    [Preview] Wrap-R Video #2
    extensions
    72 Posts 26 Posters 19.9k Views 26 Watching
    • JQLJ Offline
      JQL
      I'm relaxed... will wait for it calmly now...
      www.casca.pt
      Visit us on facebook!
      • FrederikF Offline
        Frederik
        I'm calm as well...
        But I do want to see more of this... πŸ˜„
        Cheers
        Kim Frederik
        • cmeedC Offline
          cmeed
          question on the video...
          the shell of the car was mostly green. The areas around the lights were red while an area opposite was blue - This indicates the checker material is being squashed or stretched? red squashed blue stretched. So will WrapR be able to fix this?
          how? - by moving the vertices around individually? I don't know much about UV mapping....
          • cmeedC Offline
            cmeed
            Also - will we be able to get models into games engines?
            a second UV channel was needed for Unreal for example.
            • JQLJ Offline
              JQL
              I don't believe you need the second UV channel. At least I was able to export to UE without it... The only problem I faced was 64+ materials on my model. It doesn't handle so many and I also haven't managed to actually work inside UE as I hadn't the time to dable with it. πŸ˜‰
              www.casca.pt
              • cmeedC Offline
                cmeed
                ....actually i think the second UV channel is now created by default by UE if the model doesn't have one...I just remembered.
                I ran into problems where some of my model would be fine in UE for a while then after a 'lighting' build everything went crazy - supposedly due to the lack of the second uv channel. anyway, like you, finding time to try and experiment is hard to find.
                • K Offline
                  kaas
                  If you want to use lightmaps in Unreal, you need a second UV channel. If you want to use only dynamic lights, you don't.
                  Unreal can create a second UV channel from Sketchup's texture channel. It basically makes a copy of the texture UV's, and re-shuffles all the individual UV islands so they fit in a 0-1 space.
                  Most textures in SketchUp have UV coords outside that 0-1 space so Unreal takes a bit time for that.
                  Problem is though, this only works for simple geometry. For more complex or curved elements (furniture for instance) the UVs in SketchUp are not nicely stitched together but all loose islands and all over the place. This results in a large lightmap with all kinds of tiny little islands and lots of wasted space. These lightmaps take more time to calculate and never look really well - even at higher resolutions.
                  For those elements, make your own lightmap UVs in Blender is your best option.
                  • JQLJ Offline
                    JQL
                    kaas, but if the original textures are UV unwrapped onto one of these organic models, the lighmap problem persists?
                    I mean if we have something unwrapped the second UV channel to lightmap convertion works well?
                    www.casca.pt
                    • K Offline
                      kaas
                      If you have nicely layout uvs (like in the image) AND the export to obj or fbx doesn't mess them up, I expect Unreal will most likely be able to re-use them easily.
                      • JQLJ Offline
                        JQL
                        Nice... It's not such a big deal with hard face modelling right?
                        www.casca.pt
                        • K Offline
                          kaas
                          Don't want to clutter Rich's topic. Send you a pm.
                            Yes, you can relax the selected UVs with the R key
                            Saving multiple UV maps per mesh is on the roadmap.
                            • JQLJ Offline
                              JQL
                              You're right... though it also relates to the usefulness of Wrap-R...
                              www.casca.pt
                                This video shows how you can mark seams in SketchUp anf it will be unwrapped in Wrap-r when it imports....
                                ...You can also see UV shells getting flipped.
                                Next is live syncing in SU so you don't need to save-close-open-save-close-open... πŸ˜›
                                • JQLJ Offline
                                  JQL
                                  Whoaa... Hold on!
                                  Are you developing that prior to release or after release?
                                  www.casca.pt
                                    prior to.... πŸ˜‰
                                    • jujuJ Offline
                                      juju
                                      @rich o brien said:
                                      prior to.... πŸ˜‰
                                      so, technically, would one then be able to save bump maps, etc. (all related to specfic textures) in the sketchup file?
                                      initially I thought this tool would only really benefit organic modeling, but it seems as though it may be of good use for all, especially if you want to contain all your texture info in one place... or am I understanding this wrong?
                                      • FrederikF Offline
                                        Frederik
                                        You're killing me...
                                        Cheers
                                        Kim Frederik
                                          no, UV maps and texture maps are different beasts. By having multiple UV maps you could then assign different texture maps to different uv maps. This is typically done in game engines for performance gains.
                                          it will benefit everyone that needs to UV map. Because SketchUp doesn't do it well and the extensions that try to tackle it can only get so far. Hence the standalone app of sorts.
                                          • JQLJ Offline
                                            JQL
                                            VIDEO WAS HERE
                                            You are really annoying... I want to play with it already!!!! I'm not calm anymore!
                                            www.casca.pt
                                            • 2 / 4
