    Aligning multiple components to sit on one plane
    6 Posts 6 Posters 2.7k Views 6 Watching
    • M
      malanski
      Hello everybody,
      This is my first post on sketchucation.
      I am new to sketchup and I am still struggling with the basics. I have found answers to most of my questions on existing threads but this time I’m stuck. Perhaps it’s a matter of naming the problem properly.
      I want to align multiple components so that they sit on the same level/surface. I know how to do this manually by aligning each object separately using the move tool and locking the direction using the shift key. For aligning a couple of objects this is no problem but what if I were to align tens of objects? The attached picture illustrates the issue.
      I have tried googling phrases such as “Aligning multiple components” or “Aligning components to face” but obtained not satisfying results. Most often I would come across the Align Plugin for SU which seems to be dedicated to aligning two components together.
      Simon
      http://i66.tinypic.com/sztxys.jpg
        You might try Smart Drop.
        • sdmitchS
          sdmitch
          Select the components, open Windows>Ruby Console, paste this one-liner and press enter.
          Sketchup.active_model.selection.grep(Sketchup;;ComponentInstance).each{|ci|
           ci.transform! Geom;;Transformation.translation([0,0,-ci.transformation.origin.z])
          This will put all selected components on the XY plane.
          http://sdmitch.blogspot.com/
          • BoxB
            Have a look at the 'Throw to' plugin.
              😮 Dave is using a Script? 💚
              Try also this one 😉
              Ray Tracer By Thomthom
              http://sketchucation.com/forums/download/file.php?id=53899&t=1
              http://sketchucation.com/forums/download/file.php?id=53900&t=1
              • D
                djh
                This will put all selected components on the XY plane.[/quote]
                sdmitch, thank you. Just what I needed. Just have to be careful to copy and paste the whole thing, even the last } which is on the bottom line.
