    [Plugin]SharpComp v1.0 2015-11-29
    34 Posts 14 Posters 13.1k Views 14 Watching
    • W Offline
      wikii
      sharp editor of componet v0.01
      1 select a component
      2 right click it
      3 from pop menu ,select "Edit Component"
      4 the component will be open in a new sketchup window(if already opened,the window will be actived).
      5 modify the model in the new open window,then save it.
      6 back to the first sketchup window
      7 right click the component,then "reload component"
      This plugin need AMS_LIB.
      v0.02
      add sendback , auto active old su window and auto reload componet.
      v1.0 1129
      1 lock component instances when definition opened in the seperate su window.
      2 unlock component instances when the seperate su window close.
      3 rewrite codes to work more clearly.
      need ams_lib 3.1.0
      v1.0 1129
      • JQLJ Offline
        JQL
        2 right click it
        [attachment=1:3lhnumqo]<!-- ia1 -->sharp2.gif<!-- ia1 -->[/attachment:3lhnumqo]
        [attachment=0:3lhnumqo]<!-- ia0 -->Sharp_edit_comp.rb<!-- ia0 -->[/attachment:3lhnumqo]
        Excellent!
        What if the component has already been "save as" into a folder. Does it open the component inside that folder?
        www.casca.pt
        Visit us on facebook!
        • W Offline
          wikii
          2 right click it
          [attachment=1:2cnkdyrm]<!-- ia1 -->sharp2.gif<!-- ia1 -->[/attachment:2cnkdyrm]
          [attachment=0:2cnkdyrm]<!-- ia0 -->Sharp_edit_comp.rb<!-- ia0 -->[/attachment:2cnkdyrm]
          Excellent!
          If the component has been saveas or loaded from skp file , the sharp editor of component will open the skp file directly.
          • JQLJ Offline
            JQL
            It is perfect then! Really great!
            www.casca.pt
            • G Offline
              greatoe
              Does this work for Mac?
              I got error loading this on a Mac.
              • W Offline
                wikii
                Sorry this plugin need ams_lib to find sketchup window.
                ams_lib only works on pc.
                • pbacotP Offline
                  Looks great. I'd like to work more with separate files, and this would really make it smoother. Only on PC though... Good work anyway.
                  • guanjinG Offline
                    guanjin
                    Wikii,Elder brother
                    AMS_LIB,Where to download
                    I come from China, is to learn
                      driven
                      it also requires "whdialog.rb"?
                      but that's not in the AMS_LIB from the Plugin Store...
                      john
                      • W Offline
                        wikii
                        @guanjin said:
                        Wikii,Elder brother
                        you can download ams_lib here
                        http://sketchucation.com/forums/viewtopic.php?f=323%26amp;t=55067
                        • W Offline
                          wikii
                          john
                          whdialog is a lib that I wrote to creat webdialog easily.
                          with out whdialog this plugin can also run well.
                          • HornOxxH Offline
                            HornOxx
                            Hi Wikii
                            This is a wonderful plugin. Thank you for sharing that!
                            It automatically does what I often forget to do - namely to work with a second opened Skup, which makes things much easier often.
                            One thing I have noticed which is worth to mention here: First after the initial SkUp file with the component is saved at least once, the "Edit Component" option will run by opening the second SkUp.
                            never trust a skinny cook
                            • W Offline
                              wikii
                              with SEC v0.02
                              If I make shortcuts CAS+E to "Edit Component",CAS+B to "Send Back".
                              In a Sketchup window, I select a component,then press CAS+E to "Edit Component" .the component will be saved and opened in a new su window .
                              Edit something in the new su window, then press CAS+B to "Send Back",the file will been saved . then old sketchup window will be actived and reload the component automaticly.
                              I think this plugin can greatly improve the modeling efficiency.
                              • Bob JamesB Offline
                                Bob James
                                @wikii said:
                                with SEC v0.02
                                What is "CAS" in CAS+E and CAS+B
                                • W Offline
                                  wikii
                                  @bob james said:
                                  @wikii said:
                                  with SEC v0.02
                                  cas+e means shortcut : ctrl+alt+shift+e.
                                  • JQLJ Offline
                                    JQL
                                    @wikii said:
                                    with SEC v0.02
                                    This was a though read but it's an excellent feature.
                                    What if you had a "save as and edit" tool.
                                    Using this feature on a component wich has not been "saved as" manually before, would first save as and then open the component in a new window.
                                    If a component had been saved before, it would simply open it.
                                    Also.
                                    What about conflicts?
                                    Could there be a way to lock a component that is being edited? And reload it as usual even locked once the edition is finished and unlock it only when the editing window has been closed?
                                    www.casca.pt
                                    • W Offline
                                      wikii
                                      @jql said:
                                      @wikii said:
                                      with SEC v0.02
                                      Also.
                                      yeah,to lock the component when it has been opened in the new window is necessarily.
                                      • sadyoS Offline
                                        sadyo
                                        Wondering if we can edit multiple component with your plugin
                                        • W Offline
                                          wikii
                                          Yes,will open multiple sketchup window for each component.
                                            @wikii
                                            you should be able to update your plugins/extensions at plugins.sketchucation.com
                                            here you can push updates directly to the store
                                            • 1 / 2
