Aligning multiple components to sit on one plane
6 Posts 6 Posters 2.2k Views 6 Watching
    malanski
    Hello everybody,
    This is my first post on sketchucation.
    I am new to sketchup and I am still struggling with the basics. I have found answers to most of my questions on existing threads but this time I’m stuck. Perhaps it’s a matter of naming the problem properly.
    I want to align multiple components so that they sit on the same level/surface. I know how to do this manually by aligning each object separately using the move tool and locking the direction using the shift key. For aligning a couple of objects this is no problem but what if I were to align tens of objects? The attached picture illustrates the issue.
    I have tried googling phrases such as “Aligning multiple components” or “Aligning components to face” but obtained not satisfying results. Most often I would come across the Align Plugin for SU which seems to be dedicated to aligning two components together.
    Simon
    http://i66.tinypic.com/sztxys.jpg
      You might try Smart Drop.
        sdmitch
        Select the components, open Windows>Ruby Console, paste this one-liner and press enter.
        Sketchup.active_model.selection.grep(Sketchup;;ComponentInstance).each{|ci|
         ci.transform! Geom;;Transformation.translation([0,0,-ci.transformation.origin.z])
        This will put all selected components on the XY plane.
        http://sdmitch.blogspot.com/
          Have a look at the 'Throw to' plugin.
            😮 Dave is using a Script? 💚
            Try also this one 😉
            Ray Tracer By Thomthom
            http://sketchucation.com/forums/download/file.php?id=53899&t=1
            http://sketchucation.com/forums/download/file.php?id=53900&t=1
              djh
              This will put all selected components on the XY plane.[/quote]
              sdmitch, thank you. Just what I needed. Just have to be careful to copy and paste the whole thing, even the last } which is on the bottom line.
