    [Preview] Wrap-R Video #2
    extensions
    72 Posts 26 Posters 20.8k Views 26 Watching
    • JQLJ Offline
      JQL
      I don't believe you need the second UV channel. At least I was able to export to UE without it... The only problem I faced was 64+ materials on my model. It doesn't handle so many and I also haven't managed to actually work inside UE as I hadn't the time to dable with it. πŸ˜‰
      www.casca.pt
      Visit us on facebook!
      • cmeedC Offline
        cmeed
        ....actually i think the second UV channel is now created by default by UE if the model doesn't have one...I just remembered.
        I ran into problems where some of my model would be fine in UE for a while then after a 'lighting' build everything went crazy - supposedly due to the lack of the second uv channel. anyway, like you, finding time to try and experiment is hard to find.
          kaas
          If you want to use lightmaps in Unreal, you need a second UV channel. If you want to use only dynamic lights, you don't.
          Unreal can create a second UV channel from Sketchup's texture channel. It basically makes a copy of the texture UV's, and re-shuffles all the individual UV islands so they fit in a 0-1 space.
          Most textures in SketchUp have UV coords outside that 0-1 space so Unreal takes a bit time for that.
          Problem is though, this only works for simple geometry. For more complex or curved elements (furniture for instance) the UVs in SketchUp are not nicely stitched together but all loose islands and all over the place. This results in a large lightmap with all kinds of tiny little islands and lots of wasted space. These lightmaps take more time to calculate and never look really well - even at higher resolutions.
          For those elements, make your own lightmap UVs in Blender is your best option.
          • JQLJ Offline
            JQL
            kaas, but if the original textures are UV unwrapped onto one of these organic models, the lighmap problem persists?
            I mean if we have something unwrapped the second UV channel to lightmap convertion works well?
            www.casca.pt
              kaas
              If you have nicely layout uvs (like in the image) AND the export to obj or fbx doesn't mess them up, I expect Unreal will most likely be able to re-use them easily.
              • JQLJ Offline
                JQL
                Nice... It's not such a big deal with hard face modelling right?
                www.casca.pt
                  kaas
                  Don't want to clutter Rich's topic. Send you a pm.
                    @cmeed said:
                    So will WrapR be able to fix this?
                    Yes, you can relax the selected UVs with the R key
                    @cmeed said:
                    Also - will we be able to get models into games engines?
                    Saving multiple UV maps per mesh is on the roadmap.
                    • JQLJ Offline
                      JQL
                      You're right... though it also relates to the usefulness of Wrap-R...
                      www.casca.pt
                        This video shows how you can mark seams in SketchUp anf it will be unwrapped in Wrap-r when it imports....
                        ...You can also see UV shells getting flipped.
                        Next is live syncing in SU so you don't need to save-close-open-save-close-open... πŸ˜›
                        • JQLJ Offline
                          JQL
                          Whoaa... Hold on!
                          Are you developing that prior to release or after release?
                          www.casca.pt
                            prior to.... πŸ˜‰
                            • jujuJ Offline
                              juju
                              @rich o brien said:
                              prior to.... πŸ˜‰
                              so, technically, would one then be able to save bump maps, etc. (all related to specfic textures) in the sketchup file?
                              initially I thought this tool would only really benefit organic modeling, but it seems as though it may be of good use for all, especially if you want to contain all your texture info in one place... or am I understanding this wrong?
                              • FrederikF Offline
                                Frederik
                                You're killing me...
                                Cheers
                                Kim Frederik
                                  no, UV maps and texture maps are different beasts. By having multiple UV maps you could then assign different texture maps to different uv maps. This is typically done in game engines for performance gains.
                                  it will benefit everyone that needs to UV map. Because SketchUp doesn't do it well and the extensions that try to tackle it can only get so far. Hence the standalone app of sorts.
                                  • JQLJ Offline
                                    JQL
                                    VIDEO WAS HERE
                                    You are really annoying... I want to play with it already!!!! I'm not calm anymore!
                                    www.casca.pt
                                    • JQLJ Offline
                                      JQL
                                      @rich o brien said:
                                      prior to.... πŸ˜‰
                                      Are Tomasz and other render engines developers envolved with this? They could be interested in working together so we can better integrate materials in SU...
                                      Hell I will poke folks at Substance too!
                                      www.casca.pt
                                      • JQLJ Offline
                                        JQL
                                        I just came up to the conclusion that you're developing Wrap-R with the single purpose of getting on my nerve!
                                        www.casca.pt
                                          What more alarming to me is that you've only a single nerve! the rest of us suffer from having multiple nerves.
                                          It's easier hit one nerve though.
                                          • JQLJ Offline
                                            JQL
                                            Yes... my nerve looks forward to this! πŸ˜„
                                            www.casca.pt
                                            • 2 / 4
