 = servo 7
                  SLIDER 8 = servo 8
                  SLIDER 9 = servo 3, 4, 5
                  How to do that?
                  Thank you all in advance!
                  • ecatiE Offline
                    ecati
                    aldoz8
                    If you can not find a solution, do you share the skp file?
                      Jens3D
                      I downloaded MS Physics plugin after seeing a demo from Justin's SketchUpEssentials. Looks really cool, but is it really compatible with Mac? It says it is, but following the tutorials on Youtube, all the setup modes seem to function, but when it comes to implementation, the model disappears, and a counter on the bottom left hand of the screen counts โ€˜Frameโ€™, Time and FPS. Goes on forever! Is this normal?
                      Box, on the SketchUp Forum looked at the model for me on a PC, and then had similar issues, so suggested that this is not necessarily a Mac issue.
                      I am setting up a mobile (to hang above a baby's cot) with rotating discs balanced on a simple rod. Each disc then has to be able to swivel on its vertical axis, each group would then too, and then including the main arm holding all the groups has to be able to swivel on its axis.
                      Can Anybody offer some advice.
                      Jens
                      • F Offline
                        faust07
                        Judging from the description, objects outside the window seem to fall into the bottomless state and cause the SketchUp clipping problem. All groups or components that should not be simulated should be set to "Ignore" or "Static". This can be done in the MSP user interface or in the MSP context menu. A sample SUp model is always very helpful for more precise assessments.
                        • F Offline
                          faust07
                          @ aldoz8:
                          There is no easy solution for this after my first tests. Each slider can directly control only one joint (and several identical copies of the joint) at a time. It is possible to use scripts to query the input values from a slider and pass them on to the required other joints. Unfortunately, I don't have time for an example. Sorry!
                          • ecatiE Offline
                            ecati
                            This is a message sent by mistake. It needs to be deleted. I did not delete it. Sorry.
                              tecnozati
                              Hello everyone, to see if a charitable soul can help me out.
                              Using MSPhysics script I want to get:
                              1 know the position of a servo join
                              2 move the servo without using โ€œget_var ()โ€ as controller
                              I wish to animate a mechanism with scripting, I would greatly appreciate code examples (I find it almost impossible to find them)
                              Greetings and many thanks
                              • F Offline
                                faust07
                                There is a link to the Scripting Documentation in the first post of Anton_S regarding his MSPhysics plugin: https://sketchucation.com/forums/viewtopic.php?f=323&t=56852
                                  Anton_S
                                  tecnozati,
                                  Yeah, the docs do not have enough coding examples. But I intended to fix that someday.
                                  To get the position of a servo joint from a script field, you will first need to know the name/id of the joint, which is displayed in UI when you select the joint. Then you can write the following code:
                                  onStart {
                                    @j = simulation.find_joint_by_name("569422")
                                  onTick {
                                    # Set desired angle
                                    if (key(' ') == 1)
                                      @j.controller = 100.degrees
                                    else
                                      @j.controller = 0
                                    # Get current angle
                                    simulation.log_line @j.cur_angle.radians
                                  You can refer to servo docs for more functionality: https://www.rubydoc.info/github/AntonSynytsia/MSPhysics/MSPhysics/Servo
                                  Anton
                                    tecnozati
                                    ๐Ÿ˜ฎ ๐Ÿ˜ฎ Thank you, thank you, thank you! The head was going to burn me!
                                    And above all, thanks for Msphysics! ๐Ÿ‘
                                      tecnozati
                                      Again, thanks Anton, I have managed to give life to my creature ๐Ÿ˜‰
                                        Anton_S
                                        Dude great job!!!
                                          pppppppppppppppppppppppppppppluginuser
                                          I have made a simple car and set a controller for the servos and motors but they don't respond. Any clue on how to fix? (controls are the arrow keys)
                                          Motor ui
                                          Servo ui
                                          Simple car
                                          Car Simulation.skp
                                          • ecatiE Offline
                                            ecati
                                            If you upload the skp file, we can have a look.
                                            • 5 / 6
