Fredo6 RoundCorner weird problem
I have installed Fredo6 RoundCorner and libFredo6(last version) but when I open sketchup.I get massage that I need to install libredo6 to use RoundCorner.This is the error when I tried to use a RoundCorner
Error: #<NoMethodError: undefined method
no_bandeau' for #<Traductor::Palette:0x0000000d8997b8>> C:/Users/Deankkostov/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/Fredo6_RoundCorner/RoundCorner_Tool.rb:1045:inpal_sepa_bandeau'
C:/Users/Deankkostov/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/Fredo6_RoundCorner/RoundCorner_Tool.rb:1069:inpalette_init' C:/Users/Deankkostov/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/Fredo6_RoundCorner/RoundCorner_Tool.rb:208:ininitialize'
C:/Users/Deankkostov/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/Fredo6_RoundCorner/RoundCorner_Tool.rb:129:innew' C:/Users/Deankkostov/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/Fredo6_RoundCorner/RoundCorner_Tool.rb:129:inlaunch'
C:/Users/Deankkostov/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/Fredo6_RoundCorner/RoundCorner_Tool.rb:120:inaction__mapping' C:/Users/Deankkostov/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6Plugin.rb:133:incall'
C:/Users/Deankkostov/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6Plugin.rb:133:inlaunch_action' C:/Users/Deankkostov/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/Fredo6_RoundCorner/bootstrap_RoundCorner.rb:81:inlaunch_action'
C:/Users/Deankkostov/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/Fredo6_RoundCorner/bootstrap_RoundCorner.rb:96:inblock in startup' C:/Users/Deankkostov/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6Plugin.rb:1093:incall'
C:/Users/Deankkostov/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6Plugin.rb:1093:incommand_invoke' C:/Users/Deankkostov/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6Plugin.rb:1075:inblock (2 levels) in build_config_commands'
C:/Users/Deankkostov/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6Traductor.rb:1107:incall' C:/Users/Deankkostov/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6Traductor.rb:1107:inblock in add_command'
SketchUp:1:in `call'I tried reisntal, delete etc... these two plugins but the problem is staying again.I have Sketchup 2015 and windows 8.1.Any idea how to fix it ?
Is it possible you still have an older version of some files from LibFredo6 in the Plugins folder?
Now I deleted all replicated plugins of RoundCorner and do not have a massage to instal libFredo but when try to use the plugin I get this error in ruby console
rror: #<NoMethodError: undefined methodno_bandeau' for #<Traductor::Palette:0x000000108de770>> C:/Users/Deankkostov/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/Fredo6_RoundCorner/RoundCorner_Tool.rb:1045:inpal_sepa_bandeau'
SketchUp:1:in `call' -
You need to have the latest "LibFredo" installed to run almost all of his tools.
So that Lib + RoundCorners are the minimum you need, and it will work provided that nothing 'old' is left behind.
Also restart SketchUp after the install or other file-sorting out to ensure a proper load is achieved...I suspect you have copied files/folders over from the Plugins folder[s] of older versions of SketchUp ?
Not recommended.There are several possibilities...
The likely one is because newer 'LibTraductor' is now provided within the "Fredo6_!LibFredo6" subfolder, and there should NOT be a RB file of that name loading directly from the Plugins folder.
This might be causing the issue ?
If the old version loads and doesn't include theno_bandeaumethod the error arises...I suggest you remove all Fredo related files and subfolders from the Plugins folder; then reinstall the LibFredo, and then the Plugin itself, from their respective RBZ files, finally restart SketchUp and retest...
Ok TIG I will try it now.
This fix the problem thank you !
Thank you for your time guys !
