    [Plugin]SharpComp v1.0 2015-11-29
    34 Posts 14 Posters 13.3k Views 14 Watching
    • pbacotP Offline
      Looks great. I'd like to work more with separate files, and this would really make it smoother. Only on PC though... Good work anyway.
      • guanjinG Offline
        guanjin
        Wikii,Elder brother
        AMS_LIB,Where to download
          driven
          it also requires "whdialog.rb"?
          but that's not in the AMS_LIB from the Plugin Store...
          • W Offline
            wikii
            @guanjin said:
            Wikii,Elder brother
            you can download ams_lib here
            http://sketchucation.com/forums/viewtopic.php?f=323%26amp;t=55067
            • W Offline
              wikii
              whdialog is a lib that I wrote to creat webdialog easily.
              with out whdialog this plugin can also run well.
              • HornOxxH Offline
                HornOxx
                Hi Wikii
                This is a wonderful plugin. Thank you for sharing that!
                It automatically does what I often forget to do - namely to work with a second opened Skup, which makes things much easier often.
                One thing I have noticed which is worth to mention here: First after the initial SkUp file with the component is saved at least once, the "Edit Component" option will run by opening the second SkUp.
                never trust a skinny cook
                • W Offline
                  wikii
                  with SEC v0.02
                  If I make shortcuts CAS+E to "Edit Component",CAS+B to "Send Back".
                  In a Sketchup window, I select a component,then press CAS+E to "Edit Component" .the component will be saved and opened in a new su window .
                  Edit something in the new su window, then press CAS+B to "Send Back",the file will been saved . then old sketchup window will be actived and reload the component automaticly.
                  I think this plugin can greatly improve the modeling efficiency.
                  • Bob JamesB Offline
                    Bob James
                    @wikii said:
                    with SEC v0.02
                    What is "CAS" in CAS+E and CAS+B
                    • W Offline
                      wikii
                      @bob james said:
                      @wikii said:
                      with SEC v0.02
                      cas+e means shortcut : ctrl+alt+shift+e.
                      • JQLJ Offline
                        JQL
                        @wikii said:
                        with SEC v0.02
                        This was a though read but it's an excellent feature.
                        What if you had a "save as and edit" tool.
                        Using this feature on a component wich has not been "saved as" manually before, would first save as and then open the component in a new window.
                        If a component had been saved before, it would simply open it.
                        Also.
                        What about conflicts?
                        Could there be a way to lock a component that is being edited? And reload it as usual even locked once the edition is finished and unlock it only when the editing window has been closed?
                        www.casca.pt
                        Visit us on facebook!
                        • W Offline
                          wikii
                          @jql said:
                          @wikii said:
                          with SEC v0.02
                          Also.
                          yeah,to lock the component when it has been opened in the new window is necessarily.
                          • sadyoS Offline
                            sadyo
                            Wondering if we can edit multiple component with your plugin
                            • W Offline
                              wikii
                              Yes,will open multiple sketchup window for each component.
                                @wikii
                                you should be able to update your plugins/extensions at plugins.sketchucation.com
                                here you can push updates directly to the store
                                • F Offline
                                  function
                                  wikki can you update combin editor. I've found it breaks dynamic components
                                  • W Offline
                                    wikii
                                    @rich o brien said:
                                    @wikii
                                    I can't login http://plugins.sketchucation.com/.
                                    Should I use password same as http://www.sktchucation.com?
                                      Jim
                                      What functions do you need from AMS_Lib? I think this can be done without any Windows-specific functions.
                                      • W Offline
                                        wikii
                                        The plugin need AMS_LIB to find window which opened the component,then active it.
                                        • W Offline
                                          wikii
                                          v1.0 1129
                                          1 lock component instances when definition opened in the seperate su window.
                                          2 unlock component instances when the seperate su window close.
                                          3 rewrite codes to work more clearly.
                                            Jim
                                            @wikii said:
                                            v1.0 1129
                                            Is there any good reason that you are including Anton's AMS Lib with this? AMSLib is easily available in the Plugins Store and also the Extension Warehouse.
                                            You have now created a conflict - one of the libraries will re-write the other. This is not a problem until one of you makes changes which could potentially break both plugins and cause a lot of confusion for yourselves and problems for everyone else using the library.
                                            I hope you at least that you talked to Anton about including his work in your extension. At the very least, you need to wrap AMSLib in a different namespace to avoid conflicts.
