    Animator: Parametric Animation plugin - Discussion
    249 Posts 56 Posters 144.8k Views 55 Watching
    • fredo6F
      fredo6
      This is a thread for discussion about a plugin I am working on, called Animator.
      Animator is a Parametric and Interactive animation script. It manages unit movements for objects and cameras along a timeline:
      • Parametric, as it is based on the decomposition of movements in unit transformation (like translation, rotation, spin, ...). The exact position of objects and cameras can therefore be calculated at any time in the animation, at any frame rate.
      • Interactive, as you can create / modify unit movements and arrange them on a timeline. So you can see immediately the result of the change.
      The short video below gives a first idea of the concept.
      I am also looking for simple models designed for animation, like robots or mechanical devices, so that I can test the script as I am finishing it (which may take long actually).
      Fredo
        The new hit of 2016! ๐Ÿ˜‰
          here to help....and drool!
            Does this will be possible: Movements of the mechanical digger? (not the "Physics" falling objects)
            • O
              otb designworks
              This thread has made me very happy! Go Fredo Go!!!!
              Cheers, Chuck
              OTB Designworks is on Youtube
              • soloS
                solo
                Awesome, just what I have been talking about, any way I can help, just ask.
                http://www.solos-art.com
                • PixeroP
                  Pixero
                  Yes, YES, YEEES! ๐Ÿ‘ ๐Ÿ˜„
                  Finally.
                  This is something I have been wishing for for a looong time.
                  I'd love to try it to give feedback.
                  • ntxdaveN
                    ntxdave
                    I am happy to share a sample animation that Fredo created with the alpha version of his Animator plugin using one of my sample car washes. It shows both the ability to animate objects and do some "fly through" stuff.
                    Personally I am excited about the potential I am seeing here and glad that it is finally out there for the whole world to see.
                    BTW: Someone enlighten me what I did wrong with my attempt to include the YouTube video.
                    Press F1...thank me later
                    • massimoM
                      massimo Moderator
                      Just erase the "s" from "https".
                      I embedded it for you.
                      • ntxdaveN
                        ntxdave
                        Thanks - I appreciate that so that I can do it in the future.
                        For those viewing the animation, please notice how smooth it is. In the original animation posted by Fredo, also notice that while his SU model has multiple scenes, the animation appears to be taking place in a single scene. Think about that.....
                        Wouldn't it be wonderful if these types of animations could be included in things like Lumion, LumenRT and Twinmotion. We are heading toward the ability to show off products in an environment something like a video game.
                        • soloS
                          solo
                          It is possible in Lumion.
                          • ntxdaveN
                            ntxdave
                            When I looked at the animation capabilities in Lumion, it said (at least what I remember) was that you could not do subcomponents. Therefore if I had parts that I wanted to animate at two levels (like the first brush that both spins and pivots on an arm) you could not do that (at least that was my understanding). It would be great if we could do the basic animations within SU and then import them into those products and take advantage of their rendering and other capabilities.
                            • soloS
                              solo
                              It would be fantastic if this animation could be exported to a 3rd party animation app as .fbx, will not hold my breath however, In lumion to create this you would have to import all moving components separately however, can become very fiddly.
                              I hope that this animation gets supported by the SU integrated render engines like Twilight, Thea, Podium, Corona, Vray, etc.
                              • chriC
                                chri
                                Hi Fredo
                                Many Thanks for this new plugin.
                                I think that the movement is done by the timeline .
                                Is it possible to combine 2 movements like following examples from SKETCHYPHYSICS ?
                                in french
                                Il me semble avoir compris que la "timeline" commande les mouvements
                                Est-il possible de combiner des mouvements pour qu'une piรจce en pilote une deuxiรจme , comme dans les exemples SKETCHYPHYSICS ?.
                                Bye
                                Chri
                                FOURBAR.skp
                                CAME+TRANSLATION.skp
                                CAME+ROTATION.skp
                                ROTATION+ROTATION.skp
                                • PixeroP
                                  Pixero
                                  I really hope it will be possible with ease in and out and not just linear interpolation between key frames.
                                  • fredo6F
                                    fredo6
                                    @Pilou and chri
                                    Animator is purely based on kinematics, not physics. In addition, Animation is predictive, as you specify the movements, whereas Physics will dynamically calculate the movements based on physical laws (weight, collisions, ...).
                                    Therefore the purpose is very different, one is for illustrating, the other for playing or simulating.
                                    Animator should however include a Visit Controller mode, where you can animate the sequences individually.
                                    Fredo
                                    • fredo6F
                                      fredo6
                                      I plan to include Easing hopefully. You can see it in the video of the first post (look at Homer or some small cubes, which move with acceleration).
                                      Fredo
                                      • PixeroP
                                        Pixero
                                        Another wish.
                                        Perhaps for a later version, would be a curve editor for those who wish more precise control over animation.
                                        • PixeroP
                                          Pixero
                                          ...and another one...
                                          A way of retiming a animation "clip" by making it longer or shorter.
                                          • fredo6F
                                            fredo6
                                            Actually you can adjust the duration and start time of each element of a clip.
                                            You can also play the animation with variable speed.
                                            See at the end of the video, where I used a model provided by chri.
                                            Fredo
                                            • 12
                                            • 13
                                            • 1 / 13
