    🤑 SketchPlus 1.3 | 44 Tools for $15 until June 20th Buy Now
    How to create realistic gravel from mapping texture ?
    renderpluginsextensions
    8 Posts 4 Posters 3.6k Views 4 Watching
    • yantinoviikaY Offline
      yantinoviika
      hello, i have a problem with rendering gravel. can you help me?
      when i make gravel from mapping texture and add some bump and displacement, it doesn't look good when i rendered.
      how can i make this texture look realistic?
      thank you.
        You need to give more info. What rendering program? Show us the results you're getting and tell us in detail what you want to get as a result
          yantinoviika
          Here, sample from my render
          i want a realistic result
          but in my rendered image it look flat, like i dont use displacement
          but if i increase number pf displacement
          the result is so ugly
            yantinoviika
            oh sorry i used vray for sketchup
            • jujuJ Offline
              juju
              @dave r said:
              ... What rendering program? ...
                yantinoviika
                I used vray from sketchup
                • TedVitale_CGT Offline
                  TedVitale_CG
                  Here's a low quality example of gravel. This is an Aaroway material you can purchase in high resolution here: https://www.arroway-textures.ch/en/textures/gravel-002?browser
                  This is a good example of a gravel texture with displacement. Remember to use displacement sparingly and only on a single grouped object. Do not use it with a piece of geometry that has multiple textures or materials applied to the same mesh, or you'll run into problems.
                  Hope that helps!
                  Gravel.zip
                  Ted Vitale
                  Owner | Creative Director
                  http://www.voxl.vision
                    yantinoviika
                    tankyu @TedVitale_CG
                    it really work
