    SubD examples and models
    Scheduled Pinned Locked Moved SUbD
    renderpluginsextensions
    1.7k Posts 81 Posters 1.1m Views 79 Watching
    • aarondietzenA Offline
      aarondietzen
      @hornoxx said:
      @aarondietzen said:
      ...Quick model I did earlier this week...
      πŸ‘ Wonderful - what a nice SubD model idea this example is again !
      To reduce the geometry to what is just necessary always looks so simple but is the challenge πŸ˜‰
      (would you mind to share this proxy here?)
      But of course!
      I even did a video of the model, for anyone interested...
      "Imagination is more important than knowledge..."
      - Albert Einstein
      • dereiD Offline
        derei
        @hornoxx said:
        πŸ‘ Great - I love this little boat
        Do I get you right - the 3D text remains a geometry of itΒ΄s own?
        No. The 3D text is "draped" and then extruded from the boat's hull mesh. But that could be done only after the boat was subdivided using subD. After the subdivision, if you right-click on it, you will se a context subD menu that converts the parametric mesh into a plain mesh... that can't be turned back to low poly anymore. Is just a simple standard triangle mesh surface.
        So, on this surface I used the Drape Tool from Sandbox to imprint the text outline. Then I used Fredo's PushPull over that outline.
        DESIGNER AND ARTIST [DEREI.UK](http://derei.uk/l)
        • HornOxxH Offline
          HornOxx
          @aarondietzen said:
          ...But of course!...
          Thanks a lot!!
          This is a great (and hopefully timelapsed πŸ˜„ ) Making Of video !!!
          Best
          never trust a skinny cook
            aarondietzen
            @hornoxx said:
            Thanks a lot!!
            Best
            Yeah... even though it was a quick model (25 minutes) I did speed it up for the video... but I did leave it all in there! Even several "oops" moments!
            - Albert Einstein
            • dereiD Offline
              derei
              @nlipovac said:
              I do expect pic of printed boat!? πŸ˜„
              I definitely expect that too... he promised that he would do that on Monday... due to the reason that he has to fine-tune the printer. Right now he's printing with 0.3mm nozzle and had some speed problems. But he promised to go with 0.1 (which my model deserves).
              • HornOxxH Offline
                HornOxx
                @derei said:
                ...But he promised to go with 0.1 (which my model deserves)...
                πŸ˜„ πŸ˜‰ πŸ˜„ and not only that - I expect floating capability even πŸ˜„
                • dereiD Offline
                  derei
                  Well, is plastic...and you know that 3D printing software makes that honeycomb structure inside... so I expect it will float... but I can't guarantee it won't be upside down πŸ’š I didn't do any buoyancy calculations, not even to find its center of gravity... (tig has a plugin for that, right?)
                  • HornOxxH Offline
                    HornOxx
                    @derei said:
                    ... but I can't guarantee it won't be upside down πŸ’š...
                    πŸ’š πŸ˜‰
                      pilou, that image doesn't load right to me...
                        @Aaron! πŸ‘
                        http://lewebjournal.fr/wp-content/uploads/2013/07/images1.jpg
                        • BoxB Offline
                          I haven't had time for ages just to have a play, so this was a relaxing bit of fun.
                          One interesting thing that came out of it that I was half aware of, you can twist your quads so they are kinda inside out and SUbD will still make beautiful shapes from them.
                          http://i.imgur.com/ZHe60rD.gif
                          SUbDFun.skp
                            cuttingedge
                            For a while, I thought your model was too messed up for SubD to actually work.Awesome discovery by just playing around..
                            • BoxB Offline
                              I'm pretty sure it helped that I twisted it using Vertex tools as it tends to retain a good quad structure.
                                Very elegant! 😎
                                  spacemouse-uv.zip
                                  • cottyC Offline
                                    cotty
                                    A simple heater...
                                    my SketchUp gallery
                                    • HornOxxH Offline
                                      HornOxx
                                      @rich o brien said:
                                      ...spacemouse...
                                      πŸ‘ this is a perfect example for quad modeling
                                      are you using this spacemouse?
                                      • HornOxxH Offline
                                        HornOxx
                                        @cotty said:
                                        A simple heater...
                                        πŸ‘ πŸ‘
                                        ... maybe simple - but very smart to build just a quarter of only one heater segment and to copy-mirror everything to a whole heater - a nice model idea!
                                          Useful for these frozzen times! 😎
                                            Wonderful examples. Loving meshes that have the bare minimum of quads to define a shape.
                                            • 36
                                            • 37
                                            • 38
                                            • 39
                                            • 40
                                            • 82
                                            • 83
                                            • 38 / 83
