    [Preview] Wrap-R Video #2
    extensions
    72 Posts 26 Posters 18.9k Views 26 Watching
    • JQLJ Offline
      JQL
      @rich o brien said:
      If you export the model to .obj from Wrap-R you can then go to Substance Painter...
      Then you simply create a material based on the textures exported from painter/designer.
      In your case you can, of course, use Thea Converter and apply those materials directly in SU with the help of T4SU or thrupaint.
      www.casca.pt
      Visit us on facebook!
      • JQLJ Offline
        JQL
        @Rich,
        Will we also be able to import textures directly into unwrapper or will we have to work with SU textures?
        www.casca.pt
        • FrederikF Offline
          Frederik
          @rich o brien said:
          You can export your unwrap to svg and do whatever you want in your image editor.
          This is EXCELLENT...!!! πŸ’š
          Thanks, Rich...!
          And also thanks for your comments, JoΓ£o... πŸ‘
          Cheers
          Kim Frederik
            @jql
            world is your oyster once you have a uv map.
            without one you can't bake normals, ao etc...
            texture import is vital but not from the outset. main purpose is to get this out as a minimum viable product and then let the users dictate it's dev.
            • soloS Offline
              This is so exciting, I cannot wait to try this.
              • JQLJ Offline
                JQL
                @rich o brien said:
                @jql
                You're absolutelly right!
                Also, my concerns are really not aiming at my current workflow as I'm using substance and as you say the only thing I need is an UV map and doing it with sketchup tools.
                Basically, I need only what you have right now!
                But I just cannot help pestering you, it's a way to feel involved already. Will it also be easy to select some edges and rotate them or edit them somehow so they get absolutelly vertical or horizontal?
                That would help a lot in some architectural workflows and I cannot do it with blender (I know it's pbcac... don't shove that on me! πŸ˜„)
                www.casca.pt
                • cmeedC Offline
                  cmeed
                  looks amazing....
                  c
                    "Will it also be easy to select some edges and rotate them or edit them somehow so they get absolutely vertical or horizontal?
                    Will it?
                    It can do it already πŸ˜‰
                    Align to top,bottom, left and right. Pin points too. And Relax.
                    • JQLJ Offline
                      JQL
                      I'm relaxed... will wait for it calmly now...
                      www.casca.pt
                      • FrederikF Offline
                        Frederik
                        I'm calm as well...
                        But I do want to see more of this... πŸ˜„
                        Cheers
                        Kim Frederik
                        • cmeedC Offline
                          cmeed
                          question on the video...
                          the shell of the car was mostly green. The areas around the lights were red while an area opposite was blue - This indicates the checker material is being squashed or stretched? red squashed blue stretched. So will WrapR be able to fix this?
                          how? - by moving the vertices around individually? I don't know much about UV mapping....
                          • cmeedC Offline
                            cmeed
                            Also - will we be able to get models into games engines?
                            a second UV channel was needed for Unreal for example.
                            • JQLJ Offline
                              JQL
                              I don't believe you need the second UV channel. At least I was able to export to UE without it... The only problem I faced was 64+ materials on my model. It doesn't handle so many and I also haven't managed to actually work inside UE as I hadn't the time to dable with it. πŸ˜‰
                              www.casca.pt
                              • cmeedC Offline
                                cmeed
                                ....actually i think the second UV channel is now created by default by UE if the model doesn't have one...I just remembered.
                                I ran into problems where some of my model would be fine in UE for a while then after a 'lighting' build everything went crazy - supposedly due to the lack of the second uv channel. anyway, like you, finding time to try and experiment is hard to find.
                                  kaas
                                  If you want to use lightmaps in Unreal, you need a second UV channel. If you want to use only dynamic lights, you don't.
                                  Unreal can create a second UV channel from Sketchup's texture channel. It basically makes a copy of the texture UV's, and re-shuffles all the individual UV islands so they fit in a 0-1 space.
                                  Most textures in SketchUp have UV coords outside that 0-1 space so Unreal takes a bit time for that.
                                  Problem is though, this only works for simple geometry. For more complex or curved elements (furniture for instance) the UVs in SketchUp are not nicely stitched together but all loose islands and all over the place. This results in a large lightmap with all kinds of tiny little islands and lots of wasted space. These lightmaps take more time to calculate and never look really well - even at higher resolutions.
                                  For those elements, make your own lightmap UVs in Blender is your best option.
                                  • JQLJ Offline
                                    JQL
                                    kaas, but if the original textures are UV unwrapped onto one of these organic models, the lighmap problem persists?
                                    I mean if we have something unwrapped the second UV channel to lightmap convertion works well?
                                    www.casca.pt
                                      kaas
                                      If you have nicely layout uvs (like in the image) AND the export to obj or fbx doesn't mess them up, I expect Unreal will most likely be able to re-use them easily.
                                      • JQLJ Offline
                                        JQL
                                        Nice... It's not such a big deal with hard face modelling right?
                                        www.casca.pt
                                          kaas
                                          Don't want to clutter Rich's topic. Send you a pm.
                                            Yes, you can relax the selected UVs with the R key
                                            Saving multiple UV maps per mesh is on the roadmap.
                                            • 2 / 4
