All my 2-D components are z-fighting!
Has anyone else run into this problem?
I am using standard sketchup 2-D figures and downloaded 2-D components from the 3-D Warehouse. When I try to render my scenes as animations, all the 2-D figures are flickering - ie z-fighting. The only way around this is to explode each component, create a new component from the resulting object, then replace any other instances in the scene. The only reason I am posting here in the forum is because at first I thought it was just the components I downloaded from the warehouse, but it is even happening with sketchup standard figures like "Susan" and "Steve". WTF? I am using Sketchup Make 2015
Any suggestions appreciated. I am working to replace all the figures with new components, but it is a pain and I don't want to have to do this every time in the future...
Can you share one model with this behaviour?
You know that you can replace all instances of a component at once? -
You know that you can replace all instances of a component at once?Yes, thank goodness it is possible to replace all instances!
I will have a quick look at how to share my model, and make sure the file size isn't too huge. I am wondering if the problem is that I am looking through a transparent surface at one point during the animation... -
Nope - my current file is way too big to upload. Will create a smaller version and upload that. Stay tuned...
Okay I chopped out lots of stuff and got this file down to the basic problem. A quick render shows that the z-fighting happens when the view is through a transparent wall. The wall is there so that it can cast a shadow on the scene. If I take it away, the shadow is gone, but if it is not transparent, then I cannot view the scene the way I want...
Any suggestions appreciated!
Chopped down file, z-fighting when seen through transparent wall.
maybe try changing your window-style-face settings to 'nicer' instead of 'faster'. That can improve quality of transparent objects.
Thanks kaas I will try that.
where do you see the z-fighting. I see none if I run the animation or move through manually?
it may be graphic card related...
john
john
Thanks John - I do not see it when navigating the model, only when it is rendering as an animation.
You are right, it may indeed be a problem with my graphic card, this is a rather old laptop that has the OS reinstalled several times. Will try looking into that...
I redesigned the scenes so that I no longer needed any transparency, and I am still getting the same z-fighting.
Could it be related to the reversed faces you have in the model.
Look at it in Monochrome and see if the fighting is happening on the blue areas. -
Possible your graphic card. You should try Window>Preference>OpenGL and check/uncheck options there.
I can also recreate on export even without the transparent walls [which thought may be causing an openGL glitch]
@driven said:
I can also recreate on export even without the transparent walls [which thought may be causing an openGL glitch][attachment=0:1mbcevkl]<!-- ia0 -->test-less-scenes0004.jpg<!-- ia0 -->[/attachment:1mbcevkl]
Thanks driven! So it is not just me
Yes, I got rid of the invisible wall as well, and made all my scenes take place within the courtyard area (not looking through anything), and still got the z-fighting. I have been out all day, so have not had the chance to check my graphics card. I know I have two more projects coming up that I will be using sketchup on, so need to sort this out... when I do, I will post solution here.Thanks everyone for suggestions, and keep them coming if you think of something no one else has mentioned.
I've had this issue too. I can't recall how or if we fixed it. I'll check back (its a couple of years ago). In the mean time, if you discover an answer, I'd be very pleased to know also.
Register LoginAdvertisement
