    [Plugin]SharpComp v1.0 2015-11-29
    34 Posts 14 Posters 13.4k Views 14 Watching
    • W Offline
      wikii
      @guanjin said:
      Wikii,Elder brother
      AMS_LIB,Where to download
      you can download ams_lib here
      http://sketchucation.com/forums/viewtopic.php?f=323%26amp;t=55067
      • W Offline
        wikii
        @driven said:
        it also requires "whdialog.rb"?
        but that's not in the AMS_LIB from the Plugin Store...
        whdialog is a lib that I wrote to creat webdialog easily.
        with out whdialog this plugin can also run well.
        • HornOxxH Offline
          HornOxx
          Hi Wikii
          This is a wonderful plugin. Thank you for sharing that!
          It automatically does what I often forget to do - namely to work with a second opened Skup, which makes things much easier often.
          One thing I have noticed which is worth to mention here: First after the initial SkUp file with the component is saved at least once, the "Edit Component" option will run by opening the second SkUp.
          never trust a skinny cook
          • W Offline
            wikii
            with SEC v0.02
            If I make shortcuts CAS+E to "Edit Component",CAS+B to "Send Back".
            In a Sketchup window, I select a component,then press CAS+E to "Edit Component" .the component will be saved and opened in a new su window .
            Edit something in the new su window, then press CAS+B to "Send Back",the file will been saved . then old sketchup window will be actived and reload the component automaticly.
            I think this plugin can greatly improve the modeling efficiency.
            • Bob JamesB Offline
              Bob James
              @wikii said:
              with SEC v0.02
              What is "CAS" in CAS+E and CAS+B
              • W Offline
                wikii
                @bob james said:
                @wikii said:
                with SEC v0.02
                cas+e means shortcut : ctrl+alt+shift+e.
                • JQLJ Offline
                  JQL
                  @wikii said:
                  with SEC v0.02
                  This was a though read but it's an excellent feature.
                  What if you had a "save as and edit" tool.
                  Using this feature on a component wich has not been "saved as" manually before, would first save as and then open the component in a new window.
                  If a component had been saved before, it would simply open it.
                  Also.
                  What about conflicts?
                  Could there be a way to lock a component that is being edited? And reload it as usual even locked once the edition is finished and unlock it only when the editing window has been closed?
                  www.casca.pt
                  Visit us on facebook!
                  • W Offline
                    wikii
                    @jql said:
                    @wikii said:
                    with SEC v0.02
                    Also.
                    yeah,to lock the component when it has been opened in the new window is necessarily.
                    • sadyoS Offline
                      sadyo
                      Wondering if we can edit multiple component with your plugin
                      • W Offline
                        wikii
                        Yes,will open multiple sketchup window for each component.
                          @wikii
                          you should be able to update your plugins/extensions at plugins.sketchucation.com
                          here you can push updates directly to the store
                          • F Offline
                            function
                            wikki can you update combin editor. I've found it breaks dynamic components
                            • W Offline
                              wikii
                              @rich o brien said:
                              @wikii
                              I can't login http://plugins.sketchucation.com/.
                              Should I use password same as http://www.sktchucation.com?
                                Jim
                                What functions do you need from AMS_Lib? I think this can be done without any Windows-specific functions.
                                • W Offline
                                  wikii
                                  The plugin need AMS_LIB to find window which opened the component,then active it.
                                  • W Offline
                                    wikii
                                    v1.0 1129
                                    1 lock component instances when definition opened in the seperate su window.
                                    2 unlock component instances when the seperate su window close.
                                    3 rewrite codes to work more clearly.
                                      Jim
                                      @wikii said:
                                      v1.0 1129
                                      Is there any good reason that you are including Anton's AMS Lib with this? AMSLib is easily available in the Plugins Store and also the Extension Warehouse.
                                      You have now created a conflict - one of the libraries will re-write the other. This is not a problem until one of you makes changes which could potentially break both plugins and cause a lot of confusion for yourselves and problems for everyone else using the library.
                                      I hope you at least that you talked to Anton about including his work in your extension. At the very least, you need to wrap AMSLib in a different namespace to avoid conflicts.
                                      • W Offline
                                        wikii
                                        @jim said:
                                        @wikii said:
                                        v1.0 1129
                                        In our place,many time,it very difficult to access sketchucation.com or the Extension Warehouse.
                                        Thank you for your advise.
                                        I remove ams_lib in the packed file.
                                        • JQLJ Offline
                                          JQL
                                          Wikii, can I ask for a name change of this plugin in the Sketchucation Plugin Store?
                                          I've literally lost hours searching for this magnificent gem, and then hours searching for this thread, and finally I found it!
                                          Thanks! (and thanks for the plugin, of course, it's very good!)
                                          www.casca.pt
                                            Bob James
                                            It's now called "Sharp Edit" and can be found in the Extension Store or at:
                                            http://sketchucation.com/pluginstore?pauthor=wikii
