    Problem with components
    5 Posts 4 Posters 316 Views 4 Watching
      kolmnurgad
      Hello, i was using sketchup 2014 and suddenly when i make a row of columns into a component, when i pull one column nothing happens with the other columns. What is this? i have tried everything. It doesn't change even when i make a new file. πŸ˜• Is this a bug or is it on my settings?
      • TIGT Online
        Can you post an example SKP ? πŸ˜•
        If you make the Component AFTER placing copies of something similar [e.g. Geometry OR Groups] it won't work.
        Make the Component then place it...
        • cottyC Offline
          cotty
          You make a row of components or a row into components? You should follow TIGs suggestion...
          my SketchUp gallery
          • pbacotP Offline
            Sounds like you made a component of a "row" of columns, instead of making a row from a single column component. Make a column into a component then make your row. Then when you edit one instance of the column component all the columns in the row can change.
              kolmnurgad
              Thanks for the reply! yes that was the problem that i made component from multi objects into single group,
              very silly mistake. πŸ‘ case closed πŸ˜› 😳
