    Problem with follow me
    10 Posts 4 Posters 668 Views 4 Watching
      littleche
      hi
      I recently came into trouble with follow me tool .
      in this file you see one profile and one path . I think everything is correct But the result is not good! where I was wrong? In your opinion, where I wrong?
      follow me.skp
        Make sure the FollowMe face is square to the start of the path...
        But... I suspect that it's a 'small geometry' issue. 😲
        SketchUp baulks at edges < 1/1000" !
        So... try Scaling up x100, do the FollowMe, then Scale down again.
        ALSO - your faces are 'backwards' - use the context-menu option to reverse those faces - so no 'blue' backsides are seen...
          littleche
          thanks TIG
          I've tested previously Change scale But in this case does not respond.
          Currently backwards are not allergic and problem with follow me priority. Otherwise You're right, and must be Take care of our backwards .
          You could model correct with this file ?
          • cottyC Offline
            cotty
            You should place your face outside of the profile...
            my SketchUp gallery
              Scale x100, thenMove theCorrectlyOrientedProfileFaceOntoTheOUTSIDEofThePath_NOTOnTheVertex.PNGTheResult.PNG Then scale back down...
              • cottyC Offline
                cotty
                I've done it with the original scale.
                I think the trick is the position of the face outside of the path...
                my SketchUp gallery
                  I know, but scaling up/down can't hurt 😉
                    littleche
                    @cotty said:
                    I've done it with the original scale, I think the trick is the position of the face outside of the path...
                    thanks cotty . you right ...
                    I use Recommended method in instructor . According to me trimble make changes in follow me instructor! As you can see, in instructor face is center of the path !
                    In any case, thank you for your help.
                    In my culture, said:
                    Everyone has something to teach you,You're his servant...
                    Thank you very much from your teaching . 👍
                      CAUL
                      @littleche said:
                      hi
                      Your problem is inherent to FollowMe. Basically, if offset fails then FollowMe fails. There is a script here which handles some of these special cases. The script does not deal with loops so you have to join the frame manually with pushpull.
                      follow me (Followfy).skp
                        littleche
                        ok !
                        this scripts is great ! and I understand exactly the meaning of this performance.
                        Thanks for your help .It was Short and useful .
