    βŒ› Sale Ending | 30% Off Profile Builder 4 ends 30th September
    All my 2-D components are z-fighting!
    14 Posts 7 Posters 829 Views 7 Watching
      jhayes
      Has anyone else run into this problem?
      I am using standard sketchup 2-D figures and downloaded 2-D components from the 3-D Warehouse. When I try to render my scenes as animations, all the 2-D figures are flickering - ie z-fighting. The only way around this is to explode each component, create a new component from the resulting object, then replace any other instances in the scene. The only reason I am posting here in the forum is because at first I thought it was just the components I downloaded from the warehouse, but it is even happening with sketchup standard figures like "Susan" and "Steve". WTF? I am using Sketchup Make 2015
      Any suggestions appreciated. I am working to replace all the figures with new components, but it is a pain and I don't want to have to do this every time in the future...
      • cottyC Offline
        cotty
        Can you share one model with this behaviour?
        You know that you can replace all instances of a component at once?
        my SketchUp gallery
          jhayes
          Yes, thank goodness it is possible to replace all instances!
          I will have a quick look at how to share my model, and make sure the file size isn't too huge. I am wondering if the problem is that I am looking through a transparent surface at one point during the animation...
            jhayes
            Nope - my current file is way too big to upload. Will create a smaller version and upload that. Stay tuned...
              jhayes
              Okay I chopped out lots of stuff and got this file down to the basic problem. A quick render shows that the z-fighting happens when the view is through a transparent wall. The wall is there so that it can cast a shadow on the scene. If I take it away, the shadow is gone, but if it is not transparent, then I cannot view the scene the way I want...
              Any suggestions appreciated!
              Chopped down file, z-fighting when seen through transparent wall.
                kaas
                maybe try changing your window-style-face settings to 'nicer' instead of 'faster'. That can improve quality of transparent objects.
                  jhayes
                  Thanks kaas I will try that.
                    driven
                    where do you see the z-fighting. I see none if I run the animation or move through manually?
                    it may be graphic card related...
                      jhayes
                      Thanks John - I do not see it when navigating the model, only when it is rendering as an animation.
                      You are right, it may indeed be a problem with my graphic card, this is a rather old laptop that has the OS reinstalled several times. Will try looking into that... πŸ˜•
                      I redesigned the scenes so that I no longer needed any transparency, and I am still getting the same z-fighting.
                      • BoxB Offline
                        Could it be related to the reversed faces you have in the model.
                        Look at it in Monochrome and see if the fighting is happening on the blue areas.
                        • I Offline
                          iiid
                          Possible your graphic card. You should try Window>Preference>OpenGL and check/uncheck options there.
                            driven
                            I can also recreate on export even without the transparent walls [which thought may be causing an openGL glitch]and it's not just the dynamic ones either...
                              jhayes
                              @driven said:
                              I can also recreate on export even without the transparent walls [which thought may be causing an openGL glitch][attachment=0:1mbcevkl]<!-- ia0 -->test-less-scenes0004.jpg<!-- ia0 -->[/attachment:1mbcevkl]
                              Thanks driven! So it is not just me πŸ˜„ Yes, I got rid of the invisible wall as well, and made all my scenes take place within the courtyard area (not looking through anything), and still got the z-fighting. I have been out all day, so have not had the chance to check my graphics card. I know I have two more projects coming up that I will be using sketchup on, so need to sort this out... when I do, I will post solution here.
                              Thanks everyone for suggestions, and keep them coming if you think of something no one else has mentioned. πŸ˜„
                              • emerald15E Offline
                                emerald15
                                I've had this issue too. I can't recall how or if we fixed it. I'll check back (its a couple of years ago). In the mean time, if you discover an answer, I'd be very pleased to know also.
