    [Plugin] TIG-Fracture
    39 Posts 15 Posters 13.6k Views 15 Watching
      A Pro >= v8 Plugin to "Fracture" a Selected Solid Group/Component.
      Dialog to set number of 'Iterations' and the 'Size %', and a final 'Explode' option...
      Now available in the PluginStore http://sketchucation.com/pluginstore?pln=TIG_Fracture
      • jujuJ Offline
        juju
        "pics or it didn't happen"
          • jujuJ Offline
            juju
            thanks, as always, TIG delivers...
              driven
              TIG,
              is it possible to make it a single undo?
              john
                Yes. πŸ˜•
                But This way you can step back, undoing just the explode and then the various splits.
                Just find the model.start_operation()...model.commit_operation code and add a leading #
                Leave the first start_op and the last commit_ unchanged...
                  What about an option to uniformly scale each item about it's center via a picked/inputted value?
                  • soloS Offline
                    solo
                    I like this.
                    I am wondering if we could get different shapes, not too many long shards. Also is we could control the explode distances in future.
                    http://www.solos-art.com
                      driven
                      running enroth's erode on each piece adds to the effect of a rock wall...
                      • pbacotP Offline
                        Holy Grail
                        • jujuJ Offline
                          juju
                          @pbacot said:
                          Holy Grail
                          yeah, but i was thinking holy something else...
                            This plugin is not working for the MAKE version ?
                            • massimoM Offline
                              massimo Moderator
                              Fracture | SketchUcation
                              (sketchucation.com)
                              • KrisidiousK Offline
                                Krisidious
                                Dude... I can use this for Stained Glass. Nice TIG.
                                By: Kristoff Rand
                                  Dependencies: Pro
                                  Ah! curious maybe because that use some solids functions πŸ˜„
                                    Here's v3.0 http://sketchucation.com/pluginstore?pln=TIG_Fracture
                                    It now has three options to set constraints for the splitting around the XYZ axes, 0 to 1.
                                    The nearer to 0 the 'flatter' the split on that axis.
                                    With all three set to 1 it's entirely random.
                                    Play with their interrelationships to see the effects.
                                    Also now there are three 'Form' options:
                                    • Stacked - all parts left in place
                                    • Exploded - all parts from the center
                                    • Scaled - each part by ~90% to leave gaps
                                      If a non-Stacked Form is chosen it is separately undo-able.
                                      All of the Fragmentation is now undo-able in one step.
                                      Excellent....
                                      [edg3d:2r4rerg8]Kkw7hxg8YhQU3ne[/edg3d:2r4rerg8]
                                      Another request that if there's materials in the model you can choose which material get assigned to the faces sliced faces?
                                        Option for have only boxes ?
                                          Voxelize?
                                          • deaneauD Offline
                                            deaneau
                                            cool TIG..this plugin and sketchyPhysics could be a dream team πŸ‘ πŸ‘ πŸ‘
                                            MADE, BORN AND LIVING IN BERLIN
                                            Big Thank You to all Programmers
                                            Some German words are so long that they have a perspective. M.Twain
                                            • 1 / 2
