    [Plugin] S4u Scale Definition
    12 Posts 6 Posters 8.6k Views 6 Watching
    • asimonasA Offline
      asimonas
      It works with simple components or groups, however when I scale my dynamic components it doesn't work.
      I have attached dynamic component:
      Cabinet Base B.skp
      Could you to take a look and try to figure out why is it so?
      After all its superb plugin, can not figure out why sketchup doesn't have this by default.
      Thanks S4U!
      • hdpvH Offline
        hdpv
        Dimension of dynamic component follow its parametrics,not follow its definition.
        Suforyou
        http://www.sketchupforyou.com
          Guilherme Bera
          Thank you for your effort in make this plugin that has been quite useful for me.
          I'm just a bit upset, because it doesn't have a toolbar. So I'd be glad if you could modify your plugin just enough to support toolbar. I could do it by myself, but your script is crypted.
          Then a simple way to add the toolbar support is like TIG commented in another topic (bit.ly/29PAk6T😞
          An example of the menu making command is:
          unless file_loaded?(__FILE__)
          >    cmd = UI;;Command.new("SomeCommandName"){ SomeCommand.new() }
          >    UI.menu("Plugins").add_item(cmd)
          > ### START - ADD TOOLBAR HERE...
          > ### END -   ADD TOOLBAR HERE
          >    file_loaded(__FILE__)
          > end
          If it's a 'Tool' the CMD setup is slightly different...
          An example to use that within a toolbar is this additional code added between the ### markers:
          cmd.tooltip = "SomeCommandName"
          > cmd.status_bar_text = "SomeText"
          > cmd.small_icon = File.join("SomeCommandFolder/ImagesFolder", 'icon-24.png')
          > cmd.large_icon = File.join("SomeCommandFolder/ImagesFolder", 'icon-32.png')
          > toolbar = UI;;Toolbar.new("SomeCommandName")
          > toolbar.add_item(cmd)
          > toolbar.show if toolbar.get_last_state.abs == 1 # TB_VISIBLE/NEVER
          Note how addition properties are needed for the cmd to be used in a toolbar.
          The path to the button icons and their names is up to you...
          And I attached icons that I created for the toolbar, if it can be helpful.
          small icon
          large icon
          • hdpvH Offline
            hdpv
            I have updated it.
            You can replace your icon if you want.
            Suforyou
            • JQLJ Offline
              JQL
              hdpv, what would you feel about adding a reset scale for multiple components too?
              Thanks in advance!
              www.casca.pt
              Visit us on facebook!
                Installed update dated Jan 5, 2021 in SketchUp 2021. I get the following load error on start.
                Error Loading File s4u_scale_definition.rb Error: #<NoMethodError: undefined methodcopyright=' for nil:NilClass>
                C:/Users/Orbital/AppData/Roaming/SketchUp/SketchUp 2021/SketchUp/Plugins/s4u_scale_definition.rb:14:in <module:S4u_Scale_Definition>' C:/Users/Orbital/AppData/Roaming/SketchUp/SketchUp 2021/SketchUp/Plugins/s4u_scale_definition.rb:4:in module:S4U'
                C:/Users/Orbital/AppData/Roaming/SketchUp/SketchUp 2021/SketchUp/Plugins/s4u_scale_definition.rb:3:in <top (required)>'
                  Surprisingly the extension's code is very malformed.
                  This extension's RB loader file contains the following errors...
                  ext = SketchupExtension.new(('s4u-' + Strings.GetString(TOOL)),File.join(NAME,(NAME + "_loader")))
                  @ext.copyright= 'Huynh Duong Phuong Vi'
                  @ext.creator =  'Suforyou'
                  ext.version = '1.2.2'
                  ext.description = Strings.GetString("Set Scale Definitions for Objects.")
                  Sketchup.register_extension ext, true
                  Should read thus:
                  @ext = SketchupExtension.new(('s4u-' + Strings.GetString(TOOL)),File.join(NAME,(NAME + "_loader")))
                  @ext.version = '1.2.2'
                  @ext.description = Strings.GetString("Set Scale Definitions for Objects.")
                  Sketchup.register_extension(@ext, true)
                  You can edit the RB loader and it will work - however, it will break the 'signing' so the Loading Policy must be Unrestricted - at least until the author posts/signs a fixed RBZ...
                  It can never have worked during the author's testing pre-RBZ-making !? 😲
                    That what I would think, too. Made me wonder why he updated it both here and in the Extension Warehouse.
                    • hdpvH Offline
                      hdpv
                      Sorry! I fixed it.
                      Suforyou
                        Thank you. Your ScaleTool has the same problem.
