    [Plugin] S4u Scale Definition
    12 Posts 6 Posters 8.4k Views 6 Watching
    • hdpvH Offline
      hdpv
      S4u Scale Definition v1.2.0
      Set Scale Definitions for Components or Groups.
      http://extensions.sketchup.com/en/content/s4u-scale-definition
      http://sketchucation.com/pluginstore?pln=s4u_scale_definition
      Usage: Extensions -> Suforyou or Right Click
      Suforyou
      http://www.sketchupforyou.com
      • asimonasA Offline
        asimonas
        Didn't get it what this plugin does? Bit more info or quick video tutorial would be great! Thanks.
        • asimonasA Offline
          asimonas
          It works with simple components or groups, however when I scale my dynamic components it doesn't work.
          I have attached dynamic component:
          Cabinet Base B.skp
          Could you to take a look and try to figure out why is it so?
          After all its superb plugin, can not figure out why sketchup doesn't have this by default.
          Thanks S4U!
          • hdpvH Offline
            hdpv
            Dimension of dynamic component follow its parametrics,not follow its definition.
            Suforyou
            • G Offline
              Guilherme Bera
              Thank you for your effort in make this plugin that has been quite useful for me.
              I'm just a bit upset, because it doesn't have a toolbar. So I'd be glad if you could modify your plugin just enough to support toolbar. I could do it by myself, but your script is crypted.
              Then a simple way to add the toolbar support is like TIG commented in another topic (bit.ly/29PAk6T😞
              An example of the menu making command is:
              unless file_loaded?(__FILE__)
              >    cmd = UI;;Command.new("SomeCommandName"){ SomeCommand.new() }
              >    UI.menu("Plugins").add_item(cmd)
              > ### START - ADD TOOLBAR HERE...
              > ### END -   ADD TOOLBAR HERE
              >    file_loaded(__FILE__)
              > end
              If it's a 'Tool' the CMD setup is slightly different...
              An example to use that within a toolbar is this additional code added between the ### markers:
              cmd.tooltip = "SomeCommandName"
              > cmd.status_bar_text = "SomeText"
              > cmd.small_icon = File.join("SomeCommandFolder/ImagesFolder", 'icon-24.png')
              > cmd.large_icon = File.join("SomeCommandFolder/ImagesFolder", 'icon-32.png')
              > toolbar = UI;;Toolbar.new("SomeCommandName")
              > toolbar.add_item(cmd)
              > toolbar.show if toolbar.get_last_state.abs == 1 # TB_VISIBLE/NEVER
              Note how addition properties are needed for the cmd to be used in a toolbar.
              The path to the button icons and their names is up to you...
              And I attached icons that I created for the toolbar, if it can be helpful.
              small icon
              large icon
              • hdpvH Offline
                hdpv
                I have updated it.
                You can replace your icon if you want.
                Suforyou
                • JQLJ Offline
                  JQL
                  hdpv, what would you feel about adding a reset scale for multiple components too?
                  Thanks in advance!
                  www.casca.pt
                  Visit us on facebook!
                    Installed update dated Jan 5, 2021 in SketchUp 2021. I get the following load error on start.
                    Error Loading File s4u_scale_definition.rb Error: #<NoMethodError: undefined methodcopyright=' for nil:NilClass>
                    C:/Users/Orbital/AppData/Roaming/SketchUp/SketchUp 2021/SketchUp/Plugins/s4u_scale_definition.rb:14:in <module:S4u_Scale_Definition>' C:/Users/Orbital/AppData/Roaming/SketchUp/SketchUp 2021/SketchUp/Plugins/s4u_scale_definition.rb:4:in module:S4U'
                    C:/Users/Orbital/AppData/Roaming/SketchUp/SketchUp 2021/SketchUp/Plugins/s4u_scale_definition.rb:3:in <top (required)>'
                      Surprisingly the extension's code is very malformed.
                      This extension's RB loader file contains the following errors...
                      ext = SketchupExtension.new(('s4u-' + Strings.GetString(TOOL)),File.join(NAME,(NAME + "_loader")))
                      @ext.copyright= 'Huynh Duong Phuong Vi'
                      @ext.creator =  'Suforyou'
                      ext.version = '1.2.2'
                      ext.description = Strings.GetString("Set Scale Definitions for Objects.")
                      Sketchup.register_extension ext, true
                      Should read thus:
                      @ext = SketchupExtension.new(('s4u-' + Strings.GetString(TOOL)),File.join(NAME,(NAME + "_loader")))
                      @ext.version = '1.2.2'
                      @ext.description = Strings.GetString("Set Scale Definitions for Objects.")
                      Sketchup.register_extension(@ext, true)
                      You can edit the RB loader and it will work - however, it will break the 'signing' so the Loading Policy must be Unrestricted - at least until the author posts/signs a fixed RBZ...
                      It can never have worked during the author's testing pre-RBZ-making !? 😲
                        That what I would think, too. Made me wonder why he updated it both here and in the Extension Warehouse.
                        • hdpvH Offline
                          hdpv
                          Sorry! I fixed it.
                          Suforyou
                            Thank you. Your ScaleTool has the same problem.
