    Fredo6 RoundCorner weird problem
    5 Posts 3 Posters 1.4k Views 3 Watching
    • S
      Stermo
      I have installed Fredo6 RoundCorner and libFredo6(last version) but when I open sketchup.I get massage that I need to install libredo6 to use RoundCorner.This is the error when I tried to use a RoundCorner
      Error: #<NoMethodError: undefined method no_bandeau' for #<Traductor::Palette:0x0000000d8997b8>> C:/Users/Deankkostov/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/Fredo6_RoundCorner/RoundCorner_Tool.rb:1045:in pal_sepa_bandeau'
      C:/Users/Deankkostov/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/Fredo6_RoundCorner/RoundCorner_Tool.rb:1069:in palette_init' C:/Users/Deankkostov/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/Fredo6_RoundCorner/RoundCorner_Tool.rb:208:in initialize'
      C:/Users/Deankkostov/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/Fredo6_RoundCorner/RoundCorner_Tool.rb:129:in new' C:/Users/Deankkostov/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/Fredo6_RoundCorner/RoundCorner_Tool.rb:129:in launch'
      C:/Users/Deankkostov/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/Fredo6_RoundCorner/RoundCorner_Tool.rb:120:in action__mapping' C:/Users/Deankkostov/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6Plugin.rb:133:in call'
      C:/Users/Deankkostov/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6Plugin.rb:133:in launch_action' C:/Users/Deankkostov/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/Fredo6_RoundCorner/bootstrap_RoundCorner.rb:81:in launch_action'
      C:/Users/Deankkostov/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/Fredo6_RoundCorner/bootstrap_RoundCorner.rb:96:in block in startup' C:/Users/Deankkostov/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6Plugin.rb:1093:in call'
      C:/Users/Deankkostov/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6Plugin.rb:1093:in command_invoke' C:/Users/Deankkostov/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6Plugin.rb:1075:in block (2 levels) in build_config_commands'
      C:/Users/Deankkostov/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6Traductor.rb:1107:in call' C:/Users/Deankkostov/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6Traductor.rb:1107:in block in add_command'
      SketchUp:1:in `call'
      I tried reisntal, delete etc... these two plugins but the problem is staying again.I have Sketchup 2015 and windows 8.1.Any idea how to fix it ?
        Is it possible you still have an older version of some files from LibFredo6 in the Plugins folder?
        • S
          Stermo
          Now I deleted all replicated plugins of RoundCorner and do not have a massage to instal libFredo but when try to use the plugin I get this error in ruby console
          rror: #<NoMethodError: undefined method no_bandeau' for #<Traductor::Palette:0x000000108de770>> C:/Users/Deankkostov/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/Fredo6_RoundCorner/RoundCorner_Tool.rb:1045:in pal_sepa_bandeau'
          • TIGT
            You need to have the latest "LibFredo" installed to run almost all of his tools.
            So that Lib + RoundCorners are the minimum you need, and it will work provided that nothing 'old' is left behind.
            Also restart SketchUp after the install or other file-sorting out to ensure a proper load is achieved...
            I suspect you have copied files/folders over from the Plugins folder[s] of older versions of SketchUp ?
            Not recommended.
            There are several possibilities...
            The likely one is because newer 'LibTraductor' is now provided within the "Fredo6_!LibFredo6" subfolder, and there should NOT be a RB file of that name loading directly from the Plugins folder.
            This might be causing the issue ?
            If the old version loads and doesn't include the no_bandeau method the error arises...
            I suggest you remove all Fredo related files and subfolders from the Plugins folder; then reinstall the LibFredo, and then the Plugin itself, from their respective RBZ files, finally restart SketchUp and retest...
            • S
              Stermo
              Ok TIG I will try it now.
              This fix the problem thank you !
              Thank you for your time guys !
