    Problem with components
    5 Posts 4 Posters 283 Views 4 Watching
    • K Offline
      kolmnurgad
      Hello, i was using sketchup 2014 and suddenly when i make a row of columns into a component, when i pull one column nothing happens with the other columns. What is this? i have tried everything. It doesn't change even when i make a new file. πŸ˜• Is this a bug or is it on my settings?
      Thanks!
        Can you post an example SKP ? πŸ˜•
        If you make the Component AFTER placing copies of something similar [e.g. Geometry OR Groups] it won't work.
        Make the Component then place it...
        • cottyC Offline
          cotty
          You make a row of components or a row into components? You should follow TIGs suggestion...
          my SketchUp gallery
          • pbacotP Offline
            Sounds like you made a component of a "row" of columns, instead of making a row from a single column component. Make a column into a component then make your row. Then when you edit one instance of the column component all the columns in the row can change.
            • K Offline
              kolmnurgad
              Thanks for the reply! yes that was the problem that i made component from multi objects into single group,
              very silly mistake. πŸ‘ case closed πŸ˜› 😳
